Finally Pics of my Dual-Screen Panny Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 49 Old 01-15-2009, 08:08 AM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
Finally have some pics of my Dual-Screen setup...
Here's the 2.35 Screen (8.66' Wide / 113" Diag.)
Here's the 16:9 Screen (106" Diag.)
Screens up...
Few Signs... (have more now)
And finally the new Big Boy...
And this is a pic of the old Optoma...
mrkalel is offline
post #2 of 49 Old 01-15-2009, 08:09 AM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
And whats great about this setup is the ability to watch a movie like TDK on my 16:9 with no probs...
And a normal 2.35 also....
mrkalel is offline
post #3 of 49 Old 01-15-2009, 08:45 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Nice set-up.
2 Q's:
a) do you need to re-focus when switching between screens? Or are they close enough to be in same "focus zone"?
b) I see you have HDMI and component to the PJ, do you ever use the component?
I ran HDMI and component to my PJ 1 year ago, have been using only the HDMI, and while I just hooked up the component last weekend I did that just to "finish the job" - if you know what I mean.
mtbdudex is offline
post #4 of 49 Old 01-15-2009, 08:58 AM
yellowblanket's Avatar
Yea, i can see the flaw in the dual screen is that you'd have to re-focus the image when u want to watch in dif ratio. The key is that you get those screens as close to each other as posible. I did my dual screen for my basement before, the distance between 2 of my screen is less than 0.5". here is video of it
http://www.youtube.com/watch?v=KEkLXHbvnTE
ps: your speakers shouldn't be so close to the side wall, try move it away the wall a bit to see the differences.
yellowblanket is offline
post #5 of 49 Old 01-15-2009, 09:01 AM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
Nice set-up.
2 Q's:
I'm in the exact postion... I wished when I ran wires I would have ran 2 HDMI's instead of 1 Component & 1 HDMI...
So I did the same thing... just plugged it into 'finish' the look...
I do have nice HDMI switching going on...
Also for the focus thing... my screens are about 1' apart and I do not notice any difference of focus at all...
I am pretty sure that the Panny auto-adjusts focus with the lens shift... everything done with one button press...
mrkalel is offline
post #6 of 49 Old 01-15-2009, 09:04 AM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
I know... I wish I could but aesthetically it wouldnt work... I might try to angle out a little more though....
mrkalel is offline
post #7 of 49 Old 01-15-2009, 10:00 AM
eq_shadimar's Avatar
Quoted: 26 Post(s)
Liked: 49
Nice setup! A second screen is a heck of a lot cheaper then most of the lenses out there. I know it has been discussed here before but it is nice to see it actually being used.
Laters,
Jeff
...wake up to find out that you are the eyes of the world...
My HT Construction Thread - Updated Pictures 3/15/07
My 2.35:1 Discussion Thread - Updated Pictures 3/15/07
XBL = eqshadimar
eq_shadimar is offline
post #8 of 49 Old 01-15-2009, 10:02 AM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
mrkalel is offline
post #9 of 49 Old 01-15-2009, 10:08 AM
conradjohnsonfan's Avatar
Originally Posted by mrkalel View Post
Yup...works for me...
That setup would work for me, except I would have to use tensioned screens. Cannot stand the waves....
conradjohnsonfan is offline
post #10 of 49 Old 01-15-2009, 10:23 AM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
Well so far I have had the 16:9 screen for about 2 years and its going ok...
And I just got the 2.35...
I do keep them in the case whenever I dont use them... so I think that helps....
mrkalel is offline
post #11 of 49 Old 01-15-2009, 03:47 PM
Lonely Raven's Avatar
Quoted: 29 Post(s)
Liked: 32
The position of your speakers makes me cry.
Neat screen setup though.
Lonely Raven is offline
post #12 of 49 Old 01-15-2009, 09:28 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
nice Aquarium!!!
KBMAN is offline
post #13 of 49 Old 01-15-2009, 09:54 PM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 41
I was thinking the same thing. Many rooms can be challenging. I had similar problems (nowhere to put the L&R except next to the walls, hard surfaces, no place to hide the center,...). I ended up going with more directional speakers, rugs , drapes, and panels, etc. Then again, thats to nice a floor you have! BTW, I've been considering the dual screen option as well. I want to add a 10' wide 2.35:1 when I upgrade to a projector with a motorized lens.
My Theater Room JVC RS4910, Panamorph UH480, 148 in. 2.40:1 Dalite HD Pro 1.3, Klipsch THX Ultra II's x 7, Quad JTR Captivator S1 subs
My Previous Non-Dedicated space
RobZ is offline
post #14 of 49 Old 01-16-2009, 06:46 AM
John Ballentine's Avatar
I went w/ low-profie (vs. tower) speakers so they would fit under the screen.
Yes - awesome aquarium
John Ballentine is offline
post #15 of 49 Old 01-16-2009, 08:25 AM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
Thanks for the comments guys...
I really wish my room was more forgiving for speaker placment... but if you can see it kinda has a small area for the screens, then opens up to a larger width...
I did do a audessey setup with my Denon and then did some manual adjustment on top of that ...
To me it sounds ok... but could be better...
BTW Thanks for the aquarium comments... my true hobby just before home theater...
mrkalel is offline
post #16 of 49 Old 01-17-2009, 09:07 AM
Lebronze's Avatar
I was just thinking about doing this yesterday. Now I'm definately going to!
But my 16:9 screen has waves, pretty annoying, so I'm planning to buy a fixed frame 2.35:1
Lebronze is offline
post #17 of 49 Old 01-17-2009, 02:26 PM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
Its soo worth bro... my girl (biggest hurdle to overcome) loves the CinemaScope...
Also I was able to move up my 16:9 screen closer to my seating area with the new Panny, due to the higher resolution and also the more flexible installation options that a LCD has over a DLP...
Essentially my 2.35 is where the 16:9 was, and the 16:9 is about 1 ft closer to the seats...
mrkalel is offline
post #18 of 49 Old 01-17-2009, 02:27 PM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
This even makes even the older screen seem new...
mrkalel is offline
post #19 of 49 Old 01-17-2009, 02:51 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
I was going to do the same thing (2.35 fixed mounted to wall with pull down 1.78 in front of it) but the re-size/re-focus issue stopped me . I bet it works great with the Panny 3000 and it's automated zoom/focus however , very cool !
- Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #20 of 49 Old 01-17-2009, 03:29 PM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
yup... Just a one button press and thats it...
I even saved a 16:9 aspect in the 2.35 screen, so I wont have to pull the true 16:9 screen down for menus and if I'm too lazy.. hehe
mrkalel is offline
post #21 of 49 Old 01-18-2009, 05:08 PM
KO Abear's Avatar
Location: Brusly, Louisiana (just upriver from New Orleans)
try a screen surface like a dalite hi-power on your pulldown....waves not noticeable on most program material
KO Abear is offline
post #22 of 49 Old 02-05-2009, 02:36 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3038 Post(s)
Liked: 2970
Nice set up.
My 2 electric screens are 5" apart and even with that I never have to re-focus. It's so sharp anyway that even if the 5" difference defocuses one screen or the other ever so slightly, you can't tell from the seating distance 12' away!
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #23 of 49 Old 02-05-2009, 02:43 PM
Cam McFarland's Avatar
Love the set-up.....what is the story with the floor...looks like a baskeball court & with the symbol....I LOVE IT!
(what is the symbol?)
If there are no dogs in Heaven, then when I die I want to go where they went.
-Will Rogers
Cam McFarland is offline
post #24 of 49 Old 02-05-2009, 07:55 PM
nice set up and also nice seafishes tank.
butsu is offline
post #25 of 49 Old 02-06-2009, 06:22 AM
VTPete's Avatar
I too like the compass rose. As a cartographer, I appreciate it... what made you put one in the floor?
And, yeah, I also like the aquarium! Are you going to have a party soon?
VTPete is offline
post #26 of 49 Old 02-06-2009, 06:42 AM
I knew it looked familiar....just couldn't place it, lol....
-Will Rogers
post #27 of 49 Old 02-20-2009, 10:08 AM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
Sorry.. been away..
But I would love to have party with guys that actually appreciate these things, as opposed to family and friends that just say "Wow, what a big screen"... lol
As for the compass... It was perfect for my floor cause of the type of wood (Maple, Oak & Walnut), which matched my floor and borders perfectly...
Plus I have always loved the ocean, boats & yachts, and of course reefs and salt water fish... So it fit in the setting quite well...
mrkalel is offline
post #28 of 49 Old 02-20-2009, 10:18 AM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
BTW heres a couple of crappy pics of the tank... (Much MUCH better in person)
sorry I know its off topic...
mrkalel is offline
post #29 of 49 Old 02-25-2009, 04:37 AM
vrmarkii's Avatar
Nice tank. Is it out of the way enough to watch movies while its lit up? I have a 210 with 3 400 watt radiums. I've been wanting to set it back up but the only place I have room for it is the theater.
vrmarkii is offline
post #30 of 49 Old 03-03-2009, 08:44 AM - Thread Starter
mrkalel's Avatar
Quoted: 37 Post(s)
Actually my lights are directly on the tank, so I dont really have any light spillage from the sides..
And unless its a dark movie, I have no problem at all with the lighting...
and in total I have 1200wts on the tank...
mrkalel is offline
Reply 2.35:1 Constant Image Height Chat
