Study: Native 16:9 vs a-Lens/PJ Scaler - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 12-29-2008, 10:00 PM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
Since my DIY a-lens slide is finished I was always curious to the PQ of "Native 16:9" vs thru the combo "a-Lens expansion/PJ compression Scaler".
(main reason for having a a-lens slide)
I've not seen this study done here before - did I miss it?
This is purely a subjective visual study at this time, I'm no expert and w/o "real" tools to capture objective data (besides a basic / decent camera).
My Equipment:
PJ: Sony VPL-VW60 (12 months old, less than 500 hours total on it)
a-Lens: Panamorph UH380 (b-stock avs power buy 10 months ago, hopefully PQ does not suffer because it's a b-stock unit)
Canon SD880 IS mounted on tripod, at center screen height/width 10' from screen.
Camera/Tripod of course not moved/zoom stayed same for all shots for relative comparision purposes.
Camera in program mode, flash off, ISO set to 100.
If I had a D-SLR could have totally fixed it's settings and seen a vs b comparision, but this should still capture any major diff's.
Had "Old School" on DVR, HD with some decent shots in it, so watched it tonight after the kids went to bed and put my just finished manual slide to use.
Back and forth, back and forth, cycle testing it....
The first thing I immediately noticed is the "a-Lens/PJ Scaler" image is about 3" skinner than the "native" image.
I put blue painters tape on the screen for the skinner image (a-Lens/PJ Scaler image), you can see that in most of the "native" shots.
Not sure why that's happening, according to what I've read and understood in the Sony manual the "normal" mode compresses 16:9 into 4:3, correct?
This should exactly counteract the a-lens 4/3 expansion ratio to give a net result of 16:9
Besides that look at the picts and make your own subjective visual observations:
Honestly, I was expecting more difference, like the native was obviously sharper/clearer, but I'm pleasantly surprised.
Looks like the "a-lens/PJ scaler" combo does a decent job.
Since this is a $3k lens and a +$4k PJ I'd expect this level of capability.
I'll have to dig into what's going on with the "squeeze" image I'm getting with the a-Lens/PJ Scaler doing their thing.
At this time I have absolutely NO plan to buy a separate scaler box.
Here are 5 comparison series of pictures.
1a native 16:9:
1b a-Lens/PJ Scaler:
2a native 16:9:
2b a-Lens/PJ Scaler:
3a native 16:9:
3b a-Lens/PJ Scaler:
These next two series has "hair detail", which I thought looked fine in both.
4a native 16:9:
4b a-Lens/PJ Scaler:
5a native 16:9:
5b a-Lens/PJ Scaler:
Next, I'll go back to the original pictures and blow them up and look at detail to see if any loss.
mtbdudex is offline
post #2 of 26 Old 12-29-2008, 10:23 PM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
Quick zoom, basically same.
What I need is good PQ 16:9 HD material from Blu-Ray source to try this with.
This Cable HD does not have as much detail as I've seen in Blu-ray's.
Full / Native:
Normal / PJ/Scaler
mtbdudex is offline
post #3 of 26 Old 12-30-2008, 07:37 AM
jayrader's Avatar
Nice. I would say that the shots with the scaler / lens have the edge, but definately not enough for me to drop thousands of dollars on the setup for it. Glad I'm still zooming.
jayrader is offline
post #4 of 26 Old 12-30-2008, 07:56 AM
ilsiu's Avatar
I think that the comparison is for those that already have a lens and wondering if they should invest in a slide or leave it in place permanently. The squeezed lens image should look worse than the native image because it's using less pixels (1440x1080 vs 1920x1080) for the same image size. But the screencaps really do seem to show that this difference is really hard (if not impossible) to detect. The 3" skinnier image with the squeezed image is disconcerting, but that may be an issue with the particular projector scaler being used, and not a problem with squeezing in general.
PS - Mike: Nice comparisons, they are very useful.
ilsiu is offline
post #5 of 26 Old 12-30-2008, 09:19 AM
Nasty N8's Avatar
Ya I leave my lens in place all the time and really like the convenience.
Nate
www.NastyPerformance.com
10,000 Watts, custom built speakers, 10' CIH screen = Holy Crap
Nasty N8 is offline
post #6 of 26 Old 12-30-2008, 07:12 PM
Vern Dias's Avatar
But it's NOT the same image size. The pixel density per horizontal inch of the image is the same when the lens is in place regardless of the AR of the image.
An example:
2.40:1 image dimension 5' x 12' 1920 / 12 = ~160 PPI (Pixels per inch)
1.85:1 image dimension 5' x 9.25' 1500 / 9.25 = ~162 PPI (Pixels per inch)
This is why using a lens slide for 1.85 AR sources with a good quality anamorphic lens does not show any advantage at a reasonable viewing distance when the lens is in use.
Vern
Vern Dias is offline
post #7 of 26 Old 12-30-2008, 09:52 PM
CAVX's Avatar
Quoted: 211 Post(s)
Liked: 113
I would like the OP to confirm that the Panamorph lens is indeed aligned correctly as one of the limitiations of a prisms lens is that rotation affects the optical stretch. Cylindrical lenses do not suffer this...
Mark
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #8 of 26 Old 12-31-2008, 08:44 AM
ilsiu's Avatar
An example:
Vern
Maybe I'm misunderstanding the comparison. I believe Mike was looking at a 1.78 image in two ways: with the lens out of the way using the full 1920x1080 panel, and then with the lens in place while scaling the image to use the central 1440x1080 portion of the panel. If the lens has the correct stretch ratio, shouldn't the projected image in either case be the same size?
Why are you comparing 2.40 vs 1.85?
ilsiu is offline
post #9 of 26 Old 12-31-2008, 08:45 AM
ilsiu's Avatar
Mark
I hope it can be corrected, as the distortion can easily be seen even in the screen shots.
ilsiu is offline
post #10 of 26 Old 12-31-2008, 09:23 PM
Vern Dias's Avatar
Yes, exactly. However, if you are using an anamorphic lens you are using it to project 2.40 source on a 2.40 screen.
More importantly your seating distance should be optimized for the 2.40:1 scrren width to avoid seeing individual pixels while also maximizing the resolution that is perceived by your final optical system, your eyes.
This means that the resolving power of your eyes will determine the maximum effective resolution that you can perceive and delivering a higher resolution to the screen for a 1.85:1 source by not using the anamorphic lens will result in no visible increase in resolution to your eys/brain....
Unless, of course you change your viewing distance when you watch 1.85:1 sources. (But then why are you wasting time with a CIH set up if you do that???)
Vern
post #11 of 26 Old 01-01-2009, 05:08 AM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
Happy New years!
I have been gone since Tues @ Family, at mother-inlaws now, Thur 1/1/09, just woke up.
Sorry if not clear this original post.
I'll re-state it. (and put in my 1st post)
I posted this in the 2.35 CIH forum because it affect us with scope screens.
Also related to people with anamorphic lens and the decision to buy/make a slide (manual or automatic) to use the a-lens for scope movies and move it out for non scope movies.
I was curious to the PQ of watching 16:9 material with lens in place with my PJ built in scaler vs "virgin" 16:9 material directly onscreen.
This is NOT an offshoot of the zoom for CIH vs a-lens for CIH debate thread.
(at least not intended to be, nor did I read anything in there that led me to do this)
Mark;
I spent lots of time dialing in the a-lens, I believe it is correctly positioned now. I'll take a screen shot of the PJ "green grid".
If my logic is correct and I do my math correctly:
16:9 material, 1920 wide x 1080 tall, with my Sony PJ in normal mode it should re-map those pixels into the middle image chips 1440 pixel for width and still the 1080 for height. I get Black bars on either side.
Then, the a-lens expands those 1440 pixels back to same size as 1920.
So, that picture should look really close to the "virgin" 16:9 material and I was trying to compare both for image PQ, sharpness, brightness, etc.
I'll do some more screen comparisons.
Like I stated, I wish I had a D-SLR to put it into manual mode for screen brightness comparisons.
If possible, it would be nice if 1 or 2 others with lens slide do same and share results.
Why bother doing this?
For me sorta confirmation of why I made my slide in the first place, that the image PQ should be "best" with the "virgin" image.
mtbdudex is offline
post #12 of 26 Old 01-01-2009, 06:04 AM
Vern Dias's Avatar
Well, the image for 1.85 will be brighter without the lens compared to the 2.40 image with the lens. This will affect your black level calibration, and may require 2 different calibration settings depending on how fussy you are about having it "right".
I see you have a curved screen, which also means that you will not have consistent pincushion compensation unless you always leave the lens in place.
Vern
post #13 of 26 Old 01-01-2009, 12:52 PM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
Vern
Agreed;
With lens out of the light path I do get slight barrel at the bottom of the screen.
I was hoping AussieBob would answer Q I asked in another post http://www.avsforum.com/avs-vb/showt...4#post15388954, but you are also expert:
Q:
My UH380 lens is inline with the top of my screen border (20" below my 8.75' ceiling), when I removed the lens I see barrel at the bottom - I expected that, but at the top it was flat, I did NOT expect that.
For true a-lens placement is it best to be centered height wise as well to "balance" the optics?
I could lower my lens 8" more, but lower than that and I'm worried about peoples head hitting possibly.
The tape in the "virgin" 16:9 image is center height/width of screen.
mtbdudex is offline
post #14 of 26 Old 01-04-2009, 04:12 AM
syncguy's Avatar
Yes. As I see the virgin image is always better for the 16x9 material. Higher resolution, higher brightness and no scaling issues.
I also feel that vw60 normal-mode scaling is not good as anamorphic stretch mode. A good quality A-lens always shines for 2.35:1 material but not the best way to watch 16x9 material, IMO.
syncguy is offline
post #15 of 26 Old 01-14-2009, 12:25 PM
emf
emf's Avatar
Truly interesting study, truly interesing. Thanks for posting comparisons.
emf is offline
post #16 of 26 Old 01-16-2009, 10:44 PM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
Got my Blu-ray DVE HD Basics and spent some time after the kids went to bed.
I reset my PJ to factory settings, then started from scratch following the instructions.
Plus, I went thru the a-lens set-up again, gosh I was having all kinda fun 9pm - midnight while the wife/kids sleep here in minus 10deg f SE Michigan.
About the only time I can do any of this amateur calibration stuff anyways.
Pictures of a-lens "tuned" and some test patterns:
(ceiling paint job looks crappy in these picts, I moved the PJ mount when going from fixed to slide)
Hard to see but image is mostly centered back and front glass:
1.78:1 w/o a-lens, PJ in full mode:
2.35:1 w/a-lens:
w/a-lens and using the Sony anamorphic mode:
Hard to see but my greyscale is dialed in, where the grey bar is just one stop above blending in with the black background.
First time for me to use color filters over my eye to set the color.
The camera saw these morie patterns, my eyes only saw parallel lines, kinda wierd:
We did watch "Meet the Robinsons" on Blu-ray tonight, a so-so movie, but it's 1.78 not 2.35 material so perfect for some comparisions:
w/o a-lens and "full mode" for native 1.78:1
With a-lens and using "normal mode" for end result of 1.78:1 (trying at least): The shift to the left was my cropping the photo.
I don't know if it's worth me "complaining" my Sony PJ internal scaler normal mode does not correctly compress pictures by 1.333 (4/3) factor.
I'll probably live with my PJ as is.
I should say that other Sony VPL 50/60/70/10 owners should confirm their internal PJ scaler.
At this time I satisfied with my internal scaler and have no plans to spend $$$'s for external scaler.
mtbdudex is offline
post #17 of 26 Old 01-17-2009, 07:47 AM
ilsiu's Avatar
IMG]
The moire is from the interaction of the test pattern and camera CCD.
Nice followup. Too bad you can't get the correct squeeze, otherwise it looks to me that you could leave the lens in place all the time. As it is now, I would vote for sliding.
ilsiu is offline
post #18 of 26 Old 01-22-2009, 12:02 AM
emf
emf's Avatar
Sliding Makes Sense
Some movies place subtitles in the bottom black bar, and sliding lets you view 2.35 movies within 16/9 screen area where subtitles are visible.
Movies often offer a choice of French, English, German subtitles. In player Set-Up, the next step needed is an additional choice: Place subtitles wholely in the picture(Yes/No)?
When you choose No, the player uses black bars for subtitles. This choice works well for LCD panels, for plasma screens, and for 16/9 projection screens.
When you choose Yes, the player scoots subtitles upward a line and treats black bars as total black-out and completely devoid of any info, and you might discard those black bars with impunity.
emf is offline
post #19 of 26 Old 01-22-2009, 06:47 AM
pocoloco's Avatar
The image using the lens looks a bit washed out... which is not surprising. I always opt for sliding the lens out of the way for 1.78/1.85 material.
pocoloco is offline
post #20 of 26 Old 01-22-2009, 02:27 PM
Vern Dias's Avatar
Sliding Makes Sense
Not if you have a high quality anamorphic lens and a scaler or HTPC....
Not if you have a high quality anamorphic lens... Also remember that black levels will be different between the lens / no lens scenario.
Vern
post #21 of 26 Old 02-01-2009, 08:48 PM
emf
emf's Avatar
Cinemascope 2.35 +1
You can leave the adapter in front of your lens, if you have some way to effect two things electronically:
1. reduce picture size a bit;
2. raise picture vertically to screen topline.
With reasonable skill and effort, a smaller 2.35 picture with "+1," or the "sub," as in subtitle, fits in the larger screen top to bottom. Since the proportions of the picture remain intact, left and right sides of picture don't match the screen.
To many of us, the above solution, even if you can accomplish it, represents another dissatisfying solution. Must you look up lists of movies to determine when to strip black bars and when to retain bottom bar? Too much fussing.
Tomorrow might we expect 2.35 +1? A major corporation like Sony can produce native 2.35 projectors accompanied by players that can scoot subtitles into the picture area, in which case the "+1" may be redundant.
Today our panels are native 16x9, and it's not unreasonable to think of these panels as 2.35 +2. Studios insert subtitles into bottom bars, because lots of folks like the idea that those bars have useful purpose.
Commercial cinema doesn't deal with bottom bars, but those folks have their own problems and annoyances and we have ours.
emf is offline
post #22 of 26 Old 02-16-2009, 02:55 PM
CRGINC's Avatar
Hi Mike,
Great screen shots. I have a Prismasonic H-FE1500 lens in front of a Sony VPL-VW50 project. Unlike yourself I bought a DVDO VP50 video processor. I think on of the reasons the 1.85:1 width seems 3" narrower is the stretch of the lens is not uniform. I noticed it when watching old 1.33:1 DVDs of TV shows. They looked slightly more square than they should. Somewhere on this site it was mentioned that the stretch was approximately 1.31 in the middle of the screen and 1.35 at the edges for an average of 1.33. This could explain what you are seeing. I really couldn't see any distortion in the picture but I did set the aspect ratio to 1.43:1 and this widened out the picture a bit and made the width look more natural.
Charles
Charles
CRGINC is offline
post #23 of 26 Old 02-16-2009, 04:47 PM
CAVX's Avatar
Quoted: 211 Post(s)
Liked: 113
You want the centre to be 1.33x. One of the limitations is grid distortion where projecting a grid on screen and then measuring both the centre and the far edges will show that the edges are slightly wider. When watching actual video, you may still see this "widening" at the edges during a pan but I think it is far less distracting than not having enought optical stretch in the centre of the image.
Mark Techer
CAVX is offline
post #24 of 26 Old 02-17-2009, 01:22 AM
Aussie Bob's Avatar
This isn't how it works.
The center will always be less than 1.33x, more like 1.30x and the edges will always be more.... wth any A-lens. Some are better than others at equalising the stretch, but all will show this effect.
Aussie Bob is offline
post #25 of 26 Old 02-17-2009, 06:36 PM
CAVX's Avatar
Quoted: 211 Post(s)
Liked: 113
Is there a way to work out the grid disortion AB?
Mark Techer
CAVX is offline
post #26 of 26 Old 02-20-2009, 01:21 AM
emf
emf's Avatar
You've Come a Long Way, Baby!
With the advent of 16/9, 4/3 pictures appear square-ish. To some extent, the wider aspect ratio might contribute optical illusion to make the square-ish picture appear more square-ish.
Another reason for the square-ish appearance is deliberate distortion to make the older aspect ratio appear ridiculously square, as if to say "You've come a long way, baby!" Producers of new products wish to sneer at old products.
An example of new/old was LaserDisc of years ago. Default was digital, and Pioneer deliberately made comparison difficult by reducing analog volume by 6 decibels. After listening to digital tracks, you would switch to analog; and reduced volume made analog seem feeble, anemic, in comparison to digital that seemed vibrant, alive.
emf is offline
Reply 2.35:1 Constant Image Height Chat
