Best Choice for HD in an iMac? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-22-2007, 08:09 PM - Thread Starter
mraub's Avatar
It looks like the 2 choices for getting an HD signal into an iMac is the ElGato eyeTV hybrid and the Miglia TVMini HD. Does anyone have a strong recommendation of one over the other? My first use will be for OTA ATSC TV viewing. I thought there was a HDTV receiver with a Firewire connection, but I can't seem to find such a product for sale.
My iMac is a 24" Intel with 2GB of memory, and the upgraded CPU and video card, if that makes any difference in recommendations.
Thanks for any advice.
MIKE
For every complex problem, there is a solution that is simple, neat, and wrong.
--H. L. Mencken
mraub is offline
post #2 of 6 Old 02-22-2007, 09:01 PM
khisayruou's Avatar
The eyetv 500 is the firewire device that has been discontinued. You will have to search ebay, etc.
http://www.elgato.com/index.php?file=products_eyetv500
In my tests, the hybrid had a very weak signal strength compared to the miglia tvmini hd. Of course YMMV. The miglia can also tune into clear qam. I ended up giving up on the hybrid, there were too many dropped signals and too much antenna adjusting for me to keep.
khisayruou is offline
post #3 of 6 Old 02-23-2007, 10:53 AM
ibglowin's Avatar
Definitely try and pick up a used EyeTV 500 on ebay. Seems to be working much better than anything else these days.
ibglowin is offline
post #4 of 6 Old 02-23-2007, 12:18 PM
jwcrash's Avatar
Third that recommendation.
jwcrash is offline
post #5 of 6 Old 02-23-2007, 02:03 PM - Thread Starter
mraub's Avatar
Thanks for the advice. There must be some old stock still floating around; I seem to have found a new unit on Amazon. With all the devices I already have plugged into my USB bus, I think a Firewire connection should prove less troublesome, given the amount of data an uncompressed HD signal creates.
MIKE
--H. L. Mencken
mraub is offline
post #6 of 6 Old 02-27-2007, 09:46 AM - Thread Starter
mraub's Avatar
Even though the EyeTV 500 is officially discontinued, I ordered one new from jr.com. At first I got a backorder notice and figured that was the end of that. Today, though, I got an e-mail that the unit had shipped.
Just passing along the information in case anyone else was wanting a Firewire HD tuner for a Mac. JR.com's price, with shipping, came to $167.62.
MIKE
--H. L. Mencken
mraub is offline
Reply HTPC - Mac Chat
