AppleTV - Converting my files into compatible format - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-18-2007, 02:44 PM - Thread Starter
Franois L.'s Avatar
Hello,
I am thinking about purchasing the AppleTV, even though I won't be able to purchase movies for a while (in Canada). My goal is to stream movies from my computer, and my movies are in these formats:
1) DVD rips (.iso, .img, video_ts)
2) Xvid/Divx/Mkv/Mpeg/
How do I convert these into the H.264 format compatible with AppleTV ?
What software do I use? I am using Windows XP.
Francois
Franois L. is offline
post #2 of 7 Old 02-18-2007, 08:30 PM
kneedragger's Avatar
Quoted: 18 Post(s)
You can use Nero 7, handbrake, X.264 and theres probably more.
You might want to wait and see what are the exact limits of the appletv.
kneedragger is offline
post #3 of 7 Old 02-19-2007, 06:50 AM
sheldonmclean's Avatar
I think anything that can create iPod video. I think the formats are compatible.
Also here are 7 others:
http://www.versiontracker.com/php/se...indows&x=0&y=0
I'd also know that mpeg streamclip and avidemux have windows versions. Both are powerful.
--sdm.
--sdm
visit my photo-retouching website: Shift Studio Image Retouching
sheldonmclean is offline
post #4 of 7 Old 02-19-2007, 05:07 PM
Andrew67's Avatar
Handbrake has been forked so check out MediaFork. It's an updated, and hopefully, properly maintained version of Handbrake.
Andrew67 is offline
post #5 of 7 Old 02-19-2007, 08:50 PM
GoodOmens's Avatar
You might want to wait a bit and see if the apple tv will support mulit-channel aac.
No word on this yet. It makes logical sense (why else have a optical out) but the ipod is only 2 channel ....
GoodOmens is offline
post #6 of 7 Old 03-17-2009, 07:36 AM
tomfoolery_79's Avatar
Can someone tell me if the AppleTV will read .mp4's encoded using Handbrake's PS3 setting?
Why you ask, because I have a PS3 and much of my library is already encoded to the PS3 format, but I've decided I like the AppleTV interface better. Thx in advance.
STEAM: Augcliffe
PSN: Augcliffe
tomfoolery_79 is offline
post #7 of 7 Old 03-18-2009, 02:02 AM
beatboy's Avatar
One option would be to install XBMC on it, after that it would play almost anything you throw at it. Within the limits of hardware of course.
beatboy is offline
Reply HTPC - Mac Chat
