SwitchresX on a Samsung HP-S4253 w/ Intel Mac Mini - AVS Forum | Home Theater Discussions And Reviews
Old 10-24-2006, 09:42 PM - Thread Starter
EROCK78's Avatar
Greetings all. Long time lurker first time poster. Sorry if this info has been hashed before but I have tried many options and searching on this forum regarding my TV...and am coming up short with switchresX. I cant seem to find timings anywhere regarding this TV
I have purchased a copy of the software running a standard dvi ->hdmi cable from my mini to my TV results in a 1280 x 720 native rez. However, the screen has a black 1.5 inch border around with overscan turned on and turned off leaves the dock and finder bar out of range. Help! I know that I have to use a custom rez and I probably wont get a true 1:1 pixal map, however I would prefer to fill my screen. So with that said I have tried many many settings to no avail. I think I am missing something simple....
I have exported my DDC options. Can someone who is knowledgable with SwitchresX assist me? I would be very grateful. Anyone have any ideas? Can I not go out side of the ranges:
Horizontal frequency range.......30-48 kHz
Vertical frequency range.........55-65 Hz
posted in my DDC dump?
Also note the TV manual it says you cant do pc DVI->HDMI...but this works straight ouf of the box just with a black border.
Thanks ahead of time.
DDC block report generated by SwitchResX for display
SAMSUNG PDP
0 1 2 3 4 5 6 7 8 9 A B C D E F
0 | 00 FF FF FF FF FF FF 00 4C 2D 28 02 00 00 00 00
1 | 34 0F 01 03 80 6F 3E 78 0A EE 91 A3 54 4C 99 26
2 | 0F 50 54 20 00 00 01 01 01 01 01 01 01 01 01 01
3 | 01 01 01 01 01 01 01 1D 00 72 51 D0 1E 20 6E 28
4 | 55 00 4E 6C 42 00 00 1E 01 1D 80 18 71 1C 16 20
5 | 58 2C 25 00 4E 6C 42 00 00 9E 00 00 00 FD 00 37
6 | 41 1E 30 08 00 0A 20 20 20 20 20 20 00 00 00 FC
7 | 00 53 41 4D 53 55 4E 47 20 50 44 50 0A 20 01 7B
Valid DDC block: checksum passed
EDID Version........1.3
Manufacturer........SAM
Product Code........10242 (2802) (0228)
Serial Number.......0
Manufactured........Week 52 of year 2005
Max H Size..........111 cm
Max V Size..........62 cm
Gamma...............2.20
DPMS Supported Features:
Display type:
RGB color display
Input signal & sync:
Digital
Color info:
Red x = 0.640 Green x = 0.300 Blue x = 0.150 White x = 0.312
Red y = 0.330 Green y = 0.600 Blue y = 0.060 White y = 0.329
Established Timings:
640 x 480 @ 60Hz
Manufacturer Reserved Timings:
Standard Timing Identification:
Monitor Description blocks:
Descriptor #0 is Timing definition:
Mode = 1280 x 720 @ 60Hz
H. Active...............1280 pixels
H. Blanking.............370 pixels
V. Active...............720 lines
V. Blanking.............30 lines
HSync Offset............110 pixels
HSync Pulse Width.......40 pixels
VSync Offset............5 lines
VSync Pulse Width.......5 lines
Pixel Clock.............74.25MHz
Horizontal freq.........45.00kHz
Vertical freq...........60.00Hz
H Image Size............1102mm
V Image Size............620mm
H Border................0 pixels
V Border................0 lines
Non-Interlaced
Sync: Digital separate with
* Positive vertical polarity
* Positive horizontal polarity
Descriptor #1 is Timing definition:
Mode = 1920 x 540 @ 60Hz
H. Active...............1920 pixels
H. Blanking.............280 pixels
V. Active...............540 lines
V. Blanking.............22 lines
HSync Offset............88 pixels
HSync Pulse Width.......44 pixels
VSync Offset............2 lines
Horizontal freq.........33.75kHz
Vertical freq...........60.05Hz
Interlaced
Descriptor #2 is Monitor limits:
Maximum bandwidth unspecified
Descriptor #3 is Monitor name:
SAMSUNG PDP
EROCK78 is offline
Old 10-26-2006, 09:00 PM - Thread Starter
EROCK78's Avatar
Anyone?
EROCK78 is offline
Old 11-03-2006, 01:09 PM - Thread Starter
EROCK78's Avatar
Bump
EROCK78 is offline
Old 11-03-2006, 01:34 PM
Doug_Eldred's Avatar
I can't help you directly, but you might also want to post this in 123macmini.com's HTPC forum.
Doug
Doug_Eldred is offline
Old 02-04-2007, 03:17 PM
slac8200's Avatar
My LCD-TV specs matches yours very closely. Where you able to solve this?
slac8200 is offline
Old 02-08-2007, 09:42 AM
dajesta007's Avatar
I have the exact same TV as you (HP-S4253) and I would love to know the proper settings. Were you able to make any progress with the resolutions and DisplayConfigX/SwitchRes? I spent days trying to get it set properly and ended up giving up and using the RGB connector in disgust. It was the only way I could get the image to fill the whole screen with nothing being cutoff. Please share if you were successful.
dajesta007 is offline
Old 02-09-2007, 01:46 AM
taugust04's Avatar
I'm starting to think this is a limitation with Samsung HDTV's HDMI port, and not necessarily wuth the Mac. I had the same exact issue, with no success, and ended up using a VGA cable from the Mac to the "PC" input on the Samsung to get the issue resolved.
taugust04 is offline
