Best LCD TV/Monitor to use with Mac Mini - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-17-2007, 02:46 PM - Thread Starter
Brazilian's Avatar
I'm looking for a LCD TV/Monitor (around 20) to use with my Mac Mini (Intel) in regular basis. Therefore it must perform as a good monitor as well.
Brazilian is offline
post #2 of 8 Old 01-17-2007, 04:11 PM
kenliles's Avatar
In a different forum discussion, someone said that the Dell lcd monitors are the same identical specs as the APple monitors for much less money; I haven't verified this, but pass it along for your research and consideration...
ken
kenliles is offline
post #3 of 8 Old 01-17-2007, 05:21 PM
nharmon91's Avatar
Well they use the same exact screen if im not mistaken, the only difference is the casing.
nharmon91 is offline
post #4 of 8 Old 01-17-2007, 05:45 PM
kenliles's Avatar
yes, that's what I was told as well...
kenliles is offline
post #5 of 8 Old 01-18-2007, 07:19 AM - Thread Starter
Brazilian's Avatar
Are you talking about the W2306C or the regular monitors?
I need one that will also work as a TV with at least 1 S-video input. (Preferable if with internal tuner) Then, this is the only in dell's website that fits my needs.
Do you know if the mac mini can work with it in native resolution? And how good is the image when using as a Tv?
post #6 of 8 Old 04-29-2009, 07:29 PM
robert223's Avatar
Originally Posted by Brazilian View Post
I’m looking for a LCD TV/Monitor (around 20”) to use with my Mac Mini (Intel) in regular basis. Therefore it must perform as a good monitor as well.
Did you find one ?
edit:sorry it is 2 years old thread.But still need 19-20 inch lcd.
robert223 is offline
post #7 of 8 Old 04-30-2009, 03:10 PM - Thread Starter
Brazilian's Avatar
Today, you have many options.
I have a frind with one LG - m228wa and he is quite happy. Its much than the Sony I bought 2 years ago!
post #8 of 8 Old 11-03-2011, 09:58 AM
ronjohnson88's Avatar
I think that the best is actually Apple. I have a place you can check out that will help you pick the best monitor and helps your see what one you need.
ronjohnson88 is offline
Reply HTPC - Mac Chat
