Focupix screen: which one? - AVS Forum
post #1 of 3 Old 01-17-2010, 10:15 AM - Thread Starter
junglalien's Avatar
I will be using this screen for 2:35 and 2:40 Blu-rays. I will use my 16:9 screen when watching 1:85. I will be using Zoom on my projector. The price is the same on both of them. The difference must be the frame. I'd rather have which ever one has the better frame. I don't care about the slight difference in viewable screen. I want the aspect ratio to be right. I want minimal black bars top and bottom.
110" 2:35:1 Ultra-WideScreen format , Matte White, Fixed Frame screen (105" Viewable)
110" - Screen Size 110";
Viewable Size 105",96"(Width)x41"(Height);
End-to-end size: 101"(Width)x44"(Height);
http://www.htdepot.com/Focupix_Ultra...35mwlt-105.htm
or
110" 2:35:1 Ultra-WideScreen format , Matte White, Fixed Frame screen (103" Viewable)
Viewable Size 103",95"(Width)x40"(Height);
End-to-end size: 100"(Width)x45"(Height);
http://www.htdepot.com/Focupix_Ultra...f235mw-103.htm
junglalien is offline
post #2 of 3 Old 01-17-2010, 11:00 AM
HopefulFred's Avatar
Quoted: 135 Post(s)
Liked: 194
I gotta say, I can't find a single difference other than the dimensions. I have a feeling that the dimensions are rounded to the nearest inch anyway. Also, I notice that the image they use is the same file for both pages. FF235MW-103-2T.jpg
What differences do you find in the frame?
HopefulFred is offline
post #3 of 3 Old 01-17-2010, 11:02 AM
Quoted: 229 Post(s)
Liked: 580
Just a FYI those measurements are probably ROUNDED and both may be the same actual 2.35 ratio.
Give them a call. I've been to their modest operation, operators are standing by during normal business hours.
BIGmouthinDC is online now
Reply 2.35:1 Constant Image Height Chat
User Tag List
