HDHomerun works in Mac OS X - AVS Forum | Home Theater Discussions And Reviews
post #1 of 74 Old 03-02-2007, 09:54 PM - Thread Starter
Joann's Avatar
The HDHomerun is a fine little device. I just got a chance to play with it tonight. I'm testing it specifically because my intent is to run a mythbackend in OS X using the HDHomerun as a video capture device. So far, so good. The HDHomerun detects my available QAM channels and streams them over the network to VLC running on my Mac. No nice and easy user interface, but it does work, FYI.
Joann is offline
post #2 of 74 Old 03-02-2007, 10:10 PM
Montressor's Avatar
Sweeeeet. Didn't know about this device before but I'm close to cobbling together a system to do just this for analog cable with a combination of Apache, PHP, AppleScript, VLC, shell scripting, EyeTV and iRed/IRTrans. Yes, it's an incredible hack. One of the limitations has been a forced choice between QAM, ATSC or digital cable. Or I could go out and buy 3 separate devices and hope EyeTV could handle them. I'll check this beastie out - it may solve the free HD part of the equation, while the Hybrid could solve the cable box part of the equation. Thanks for the heads up.
One question: is this limited to a local network or can it be accessed from the net at large? Does it have any security capabilities?
Montressor is offline
post #3 of 74 Old 03-02-2007, 10:22 PM
Montressor's Avatar
OK, did a bit more research and found that there's not really a way to distribute the stream out via the net, at least not without reencoding it at a lower bitrate through something like VLC. The Slingbox might be a better product for net streaming, bujt for inhome use this seems pretty cool.
post #4 of 74 Old 03-03-2007, 08:10 PM
bdraw's Avatar
Quoted: 161 Post(s)
Liked: 70
Yeah the HDHomeRun is pretty impressive.
I use it to stream HD to may MBP all the time especially during football season so I know when the big game is back on.
It streams HD over 802.11G perfectly (ATSC sourced), I just wish there was a more elegant UI than the cli. I wrote a few bash scripts with my favorite channels so all I have to do is write ./24 to switch to that channel. It would be nice if someone wrote a player for OSX that was easier to use.
I have also used the MCE driver which works pretty good.
Ben
How good could it be if it isn't HD?
No longer contributing to Engadget HD
bdraw is offline
post #5 of 74 Old 03-04-2007, 02:38 AM
vladd's Avatar
Liked: 39
It's coming. (One of you may be doing it, I don't know).
Someone is working on an AppleScript Studio program to tune the device and stream to VLC. I will post a link in the Silicondust dev forum when they have it completed. See http://www.silicondust.com/forum/viewtopic.php?t=2845 for the discussion.
vladd is offline
post #6 of 74 Old 03-04-2007, 05:23 AM
Jimwesternguy's Avatar
There are requests on the SageTV forum that HDHomeRun support be added to SageTV for OSX (now in Beta). Then one would have an alternative for the recording of hi-def clear QAM and OTA in OSX.
Jimwesternguy is offline
post #7 of 74 Old 03-04-2007, 08:32 PM
vladd's Avatar
Liked: 39
vladd is offline
post #8 of 74 Old 03-04-2007, 08:44 PM
chrobins's Avatar
Hold the presses. Don't you mean MythFrontend? I'm not aware of backend support for OS X, but I really wish there was.
Here's my ultimate dream:
1. MythTV backend server running Linux or OS X. Multiple HDHomeRun's connected to provide the content and a big fat NAS to dump the recordings to.
2. Apple TV in the bedroom to view what I've recorded. I could care less about iTunes content. I just want the slim silent package, HDMI, and nice UI of AppleTV.
As far as I know, AppleTV won't work with Linux since Linux doesn't have iTunes. If MythTV backend could run on OS X then all of my problems would be solved.
chrobins is offline
post #9 of 74 Old 03-05-2007, 11:40 AM
aa1979's Avatar
Originally Posted by vladd View Post
It's posted at http://www.oshinetworks.com/HDHomeRun/hdhomerun.dmg
I'm the developer. See the post at http://www.silicondust.com/forum/vie...?p=17201#17201 for instructions. We have many features planned for future versions - device detection, channel scanning, saving favorite channels, etc. So this is just a start.
Andy
aa1979 is offline
post #10 of 74 Old 03-05-2007, 01:04 PM
Joseph S's Avatar
Quoted: 12 Post(s)
Will be keeping an eye on this for sure. Keep up the good work.
Joseph S is offline
post #11 of 74 Old 03-05-2007, 08:48 PM - Thread Starter
Joann's Avatar
MythFrontend is easy, I meant MythBackend. There are people out there doing it, but it's not well documented. The development of the HDHomerun makes it worthwhile to spend the time to get MythBackend running on my Mac.
Joann is offline
post #12 of 74 Old 03-07-2007, 07:41 AM
markjeske's Avatar
Please keep us apprised of your progress as I would love to run mythbackend on the mac. Do you have any links to anyone who has this working? My google search doesn't turn up anything.
thanks
markjeske is offline
post #13 of 74 Old 03-08-2007, 04:09 PM - Thread Starter
Joann's Avatar
thanks
The information is sparse, no doubt about it. How about this, from http://www.oreillynet.com/mac/blog/2...ia+Center+Now:
"Don't forget MythTV (http://www.mythtv.org). It's an open source project with distributed client/server architecture. The 'client' (more properly known as a frontend) already runs on Mac OS X (ppc & intel). The 'server' (backend) also runs on Mac OS X however there are limited options for capturing video on a Mac OS X backend - firewire connection to a HD settop box, a USB2 capture device and the HDHomeRun (http://www.silicondust.com) have all been made to work (though are perhaps a little 'beta' at the moment)."
Or this, from http://digg.com/apple/MythTV_On_Intel_Mac:
kkuphal on 3/22/06 "The development version of MythTV has both frontend and backend components running on OS X as of a few days ago. Firewire tuner backend support was recently added and the frontend has been on OS X for some time now."
I have very little time to devote to this, but want something better than my networked Replays and Cableco's HD DVR. I've given up waiting for someone to make it easy for me, so I'm playing with it off and on as I get to it.
Joann is offline
post #14 of 74 Old 03-10-2007, 10:36 PM
procon's Avatar
El Gato really should support the HD Homerun, because as a networked device, it would really enhance EyeTV.
One of the nice things about Sage, Myth or the more robust PVRs is that it supports clients. I have a computer / TV, but wouldn't mind watching TV on my laptop (or better yet, my laptop hooked up to a projector). You can't do that in EyeTV now-- there was a 3rd party hack, but it didn't work for me-- but if the EyeTV supported the HDHomeRun, then you'd be in business. Live TV would be available to any computer on the network with EyeTV, and the saved recordings could be shared easily enough as well.
The only thing missing is commercial skip, but with everything else working out, we could focus our time getting comskip to work with DarWine. After that, it'd be pretty easy to post-process those EyeTV files.
So does anybody have an in with El Gato? Do you think they'll support the HD Homerun?
procon is offline
post #15 of 74 Old 03-22-2007, 12:07 PM
FriarWyer's Avatar
HDHRControl 1.1 for Mac OS-X is available.
Source-code is also included in the download.
You can access it here:
http://yanoweb.com/HDHRControl.zip
Enjoy. Let me know if you have any problems, questions, or suggestions.
Andy
FriarWyer is offline
post #16 of 74 Old 03-22-2007, 12:30 PM
Kid Red's Avatar
All this sounds interesting. I want to get HD on my main computer and stream it or ethernet it to my HT system. Is this something I should look into? Is this simply to record HD programs on your mac? Don't know much about HDHomerun and have seen the Myth program mentioned once or twice.
Kid Red is offline
post #17 of 74 Old 03-23-2007, 10:02 AM
procon's Avatar
Andy-- that looks great, thanks! I'll be trying it tonight.
Thank you!
procon is offline
post #18 of 74 Old 03-24-2007, 12:19 AM
FriarWyer's Avatar
The most recent version is 1.4.
VLC startup is better, and you can set the UDP port.
post #19 of 74 Old 03-27-2007, 07:34 AM
tji
tji's Avatar
That looks like a great app. I tried it out, but it doesn't work in my network setup. My HDHomeRun is on a different subnet than my wireless network. So, the auto-detection doesn't work. With the command line apps, I just specify the IP address of the HDHR and it works fine.
When I tried your app, it gave a message like "No HDHomeRun devices found on network", but didn't give me an option to enter the IP address manually.
tji is offline
post #20 of 74 Old 04-03-2007, 06:29 AM
procon's Avatar
I'm glad Andy created HDHR Control, because otherwise I would be up a creek and still not have decent TV; the quality and breadth of QAM on my network is great. I'm impressed with your intention to add recording scheduling, and I hope that some of the other PVR players will follow your lead.
It seems to me that a simple Mac binary installation of Myth working with HdHomerun would make a huge splash in the Mac world.
procon is offline
post #21 of 74 Old 04-17-2007, 07:26 PM
FriarWyer's Avatar
I've just uploaded a new version of HDHRControl.
Version 1.6, now includes support for scheduled recordings, both one-shot and series recordings.
Here's a screenshot:
Sourcecode is included in the download.
Andy
post #22 of 74 Old 04-17-2007, 08:27 PM
zmatzkin's Avatar
Very cool! I am starting to think I need to get one of these...
zmatzkin is offline
post #23 of 74 Old 04-18-2007, 10:49 AM
dthigpen's Avatar
Indeed it is. While I primarily use it to record QAM in Vista Media Center, I sometimes use it wirelessly over an 802.11n connection on my MacBook via VLC to watch HDTV wherever I want to plop my butt.
HDHRControl is an outstanding and simple app to use it, too. Someone should port it to Windows and Linux for those that just want a simplified front end for everything. Maybe I'll take it to task, if it's licensed under a compatible license, that is. (Which, after just looking, it's licensed under the GPL, so I think I'll get started on a Linux port if nobody else has).
Douglas Thigpen
dthigpen is offline
post #24 of 74 Old 04-18-2007, 11:16 AM
bdraw's Avatar
Quoted: 161 Post(s)
Liked: 70
11n can stream QAM? I stream ATSC with G from my HDHomeRun all the time, but QAM at 38Mbps proves too much for G. What type of distances can you achieve before the stream breaks up?
I have been considering swapping the 802.11 boards between my MacBook and my Apple TV, this might convince me it's worth it.
Ben
bdraw is offline
post #25 of 74 Old 04-18-2007, 05:04 PM
dthigpen's Avatar
I'm stream QAM streams to the other side of the house (3000sq) all the time, walls and all, over 802.11n.
Douglas Thigpen
dthigpen is offline
post #26 of 74 Old 04-18-2007, 06:36 PM
Joseph S's Avatar
Quoted: 12 Post(s)
Can the app be made to support multiple tuners?
Joseph S is offline
post #27 of 74 Old 04-18-2007, 07:04 PM
tji
tji's Avatar
The HDHomeRun filters the content. It only streams the PID / Program you select, not the whole QAM channel or even the whole ATSC stream.
Using 802.11G in my MacBook Pro, I can stream HD channels pretty reliably.
tji is offline
post #28 of 74 Old 04-25-2007, 11:42 PM
MickeyDora's Avatar
What would be the lowest end Mac you can use to properly record (not playback) from this?
I would love to be able to record 2 simultaneous streams (tuner 0 &1) from QAM.
I have a few iMac G3's laying around and a 466mhz G4 that I can use just for recording.
MickeyDora is offline
post #29 of 74 Old 04-26-2007, 09:07 AM
pkscout's Avatar
If all you're doing is recording the raw ATSC stream to the drive, then it is likely that any G4 would do, and even a G3 with a decent drive might work. There really isn't anything to do on the recording side other than dump the data to the drive.
pkscout is offline
post #30 of 74 Old 04-26-2007, 09:10 AM
tji
tji's Avatar
I used to have a G4 Cube (450MHz), which I hung a couple 3.5" drives off of via firewire. I used it as an smb file server, and recorded shows onto it from a Windows PC with a MyHD card and a Fusion3 card. The overhead of 2 to 3 20Mbps streams was barely a blip on the CPU meters.
The streaming of the files from the HDHomeRun should be similar, possibly even lower because the HDHR strips unneeded data from the stream. I would give it a try with the G3s. If they don't work, the G4 should.
(I should have hung onto that Cube.. it made a great server for holding all my iTunes content. But, when the newer iPods dropped firewire support, it became much less attractive.)
tji is offline
Reply HTPC - Mac Chat
