Setup for 2.35:1 for JVC DLA-RS40 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 51 Old 01-31-2011, 08:37 AM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
Originally Posted by stanger89 View Post
You can do it with a VC lens, it's just very impractical to remove the lens for non-scope content.
Precisely why is it impractical to remove the lens for Non-Scope content?
Could you not just have a sled for the lens and move it out of the way and change the scaling mode on the projector when viewing Non-Scope material?
...Glenn
Glenn Baumann is offline
post #32 of 51 Old 01-31-2011, 09:42 AM
stanger89's Avatar
Quoted: 3669 Post(s)
Liked: 2036
Because the image would "expand" (uncompress) off the top/bottom of the screen thus requiring you to zoom (if possible) to return the image to within the screen bounds.
stanger89 is offline
post #33 of 51 Old 02-02-2011, 09:10 PM
phansson's Avatar
Quoted: 57 Post(s)
I just installed my new RS40 with an ISCO II lens. They seem to work VERY WELL together. I have a 2.37 128" screen and my projector is mounted at about 19'. I haven't really been able to test the setup much, but so far I am very pleased. I also have the Oppo 93, but haven't been able to test the "anamorphic zoom" on it with 3D.
phansson is offline
post #34 of 51 Old 02-02-2011, 09:14 PM
230-SEAN's Avatar
When you do get a chance to test the zoom on it with 3d and 2d for that matter, please let us know your impressions!
-Sean
230-SEAN is offline
post #35 of 51 Old 02-02-2011, 09:19 PM
phansson's Avatar
Quoted: 57 Post(s)
-Sean
With the Oppo or the RS40?
Anamorphic zoom on the RS40 looks great. I was concerned that the "inset" of the lens might be a problem, but I was able to get the lens close enough to the cabinet. I leave my lens in place all the time. With an ISCO II, sleds do not work.
I just haven't tried to "zoom" a 3D blu ray with the Oppo yet. Like I stated in the other thread, I have had issues passing the signal correctly.
phansson is offline
post #36 of 51 Old 02-03-2011, 05:38 PM
coolrda's Avatar
Quoted: 1079 Post(s)
Liked: 962
Actually the correct term is Vertical Stretch as zoom enlarges equally in all directions. What 2.35 movies do you have?
coolrda is online now
post #37 of 51 Old 02-26-2011, 09:52 AM
phansson's Avatar
Quoted: 57 Post(s)
Ok, so I finally received some glasses and an emitter. So I am ready for 3D.
My setup is
Oppo 93
RS40
ISCO II (left in place all the time)
What are my options for 3D 1.78/1.85 content? What are my options for 3D 2.35 content? I haven't been able to get the 93 to do "vertical stretch" with 3D yet. Has anyone else had success?
phansson is offline
post #38 of 51 Old 02-27-2011, 11:40 PM
lmfmis's Avatar
Just viewed the Monsters vs. Aliens 3D Blu-ray which is 1:2,35 ratio.
By the way - good 3D.
Also have Oppo, prismasonic lens, but just ended up zooming out the picture as far as the JVC X3 (same as rs40) zoom would go. Oppo could not stretch the picture..
Luckily JVC has decent light output so that this could be done.
Now I only need "lens shift presets" for the X3...
lmfmis is offline
post #39 of 51 Old 02-28-2011, 10:36 AM
Trogdor2010's Avatar
My setup is
Oppo 93
RS40
Unfortunately, the only option I could think of to get you JVC to scale 3D content is with a lumagen scaler. Like this one, and worse it ain't cheap.
http://shop.avscience.com/Lumagen-Ra...-3D_p_118.html
Trogdor2010 is offline
post #40 of 51 Old 02-28-2011, 02:43 PM
Kelvin1965S's Avatar
Quoted: 288 Post(s)
Liked: 189
You have my 'future' setup there: I have an Isco II, HD350 and the Opp 93 player (as of today ). I plan to get an X3 at some point, though probably used once the next range come out.
I have one of these already and it's amazing what it can do to the HD350's picture (including better vertical stretch than the projector does at least for 2D anyway ). As the RS40 also doesn't have a CMS (although maybe more accurate colour gamut to start with) it would be worth it for that as well IMHO.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #41 of 51 Old 02-28-2011, 06:47 PM
phansson's Avatar
Quoted: 57 Post(s)
Well, after some trial and error, emails to Oppo tech support, I got the zoom to work with my setup. I was told by oppo that it will stretch any 3D disc as long as it wasn't authored with JAVA. He also stated that there are NO 3D discs authored in JAVA because the PS3 will not play them in 3D. So that might be a good thing. He also stated that this will be fixed in a future upgrade (where any disc can be zoomed).
So this appears to be an option for anyone using an anamorphic lens in place with the RS40.
phansson is offline
post #42 of 51 Old 03-01-2011, 12:31 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Careful, as there are some discs Java enhanced in 3D (Res Evil 2?) and won't VS in the OPPO.
How does one HS with the OPPO?
Mark Techer
I love my Constant Image Height system!
CAVX is online now
post #43 of 51 Old 03-01-2011, 06:21 AM
phansson's Avatar
Quoted: 57 Post(s)
Hey CAVX,
Is Resident Evil 2 3D java? I don't have that disc to confirm and don't plan on picking it up. Oppo stated that "most" 3D discs are not authored in JAVA, sorry I misread the email, but plan on being able to perform zoom on JAVA discs with a firmware update. This is the email I received from Oppo.
If the disc uses BD-JAVA, then zooming will not work. This will be corrected in a future firmware release when we offload the zooming to the Marvell QDEO solution.
Best Regards,
What does HS stand for?
phansson is offline
post #44 of 51 Old 03-01-2011, 08:00 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
HS= Horizontal Squeeze. To restore the image to 16:9 while leaving the lens in place.
oman321 is offline
post #45 of 51 Old 03-01-2011, 08:15 AM
phansson's Avatar
Quoted: 57 Post(s)
Thank you, I am an idiot. No the Oppo doesn't have a horizontal squeeze.
phansson is offline
post #46 of 51 Old 08-31-2012, 01:31 PM
COACH2369's Avatar
Quoted: 953 Post(s)
Liked: 772
Sorry for bringing back an old thread, but I have a question that I can't get answered.
I have a RS-40 and I am currently using a 16x9 screen. Do I have to purchase an anamorphic lens in order to use a 2:35 screen correctly? I am moving in a month and would like to go with a 2:35 screen without having to replace the projector. A few folks have recommended I pick up a Lumagen Radiance Mini-3D because it has the ability to do this...
Any help would be much appreciated..
COACH2369 is offline
post #47 of 51 Old 08-31-2012, 02:51 PM
Mike Garrett's Avatar
Quoted: 7057 Post(s)
Liked: 4762
No you do not have to have an A-lens to use a scope screen with an RS40. You can do it without an A-lens and without a Lumagen. You would have to use the power zoom and power lens shift to adjust the image to fit, whenever changing from 16:9 aspect ratio material to scope material. You could also do it with a Lumagen. Letting the Lumagen shrink the image rather than using the projector. An A-lens with out a Lumagen will also do what you are asking. With just an A-lens, you could slide the lens out of the way when projecting 16:9 and use the A-lens for scope content. You can even leave the lens in place and shrink the image for 16:9 content with the projector.
mjgarrett100@gmail.com
Mike Garrett is offline
post #48 of 51 Old 08-31-2012, 02:55 PM
COACH2369's Avatar
Quoted: 953 Post(s)
Liked: 772
Thank you for the information.
Since the projector does not have the Lens Memory feature, would it have to be manual change each time I switched between the two formats? I am okay with having black bars on the left and right of my screen when watching 16x9 material. Am I correct in thinking that is what will happen?
Thanks..
post #49 of 51 Old 08-31-2012, 06:37 PM
mbw23air's Avatar
Quoted: 198 Post(s)
Liked: 169
Thanks..
Hi,
I have both a fixed wall 2.35 and a manual pull down 1.78 screen i use with the RS40. I use to have to zoom in/out and refocus with projector when switching between 1.78 and 2.35 content. This worked well but I had always wanted to try an anamorphic lens and wanted a little bit bigger 2.35 screen. I already had a Lumagen XD video processor so I got the lens a week and a half ago and now my 2.35 image is brighter and I don't have to move lens when watching 1.78 content. I haven't bought bigger 2.35 screen yet as I plan on doing so within the next month. So both of the methods work with very good results. I think it depends on how big a screen you want and if your room will accommodate it with adequate brightness. My room is not as deep as I would like and I crave a bigger and brighter picture. When I first got the 2.35 screen and used the zoom method to fill it I was hooked as I would never go back to a 1.78 screen.
Oh, to answer your question, yes on a 2.35 screen you will have black bars on left and right side of screen with 1.78/1.85 content. I plan on using black velvet curtains to mask off when I go to just a 2.35 screen only setup.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, 2 Behringer B1200D Mid Bass Modules, Buttkicker transducer, Oppo BDP-93 blu-ray player
mbw23air is online now
post #50 of 51 Old 08-31-2012, 07:38 PM
COACH2369's Avatar
Quoted: 953 Post(s)
Liked: 772
Originally Posted by mbw23air View Post
Hi,
Mike
Mike,
Thank you for chiming in on my situation. I would love to be able to swing a lens right away, but with all the other costs I have with the room it isn't in the budget right now. I think I will add the Lumagen for right now and go from there. Since I haven't figured out where everything is going in the room yet, I don't know what size screen I will be getting. I was hoping to use a fixed 120" 2:35 screen, but that could change.
Like you, I am sure I will be wow'd so much by the 2:35 screen.....the zoom won't bother me.
post #51 of 51 Old 08-31-2012, 08:01 PM
mbw23air's Avatar
Quoted: 198 Post(s)
Liked: 169
Mike,
120" sounds good. I am leaning toward a 115" wide x 49" tall 125" diagonal 2.35 high power screen as I like a bright image. With zooming the black levels are so good on the RS40 the black bars will be completely non-existent.
Yeah, I only bought the lens as I wanted to try a quality lens and found a great price on a "C" stock lens. For what I paid I am definitely keeping the lens but zooming produced great results as well. The Lumagen is great for all that it does as well. I will say I have been as content with my RS40(lamp issues aside) as any projector i have ever had but for some reason I always crave for more. Hopefully my video addiction will end one day. wink.gif
Mike
Reply 2.35:1 Constant Image Height Chat
