Panasonic AE4000U Zoom CIH Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-08-2011, 08:48 AM - Thread Starter
nateziemann's Avatar
I have looked high and low for some instructions to setup CIH for 2.35:1 using Zoom .with the AE4000 ... no luck. If anyone can point me in the right direction or describe what you've done that would be great.
My primary questions are around what to expect when zooming to fit the 2.35:1 screen. First I centered for 16:9 and saved that to memory. Then zoomed out. The image does not stay centered, so I presume that I need to adjust the vertical shift. Can someone help me fill in the blanks on how to set this up.
Thanks !!
nateziemann is offline
post #2 of 6 Old 05-08-2011, 09:00 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 191
Thanks !!
Make sure lens height is within the screen area. It cant be below or above the border of the screen.
Also post over here: AE4000 thread
NicksHitachi is offline
post #3 of 6 Old 05-08-2011, 12:49 PM - Thread Starter
Yep, I have the projector on a tabletop at a height within the screen area. When I zoomed to fit the 2.35:1 screen it didn't stay centered vertically and had to compensate a lot using the v-position. Is that what I should expect?
post #4 of 6 Old 05-08-2011, 04:42 PM
CAVX's Avatar
Quoted: 220 Post(s)
Liked: 115
Thanks !!
All HT projectors optics are biased to either top or bottom pending the set up. So when you zoom you will need vertical lens shift.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #5 of 6 Old 05-08-2011, 08:23 PM
ilsiu's Avatar
That's correct. Unless your projector is aligned at the exact center of the screen, any zoom will always create vertical offset. You can use the v-position control (digital shift) to re-center, then store as one of your six available memory positions. The lens memory will store the focus, zoom, and v-positions so all of those will be adjusted automatically when you call on that memory.
ilsiu is offline
post #6 of 6 Old 05-08-2011, 09:48 PM
kklarson's Avatar
See this post for instructions on using the lens shift dials to setup your projector for 1.85:1 and 2.35:1 memory positions.
kklarson is offline
Reply 2.35:1 Constant Image Height Chat
