DVD Assist - VIDEO_TS playback for Front Row - Page 17 - AVS Forum | Home Theater Discussions And Reviews
post #481 of 499 Old 03-15-2008, 11:19 AM
Jordy15675's Avatar
Hi there, as far as I know, and forgive me if I'm wrong, DVD assist is designed to run under Tiger and not Leopard, the main reason there isn't Leopard compatibility with DVD Assist is because Leopard plays Video_TS files in Front Row.
ISO files as far as I know aren't compatible with Front Row in Leopard, so I'm thinking you'll need to turn them into folders containing the Video_TS file in order to play them back.
Like I say I could be wrong, but I don't think you'll see DVD Assist getting any updates. There is a plugin for the new Front Row called Sapphire (http://appletv.nanopi.net/), I don't know much about it but it might help with your problem if you don't fancy converting your files.
Jordy15675 is offline
post #482 of 499 Old 03-18-2008, 06:59 PM
bootx's Avatar
Jordy15675, thanks for the quick reply and info. I'll try the Sapphire plug. It seems to do something else that I was looking to do.
I was wrong in one respect, Front Row is still part of "CoreServices".
DVDAssist works or should I say, it almost does everything: it mounts the iso, opens DVD Player, starts playing in DVD Player. It's just that the DVD Player app stays in the background behind Front Row, meaning, Front Row is the "front most app", commandeering the screen/Mac. I can quit Front Row and navigate to DVD Player to play the "iso", but it defeats the purpose of what I was trying to do.
My guess is that the part of the script that supposed to quit Front Row is broken. I looked at the script, but I'm not "fluent" in scripting and couldn't figure it out. It seems like it would be a simple fix, but not being a scripter I don't know, I'm just speculating.
Thanks again for your advice.
B
bootx is offline
post #483 of 499 Old 05-11-2008, 02:41 AM
simpletonne's Avatar
The following will mount all iso files found in /Volumes/share/Movies/iso. The show will be available in Front Row under the disc name.
for f in /Volumes/share/Movies/iso/*.iso ; do hdiutil mount -readonly - mountroot ~/Movies "$f" ; done
Add a capital letter in front of the first asterisk to limit the scope for testing.
simpletonne is offline
post #484 of 499 Old 05-26-2008, 11:26 PM
pch1's Avatar
Dear all:
I tried to set up a Media Center environment out of my MacBook before I will buy a MacMini, did a lot of testing. I have a few test dvd's (video_ts files) on my external ethernet HDD and tried to pplat them with Frontrow, but when playing the files there were al lot of "hick-ups" and the picture and sound were not smooth. I tried playing the files directly with VLC and the dvd-player in Apple and then they played very good and smooth! So I went on the internet looking for some kind of plugin in Frontrow and came across "DVD Assist" and this site. 1st I did all the things explained in the tutural with the extra .mov folder and the aliasses but that didn't work out, then I started reading this whole topic (that lasted some time, my English isn't perfect because I'm Dutch!) and now I know that because I have Leopard and Frontrow 2.0 DVD Assist won't work at all...That's a pity.
Still have my problem: when ripping a dvd to external ethernet HDD in video_ts and playing them with VLC and Apple dvd-player picture and sound are ok, but playing them in Frontrow (aliasses of the movies) the picture and sound "hicks" and isn't smooth at all, how come?
For your knowledge:
I'm using a MacBook 2.2Ghz Santa Rosa with 120 Gb HDD and 2 Gb memory and Leopard and Frontrow 2.0
The rips are made in Windows with DVD Fab Platinum.
Paul.
pch1 is offline
post #485 of 499 Old 05-27-2008, 03:53 AM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
I have a few test dvd's (video_ts files) on my external ethernet HDD and tried to play them with Frontrow, but when playing the files there were a lot of "hick-ups" and the picture and sound were not smooth. I tried playing the files directly with VLC and the dvd-player in Apple and then they played very good and smooth!
Paul--first remove your ethernet network from the equation: move a VIDEO_TS file over to your Macbook hard drive and play that back with Front Row instead of the alias. Is it as smooth as with VLC & Apple dvd player or do you still get the hiccups?
How do you have your external ethernet hard drive hooked up?
chefklc is offline
post #486 of 499 Old 05-27-2008, 07:58 AM
pch1's Avatar
Forget to tell you that: everything (dvd-rips/video_ts) in Frontrow play with hickups! Even from the internal MacBook HDD!!!
So video_ts ripped dvd's play well from the internal HDD or external ethernet HDD with VLC or standard Apple dvd-player software, it is just that Frontrow won't plat them properly....I've tried to convert them to mpeg-4 with Handbrake and after a couple of hours (!) (that's the reason I won't it that way!? those files play ok in Frontrow...
Is that the only way?
I hoped for a Frontrow kind of playback of all my dvd's/files.
Gr. Paul.
pch1 is offline
post #487 of 499 Old 05-27-2008, 08:01 AM
pch1's Avatar
Well, I do have a ADSL2+ modem with two CAT5/ethernet ports. One goes to my Western Digital Netcenter 250 Gb HDD and the other is plugged into my MacBook, I thought that would be OK?
Paul.
pch1 is offline
post #488 of 499 Old 05-28-2008, 05:56 AM
pch1's Avatar
Pity no one can help me anymore....
Paul.
pch1 is offline
post #489 of 499 Old 05-28-2008, 07:10 AM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
well, your situation is strange, Paul, and we do have lives. What I can tell you is this: Front Row in Leopard (10.5.2) plays back VIDEO_TS just fine. Your network and external drive could have been a problem--so instead of trying to play back a file over your network, you've put a VIDEO_TS in the Movies folder of your Mac's internal hard drive--that removes those variables--then you verified Apple dvd player handles it just fine--that means the rip likely is good--and that Front Row still hiccups. OK, the next most likely candidate is that you've installed some hack or plug-in that is still interfering with Front Row. So, now boot your Mac up off of a "clean" Leopard install (from a USB or firewire drive) and try to play that VIDEO_TS with Front Row.
chefklc is offline
post #490 of 499 Old 05-28-2008, 07:11 AM
Further's Avatar
Don't give up so soon. Chefklc is one of our experts and he is probably just busy with his work.
I have one question: were all these rips done in Windows? If so, you should try ripping on the Mac and see if it has the same results.
Good luck.
Further is offline
post #491 of 499 Old 05-28-2008, 07:12 AM
Further's Avatar
Whoops, I spoke too soon!
Further is offline
post #492 of 499 Old 05-28-2008, 07:16 AM
pch1's Avatar
well, your situation is strange, Paul, and we do have lives. What I can tell you is this: Front Row in Leopard (10.5.2) plays back VIDEO_TS just fine. Your network and external drive could have been a problem--so instead of trying to play back a file over your network, you've put a VIDEO_TS in the Movies folder of your Mac's internal hard drive--that removes those variables--then you verified Apple dvd player handles it just fine--that means the rip likely is good--and that Front Row still hiccups. OK, the next most likely candidate is that you've installed some hack or plug-in that is still interfering with Front Row. So, now boot your Mac up off of a "clean" Leopard install and try to play that VIDEO_TS with Front Row.
Like I said: the external HDD isn't the problem: from the internal HDD the problem in Frontrow is the same: hickups!
I was thinking: maybe it is the way my rips (video_ts) is on the External HDD: it is made in Windows with DVD Fab platinum, does Windows make some kind of other video_ts then a Mac ripping program or what ripprogram do you advice for me to play my dvd's smooth in Frontrow?
Still strange: with the present files on the external HDD made with a Windows machine they play smooth and WITHOUT hickups with the standard Apple dvd-playet and VLC: it is always that Frontrow plays them awfull...
Strange isn't it???
Paul.
pch1 is offline
post #493 of 499 Old 05-28-2008, 07:30 AM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
Paul--at this point we've removed your external hard drive, ethernet network, Windows, ripping software, etc from the equation. So before you expand your range of questions about Windows software and ripping programs in OS X, back up.
Fact: you have a VIDEO_TS that opens and plays just fine in Apple dvd player when on your internal hard drive.
Fact: such a VIDEO_TS should ALSO play fine in Front Row.
Suspicion: you've screwed up your current OS install by installing/uninstalling various other stuff.
Solution: boot up from a clean Leopard install and test that VIDEO_TS.
Why? Apple dvd player.app is pretty picky--it doesn't just open and play everything. So the fact that it IS playing your VIDEO_TS--even though you got it from Windows ripping software--makes me think that VIDEO_TS is fine and it still leads me to believe that Front Row should be able to handle it.
Another thing you can do is stick a dvd in the drive, then open FR, and try to play it back. Hiccups?
chefklc is offline
post #494 of 499 Old 05-28-2008, 09:14 AM
pch1's Avatar
First of all I want to thank you chefkic for your help and time so far!!!
yes, even from the external HDD.
OK
can that be caused by "Perian" or "Flip4Mac"?
WOW, that is too risky for me, I cannot do that I'm afraid.
OK
I will test that right now!
THX!
Paul.
pch1 is offline
post #495 of 499 Old 05-28-2008, 09:39 AM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
Paul, I don't mean erase and reinstall your Macbook drive--I mean boot the Macbook off of a separate clean install of Leopard that's on an external drive. All you need is a spare drive--any size, 2.5 or 3.5, IDE or SATA--it's good practice to have a bootable backup of your Macbook on an external drive anyway. For troubleshooting like this--it's wise to have an external drive, it can be firewire or USB, partitioned with one volume that's a bootable clone (a perfect copy of your Macbook drive, I use SuperDuper) and a second volume that has a "clean" Leopard install on it. (Leopard installed right to that drive.) It's painless to create--and it's useful just for this strange situation. What you want is to boot off the clean install that hasn't ever had any version of Perian or Divx or Flip4Mac or DVDAssist or remote/keyboard drivers installed or uninstalled--just such things can muck up Front Row and Quicktime.
You actually need both of these--the SuperDuper clone protects you if you ever install something that really screws up your Macbook, even an official Apple software update can break something--and the only way to fix it is to revert to what your system was before the upgrade. With that clone, you just copy that back to the Macbook drive and you're back where you were pre-update. For your current Front Row troubleshooting--something that should work inherently without any third party stuff--that second "clean" volume with an install of Leopard on it but with no third party stuff is what you need. If that VIDEO_TS plays in FR, booted off of that clean install, then you know you did muck things up...
chefklc is offline
post #496 of 499 Old 05-28-2008, 09:51 AM
pch1's Avatar
OK, I did the testing: a DVD in the drive plays without hickups in Frontrow! I must say with some slow horizontal and vertical pans it sometimes isn't as smooth as with the "normal" dvd-player, but it is FAR better then a video_ts file...
How come a video_ts file (dvd-rip) won't play properly in Frontrow and a dvd is? Strange isn't it?
Isn't it just possible to throw away the old Frontrow in the bin (uninstall it) and download Frontrow again and reinstall it?
BTW: I see Flip4Mac and Perian are not in my programs-folder but somewhere else in a system-folder where I cannot drag and drop it in the bin, how come?
Paul.
pch1 is offline
post #497 of 499 Old 05-28-2008, 10:46 AM
Further's Avatar
If a DVD plays normally, then I think there is a problem with your rips. I would recommend ripping one DVD on the Mac and trying that.
I would try that before removing or uninstalling anything.
Further is offline
post #498 of 499 Old 05-28-2008, 11:35 AM
pch1's Avatar
Yeah, I've tried that too with OSEx, I believe Mac The Ripper too, but I guess I need some tweaked settings? Because the rips with those programs on my MB still hicked in Frontrow...
Do you have the best advice for a good program and settings?
Does handbrake make good video_ts or just converting into mp4/mpeg4?
Paul.
pch1 is offline
post #499 of 499 Old 05-29-2008, 01:28 AM
Further's Avatar
Unfortunately, you're asking one of the few people here who does not rip DVDs. I play the DVDs themselves. I don't think Handbrake will rip to a normal VIDEO_TS format.
I think your next step should be what Chefklc recommended to boot up from a clean install of Leopard.
Further is offline
Reply HTPC - Mac Chat
