Removing subtitles from mkv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-12-2008, 07:06 AM - Thread Starter
Jshwon's Avatar
Does anyone know how to do this? I have a file that plays but it has english subtitles and I want to remove them. Is there a file that can be removed to do this?
Jshwon is offline
post #2 of 14 Old 01-12-2008, 07:34 AM
Further's Avatar
Why do you need to remove them? Just don't show them.
Further is offline
post #3 of 14 Old 01-12-2008, 12:00 PM - Thread Starter
Jshwon's Avatar
I would love to do that but when I open the file in vlc they are on by default. Is there an option in vlc to turn them off?
Jshwon is offline
post #4 of 14 Old 01-12-2008, 01:44 PM
Further's Avatar
I have never had that experience. But, in VLC, go in the Video menu and the last item is subtitles track. You can try to turn them off there.
Further is offline
post #5 of 14 Old 01-12-2008, 06:43 PM - Thread Starter
Jshwon's Avatar
Thanks, simple solution.
Jshwon is offline
post #6 of 14 Old 01-16-2008, 06:50 AM
benzizbit's Avatar
So the subtitles of MKV are not embedded in the movie? thay can be turned on & off.
benzizbit is offline
post #7 of 14 Old 01-30-2008, 03:40 AM
benzizbit's Avatar
Is there a tool/sw I can use to edit (adding, removing) the subtitles in mkv?
for Mac or windows.
Thx
post #8 of 14 Old 01-30-2008, 04:51 AM
albo75's Avatar
MkvMerge can. It's part of the MKVToolnix package: http://www.bunkus.org/videotools/mkvtoolnix/
albo75 is offline
post #9 of 14 Old 02-02-2008, 12:47 PM
benzizbit's Avatar
Thx
post #10 of 14 Old 11-01-2010, 05:41 AM
LeadBD's Avatar
I used this program to take the subtitles out and it wont play on my WDTV( saying undetermined) and it opens on my computer but nothing plays.
LeadBD is offline
post #11 of 14 Old 11-05-2010, 06:44 AM
alex cutter's Avatar
Another reasons for wanting to remove the subtitles would be if you wanted to burn a DVD of the mkv file in Toast -- if you don't remove the subtitle track with MKV Tools, Toast burns them into the file and they can't be disabled.
alex cutter is offline
post #12 of 14 Old 11-28-2013, 06:46 PM
beycan's Avatar
I'm using MeGUI to overlay my subtitles on mkv videos (that also have embedded default subtitles).
I read the video source with DirectShowSource command, then TextSub my srt file on the video.
The problem is that the output video has two subtitles, mine over the default one.
Is there a command to ignore the default embedded subtitles that can be used for Avisynth scripts?
beycan is offline
post #13 of 14 Old 12-19-2013, 03:31 PM
macman13's Avatar
http://www.emmgunn.com/mokgvm2dvd/mokgvmhome.html
MKVTools is my favorite for modifying tracks in MKVs on the Mac.
2x HDHomeRun Prime - 3CC
Sharp 65" TV; Sharp 46" TV; Panasonic 42" TV; Sony 40" TV; Sony 32" TV
WMC HTPC Server: Intel Celeron G1840, 4GB RAM, MSI H81M-P33, 1TB
Main HTPC: Mac Mini 2.3Ghz i5, 8GB RAM, 500GB, 1TB, 2TB, 3TB
XB360 WMC Extender, Ceton Echo, Roku 3, Apple TV 3
macman13 is offline
post #14 of 14 Old 02-01-2015, 12:42 AM
Liked: 0
To remove subtitles from MKV, there are lots of solutions online.
Just Google search "How to Remove Subtitles from MKV, AVI, MP4, etc without Hassle".
richisew is offline
Reply HTPC - Mac Chat
