Anamorphic lens shootout? - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 309 Old 04-20-2011, 11:16 PM
dsardenga's Avatar
Ok I may not quite understand and perhaps its beyond the scope (no pun intended) of this setting. A prime lens with FL based on size of sheet and distance plus an anamorphic attachment to reverse the squeeze for 2.35:1 ? 1:33.1 is not anamorphic as a ratio I would not think. I defer the higher UPS for clarity if I misspoke
dsardenga is offline
post #302 of 309 Old 04-21-2011, 04:46 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
That is what a HE lens does. Cinema uses 2x and HT uses 1.33x.
Not sure if I am understanding your question.
1.33:1 is certainly an important part of Constant Image Height projection.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #303 of 309 Old 04-21-2011, 09:27 PM
dsardenga's Avatar
We might be talking two different things. I do not mean to sound gruff. I will look into the lingo used regarding the digital cinema projectors and servers so I can pose the question accurately. Thank you for taking the time.
post #304 of 309 Old 04-21-2011, 09:36 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
All of the D-Cinema projectors I've seen do not use the A-Lens (ISCO 1.25x).
Mark Techer
CAVX is offline
post #305 of 309 Old 04-21-2011, 10:05 PM
GlenC's Avatar
Here is how it works, we have 16:9 format, multiply 16 x 1.33 = 21.28 now divide 21.28 / 9 = 2.364 This is how the 1.33 horizontal stretch works. Another approach 1.78 x 1.33 = 2.367 (16:9 = 1.78:1)
Glen Carter<br />
Home Theater Calibration<br />
GlenC is offline
post #306 of 309 Old 04-22-2011, 12:04 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Mark Techer
CAVX is offline
post #307 of 309 Old 04-23-2011, 02:11 PM
goneten's Avatar
Hi guys,
Just wanted to ask (since I asked some questions earlier concerning lenses) do you think this lens would work on the Optoma HD20 http://www.prismasonic.com/english/d...on_h850m.shtml
I have no idea, just need some advice...
goneten is offline
post #308 of 309 Old 04-23-2011, 08:05 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Originally Posted by goneten View Post
Hi guys,
If the throw is long enough, yes it should be fine.
Mark Techer
CAVX is offline
post #309 of 309 Old 04-24-2011, 03:07 PM
dsardenga's Avatar
I follow. Thank you for the outstanding details. I find myself quite handicapped with a film background as the transition to the 2k DLP's happens at a pretty good click. Operating and even installing this stuff is easy but thats where it ends. I look forward to visiting this forum again.
Reply 2.35:1 Constant Image Height Chat
