Panamorph U480 - Shifting image left of center? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 05-23-2011, 08:55 PM - Thread Starter
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Greetings all,
I blame this forum for *forcing* me into a CIH setup for my theater. I've recently finished it, and am still tweaking the PJ and the lens.
Setup: JVC RS50, Panamorph U480, Carada Masquerade 136" 2.35 mask/screen. Projector is ceiling mounted, center of the room/screen, using the Chief / Panamorph plate and motorized slide.
So with the PJ in 16x9, image centered, everything is fine, no spillover onto the left/right masks at all. Bring the A-lens into place, and the image border is shifted to the left, spilling quite a bit of the image onto the left mask, while the right edge is now short of the edge.
I've adjusted the lens mount to angle the lens as much as it allows, still not enough to bring it into place.
Any suggestions? The lens is mounted with the thick side on the right side - instructions indicated it didn't matter, but I wonder if this could be the cause?
Jeff
jautor is offline
post #2 of 23 Old 05-24-2011, 01:43 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
I assume you mean rotation here?
It should not matter.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #3 of 23 Old 05-24-2011, 08:50 AM - Thread Starter
jautor's Avatar
Liked: 777
Yes, rotation of the Panamorph ATH sled, I've pushed it to the furthest point the adjustable screw locations on the mounting plate will allow...
Jeff
jautor is offline
post #4 of 23 Old 05-24-2011, 12:49 PM
Josh Z's Avatar
Quoted: 2137 Post(s)
Liked: 1434
You say that your image is centered, but is your projector really aiming straight on at the screen in a perfect 90-degree angle? If the angle is off just a little bit, that will be emphasized when you put the lens in place.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #5 of 23 Old 05-24-2011, 01:01 PM - Thread Starter
jautor's Avatar
Liked: 777
No, I'm not sure... I have 'touched' the JVC's horizontal shift, and now I don't know where it's position is relative to 'center'. The PJ doesn't show me how much shift I'm using (at least, I haven't found it yet), and as you suggest, I figured that may impact it.
I assume the best/only way to align the projector is to ensure that all horz. shift is out of the equation and then see where you're at?
And I guess the only way to find the zero/center position for the horz. shift is to take it to extreme L/R and figure the middle - I'm not seeing a reset to defaults or other setting in the PJ (maybe the service menu?).
Jeff
jautor is offline
post #6 of 23 Old 05-26-2011, 04:41 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Using lens shift should not matter. What matters is that the beam is centered. If the image is them not aligned, then rotating (yaw) of the lens should allow you equalize the image. I am surprised by your comment on reaching the full limits of the bracket.
Mark Techer
CAVX is offline
post #7 of 23 Old 05-26-2011, 10:22 AM - Thread Starter
jautor's Avatar
Liked: 777
Well, I did some adjustments last night, figuring out where the 'zero' spot was for the horizontal shift on the JVC, and aligned that to the center of the 16x9 screen. Now the image with the a-lens in place is much closer, but still shifted (now slightly) to the left.
But yes, the a-lens sled is still at the limit yaw adjustment on the Panamorph/Chief bracket. I would have expected it to be dead center, too...
Jeff
jautor is offline
post #8 of 23 Old 05-26-2011, 05:35 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Jeff
Would you not be better keeping the sled straight and yawing the lens?
Mark Techer
CAVX is offline
post #9 of 23 Old 05-26-2011, 10:28 PM - Thread Starter
jautor's Avatar
Liked: 777
Did I miss an adjustment point? I don't recall a yaw adjustment on the U480 lens or its mounting piece on the motorized sled... If I did, well, no telling where that's adjusted to!
I'll have to take a look.
Jeff
jautor is offline
post #10 of 23 Old 05-27-2011, 03:42 PM
knmlee's Avatar
Hi Jeff,
I have a similar setup with the same lens & mount on the X3 projector. I also get a slight shift to the left with the lens in place. I ended up zooming the image out to get full coverage and then using the custom masking feature on the projector to trim the extra image on the right side. There is a photo of my setup in the link below.
Good luck.
knmlee is offline
post #11 of 23 Old 05-27-2011, 08:17 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Jeff
I thought the stand of the UH440 had almost 30 degrees of yaw. I could be mistaken.
Mark Techer
CAVX is offline
post #12 of 23 Old 05-29-2011, 03:41 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
No yaw at all on the P's mount AFAIK. Bolts on squarely with 4 screws I think. FOr yaw, I think they had you move the entire slide and you don't get much. Mine has about +/- 20 degree adjustability in it, rotation at the lens where it should be, for just such reasons as these. You can't properly adjust a lens if you don't have yaw adjustment.
But, as they have a lot of these installed and this isn't a common complaint, I'd say something is wrong somewhere.
GetGray is offline
post #13 of 23 Old 05-30-2011, 12:10 PM - Thread Starter
jautor's Avatar
Liked: 777
Well, it is a new and different Panamorph/Chief plate specifically for the JVC RS-40/50/60...
Jeff
jautor is offline
post #14 of 23 Old 05-31-2011, 06:23 AM
HogPilot's Avatar
Liked: 25
I owned a UH380 and UH440, and both shifted the image a couple inches to the left. IIRC, this is normal due to the way the optics work. It's been a while so I'm relying on memory for this, but I don't think there's any way of preventing it. I left my lens in the light path and used a VP to change ARs anyways, so it was never really an issue for me.
There are 10 types of people: those who understand binary, and those who don't.
HogPilot is offline
post #15 of 23 Old 06-01-2011, 07:47 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
At the HEMI home theatre meet held 5/14 at my home one of the guys who attended, Axel (his member name here also), has a U480 and stated same thing to me.
Since I have the earlier version of that, the U380 on manual slide, we slid it in/out of the light path a few times and I don't remember having this issue.
fwiw, in my screen/PJ set-up I was very meticilous about having the center of screen/PJ line up from LH wall as datum.
My a-lens is mounted seperately of the PJ, so possible I adjusted that to not be an issue 3 years ago via rotating it slightly on its own mtg pipe....
mtbdudex is offline
post #16 of 23 Old 06-19-2013, 08:21 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
I guess I should have searched a bit more before starting a new thread. I'm having the same issue in my setup. I had an older Prismasonic lens before and did not have this problem.
dropzone7 is offline
post #17 of 23 Old 06-19-2013, 09:08 AM - Thread Starter
jautor's Avatar
Liked: 777
And I guess I should have come back to report how I resolved it...
The lens mount (the U-shaped bracket) for the sled has a bit of play - I didn't realize that when I assembled it, so didn't pay attention to any alignment. Centering that bracket correctly and then using the yaw adjustment on the sled itself got the image back to dead center. No more shift.
On a related note, I also flipped the lens over, so the weight balance of that glass doesn't tilt the projector. I don't have any additional front support wires/chains, just the pole, and with the lens installed "the other way", the weight shift made the mount flex. Speaking with someone (I think at Panamorph) about that, they suggested that the RPA mount, with all it's additional adjustment points, is more sensitive to weight shifts (due to spacers, etc.).
Hope that helps,
Jeff
jautor is offline
post #18 of 23 Old 06-19-2013, 09:23 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
Hope that helps,
Jeff
Thanks for posting back. I did move the mounting bracket side to side at it's limits and while it did help a bit I'm still off the edges. I haven't tried flipping the lens over but I do see it shown the reverse of what I have in the instructions. If I turn it the other way the label will be upside down I guess. I may just pull the whole thing down and see what centering everything to the screen gets me. Maybe if I didnt' have so much horizontal lens shift then the regular sled yaw adjustments would do the trick.
post #19 of 23 Old 06-19-2013, 09:58 AM
John Schuermann's Avatar
Quoted: 813 Post(s)
Liked: 781
I've posted this in several other threads, but since this seems to come up quite a bit I will post it again here. The adjustments are covered in the manual, but I think this video illustrates how to correct image shift much more effectively. Simply watch the Installation Video:
http://www.panamorph.com/8-support/videos
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is online now
post #20 of 23 Old 06-19-2013, 02:47 PM - Thread Starter
jautor's Avatar
Liked: 777
The label (at least on mine) is actually a small plate held in place with two small screws - it comes off and can be flipped over to avoid that nasty, nasty side effect. biggrin.gif
jautor is offline
post #21 of 23 Old 02-26-2016, 08:59 AM
gboshell's Avatar
Liked: 0
Does anyone have dimensions for the distance between the JVC and the UH 480? I do not have the mounting plate and can not seem to reach a good placement that does not clip the image a little or require changing the zoom.
gboshell is offline
post #22 of 23 Old 02-26-2016, 12:24 PM - Thread Starter
jautor's Avatar
Liked: 777
I don't have a measurement value for you, but the 480 just clears the front of the PJ in my setup with the official bracket. So very close to the front...
jautor is offline
post #23 of 23 Old 02-28-2016, 09:39 AM
stanger89's Avatar
Quoted: 2632 Post(s)
Liked: 1353
You pretty much want it as close as you can get it. Some more details about your setup might help. If you're clipping, the image, your projector/lens is too close to the screen (throw too short)
stanger89 is offline
Reply 2.35:1 Constant Image Height Chat
