is zooming the same as Vertical stretch ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-04-2010, 10:22 AM - Thread Starter
jamieuk147's Avatar
Quoted: 69 Post(s)
I am running a anamorphic lens and I dont have the vertical stretch option on my projector. I notice on my DVD player tho I have some zooming options which makes the image taller.
Is this as good as vertical stretch ? or should I be looking at buying a scaler
Jamie
jamieuk147 is offline
post #2 of 12 Old 11-04-2010, 10:42 AM
230-SEAN's Avatar
I think I saw in another thread that you have an Onkyo receiver. I am currently using my Onkyo TX-SR707 to preform my vertical stretch. On my Onkyo remote (model RC-742M, which is labeled underneath the word "Onkyo" on the remote) there is a button under the volume control and it is labeled "Video". When pushed, "Resolution: Auto" appears on the screen (since I allow my receiver to choose the best resolution for me), you then use the up or down buttons of the "Playlist/Category" selector (round button in the middle of the remote with the "Enter" button in the middle of it). Go through the selections ("Game Mode", "Hue", "Saturation", etc.) until you come to the "Zoom" option. Use the left/right buttons of the "Playlist/Category" selector to choose different types of zoom. The correct one is plain old "Zoom", NOT "Wide Zoom" or "Normal" or any of the others, just "Zoom". It does the vertical stretch for you, removing the black bars.
-Sean
230-SEAN is offline
post #3 of 12 Old 11-04-2010, 11:43 AM - Thread Starter
jamieuk147's Avatar
Quoted: 69 Post(s)
Thanks dude!!
post #4 of 12 Old 11-04-2010, 12:24 PM
230-SEAN's Avatar
No prob, let me know if that worked for you as I'm not sure if all Onkyo receivers are capable.
-Sean
230-SEAN is offline
post #5 of 12 Old 11-04-2010, 01:18 PM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
Here's a list of the other threads/questions for reference in trying to help
How Do I know which lens will work with my 8500UB:
http://www.avsforum.com/avs-vb/showt...305&highlight=
I have an 8500UB and want to add an anamorphic lens:
http://www.avsforum.com/avs-vb/showthread.php?t=1285943
Ok so you havent got powered zoom, what other hardware options are there?
http://www.avsforum.com/avs-vb/showt...238&highlight=
Must mount projector with lens centre to my 2.35.1 screen so I can zoom 2 fill screen
http://www.avsforum.com/avs-vb/showt...636&highlight=
I have maxed zoomed to fill my 2.35.1 screen and the image seems soft is this normal
http://www.avsforum.com/avs-vb/showt...734&highlight=
2.35.1 image looks a bit soft and seeing alot of pixels
http://www.avsforum.com/avs-vb/showt...268&highlight=
I dont have powered zoom is it possible for a dvd player to do it ?
http://www.avsforum.com/avs-vb/showt...002&highlight=
I've got a few questions before I install my anamorphic lens
http://www.avsforum.com/avs-vb/showthread.php?t=1287481
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
post #6 of 12 Old 11-04-2010, 06:16 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Jamie
I think there is some merit for scaling at the source. I did some testing using a PC running HD and whilst the difference between scaling at the source Vs running letterbox and Vertical Stretching at the projector was small (if at all noticeable), I felt it looked slightly better when done at the source. So I think this is where players like OPPO have a clear advantage over others. Of course a good Video Processor should deliver the same (or even better) results.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #7 of 12 Old 11-07-2010, 10:24 AM
Jason Turk's Avatar
Jamie
If you are using an anamorphic lens you have to stretch...no getting around it. Zooming is done for those who don't use a lens, but want a native 2.35:1 screen.
Jason Turk is offline
post #8 of 12 Old 11-08-2010, 08:48 PM
greg_mitch's Avatar
Something wrong with my computer? None of these links work for me. I can look them up...just wondering.
greg_mitch is offline
post #9 of 12 Old 11-09-2010, 12:58 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Here is an example of Letter Boxing as it appears on the BD/DVD.
And then the same image after Vertical Stretch has been applied.
Hope that helps.
Mark Techer
CAVX is offline
post #10 of 12 Old 11-09-2010, 06:52 AM
greg_mitch's Avatar
post #11 of 12 Old 11-09-2010, 10:21 AM
230-SEAN's Avatar
Yes...that looks bad. IMHO.
Its supposed to look distorted, then the A-lens is placed in the light path and stretches it out horizontally, restoring the proper shape.
-Sean
230-SEAN is offline
post #12 of 12 Old 11-09-2010, 04:48 PM
greg_mitch's Avatar
-Sean
Yes. Sorry I think I was mixing some threads I had open at the same time. I thought this was referring to using stretch in lieu of an A-lens.
I understand how the A-lens works.
Thanks for clarifying.
Reply 2.35:1 Constant Image Height Chat
