Zoom versus lens Screenshots - Page 8 - AVS Forum | Home Theater Discussions And Reviews
Old 10-25-2009, 05:00 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
I found this in the DIY sreen section. Note the blue hue at the top of the image. This is for all intensive purposes, the blue hue is CA, yet no anamorphic lens was used here and certainly no HE lens would produce that if it were. The blue hue is caused by the image capture - IE the lens in the camera used. So what I am saying is that you should NOT automatically assume abberations like this are always caused by an anamorphic lens.
Originally Posted by taylor View Post
Mark Techer
I love my Constant Image Height system!
CAVX is online now
Old 10-26-2009, 03:47 AM
prismasonic's Avatar
Originally Posted by Highjinx View Post
The extra CA is noticiable to me on every edge, the extra CA on the instrument panel under the "bed" stands out like canine gonads on my monitor
The blue I mentioned was from prismasonic's close ups.
I combined the pictures and zoomed it 800%, so that single camera pixels become visible.
Again, I can only see more brightness in picture with lens .. exactly the same number of camera pixels has the CA.
I find less "haloing/CA in the zoom shot as well as a color difference. Look at the vertical disk, it has a blue "fringe" on the A-Lens version, the full perimeter of the instrument has more yellow "fringing"
..and again exactly the same number of camera pixels has the CA (or whatever). Brightness is the only difference.
Originally Posted by CAVX View Post
1. The colour fringing is in both shots, so possibly a mis-convergance error, not the lens.
1.Quite possibly, but it is more evident in the A-Lens shot, obviously indicating the A-Lens is amplifing the problem.
Same thing happens if you choose the brighter projector, or screen with higher gain. Optics neither cannot separate from picture which part to amplify the brightness and which part not. Usually people consider the extra brightness as a desirable issue in a picture.
Yes, VTPetes's H-FE1500R lens introduces a slight amount of CA on the horizontal edges of the screen. However, as can be noticed from comparison pictures, there are much more dominant sources for the CA in VTPete's system than the FE1500R lens.
Anssi Leppanen
PRISMASONIC
www.prismasonic.com
prismasonic is offline
Old 10-27-2009, 01:33 AM
Highjinx's Avatar
Quoted: 325 Post(s)
Liked: 153
I've attached a brightness increased Zoom shot for comparison purposes.....I still see a color shift as well as the other differences previously discussed.
A-Lens:http://www.dtvforum.info/index.php?a...e=post&id=8018
Zoom with increased brightness: http://www.dtvforum.info/index.php?a...e=post&id=8037
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is online now
Old 10-27-2009, 01:53 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
So you had to manipulate the zoomed image to prove your point?
Mark Techer
CAVX is online now
Old 10-27-2009, 02:18 AM
Highjinx's Avatar
Quoted: 325 Post(s)
Liked: 153
Simply increased it's brightness as clearly stated.....the color shift etc is still apparent!
Old 10-27-2009, 07:28 AM
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
You see, that is the problem, once you start post processing pics everything changes. This is absolutely no way to to get a comparison from.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
