2.35 movies vs. 2.40 movies- is there an actual difference, even if it is small? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 09-15-2011, 01:25 AM - Thread Starter
iansilv's Avatar
I am wondering if these two AR labels are just tossed around and mean the same thing in reality- or if movies that are marked as being these aspect ratios are in fact different. Example- Batman Begins is 2.35 and Casino Royale is 2.40.
Anyone with a CIH setup have some input on how much difference these two ARs have on their screen and how they deal with that difference?
iansilv is offline
post #2 of 20 Old 09-15-2011, 05:53 AM
coolrda's Avatar
Quoted: 852 Post(s)
Liked: 614
They are different as the 2.40 movies have a small sliver. But were talking about a quarter inch on an 11ft wide screen. Which is about 1-2 zoom clicks.
coolrda is online now
post #3 of 20 Old 09-15-2011, 05:55 AM
stanger89's Avatar
Quoted: 2626 Post(s)
Liked: 1351
Yes they are different and yes they are tossed around to mean the same thing. You really can't trust the number on the box to be right to that degree of precision.
I personally don't worry about it, I think it amounts to about a half inch over a 100" screen.
stanger89 is online now
post #4 of 20 Old 09-17-2011, 10:22 PM
pokekevin's Avatar
Liked: 102
I remember reading somewhere in this section where 2.35 and 2.4 are thrown around as the same. Not sure though which one is "slightly bigger"
pokekevin is offline
post #5 of 20 Old 09-17-2011, 10:32 PM
230-SEAN's Avatar
Depends on what you mean by "slightly bigger". 2.4 on a 16:9 native PJ has bigger black bars top/bottom than 2.35, however that means that the 2.4 image is smaller than the 2.35 image on a native 16:9 PJ. Now, a 2.4:1 AR screen would be wider than a 2.35:1 AR screen, therefor one could say 2.4 is bigger than 2.35, just depends on how you are watching it.
-Sean
230-SEAN is offline
post #6 of 20 Old 09-17-2011, 10:50 PM
pokekevin's Avatar
Liked: 102
-Sean
You have just made the most confusing thing to me easy to understand Thanks!
-Kevin
post #7 of 20 Old 09-17-2011, 11:02 PM
230-SEAN's Avatar
-Kevin
No problem, glad I could help!
-Sean
230-SEAN is offline
post #8 of 20 Old 09-18-2011, 04:07 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
The difference is less than 2%, so I would not lose any sleep over it.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #9 of 20 Old 09-18-2011, 08:58 AM
ABCTV99's Avatar
2.35 doesn't really exist in modern filmmaking. It's a misnomer held over from the intermediate days of anamorphic photography when the aperture size was 2.35 and there were issues with the frame splices being visible on projection. People still casually refer to it as Cinemascope or 2.35, when in really modern films are neither (Cinemascope is somewhat of an outdated term, the original 'scope was spec'd at 2.66:1 but ended up with the soundtrack being more 2.55:1, but is still casually used to describe modern 2.39 films). The SMPTE standard for both anamorprhic (Batman Begins) and flat Super 35 (Casino Royale) or digital crops (The Social Network) is today 2.39:1 or 2048x854 resolution at 2K.
An anamorphic film should be presented as 2.39 unless the top and bottom are slightly cropped off for some reason. It gets trickier with flat films because they can technically be cropped to anything (though the release prints are still blown-up and anamorphised for theatrical projection, thereby making them 2.39). Since almost all Hollywood movies these days go through a DI process it's almost inexcusable for there to be discrepancies in aspect ratios for home video deliverables considering they are often struck from the 2K or 4K digital master and projection isn't an issue. There will be aspect ratio discrepancies with older films though.
ABCTV99 is offline
post #10 of 20 Old 09-23-2011, 11:17 AM
Josh Z's Avatar
Quoted: 2137 Post(s)
Liked: 1433
It's a total crap-shoot as to whether 'scope films are transferred at 2.35:1 or 2.39:1. It depends entirely on how the telecine used for the film-to-video transfer is calibrated. The numbers on the packaging are rarely reliable.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #11 of 20 Old 09-23-2011, 03:55 PM
Erik Garci's Avatar
It might not even be 2.35 or 2.39. It could be 2.33, 2.38, 2.41 or any other number in that ballpark.
Erik Garci is offline
post #12 of 20 Old 09-23-2011, 05:45 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
I just ordered a custom carada 115" diag. 2.40 screen. When I talked to Rex at Carada, he did the math and it was only a 1/8th inch size difference. I don't really care about zooming into the black velvet border too much, and like the look of 2.40:1 screens, regardless of the little difference. YMMV
KBMAN is offline
post #13 of 20 Old 09-23-2011, 08:52 PM
ABCTV99's Avatar
Though nowadays this SHOULD not be the case on newer films as the DI process should standardize this. Since people today work mostly in terms of resolution (2048x854 for example) it would be heinously irresponsible and lazy for an error like this to get by a Post-Production supervisor or Di Producer. The markings on the case, however are another story altogether.
Since most 'scope films these days are 3-perf Super 35 crops or digital crops, this is such a common process that it shouldn't be effed-up with any great frequency. Key word: shouldn't. This kinda mistake a post house or dub house might make (assuming the vernacular 2.35 to be correct) but a DI house (who actually handles the footage and dailies) should not.
ABCTV99 is offline
post #14 of 20 Old 09-26-2011, 01:14 PM
Josh Z's Avatar
Liked: 1433
You'd think that would be the case. However, I just watched X-Men: First Class, which certainly had a DI, and the Blu-ray is 2.35:1, not 2.40:1.
There's been some speculation that some studios merely crop 2k DIs to Blu-ray's 1920x1080 rather than scale them, in order to maintain 1:1 pixel mapping for the majority of the picture. (Fox's Alien Blu-ray, for example, has very obvious cropping on all four sides of the screen in comparison to earlier DVD transfers.) If that's the case, the person doing the cropping would be the one to decide whether the image is 2.35:1 or 2.40:1.
Josh Z
Josh Z is offline
post #15 of 20 Old 09-26-2011, 04:17 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Just to clarify. A 2K transfer is 2048 x 1080? So a 2.35:1 film letter boxed in this format is 2048 x 871. Are you suggesting that they have shifted the mats in to 817 and then cropped the sides to preserve the AR?
Mark Techer
CAVX is offline
post #16 of 20 Old 09-26-2011, 06:27 PM
R Harkness's Avatar
Quoted: 1927 Post(s)
Liked: 1626
BTW, on the subject of those teeny black bars from slightly wider than 2:35:1 ARs, I find it beneficial to get rid of even those tiny black bars. However, this is not something I'd ever advocate as "important" for other people as I can completely understand someone not being bothered by such small black bars.
R Harkness is online now
post #17 of 20 Old 09-27-2011, 10:31 AM
Josh Z's Avatar
Liked: 1433
According to Wikipedia, the 2k scanning resolution for 35mm film is 2048x1556. But otherwise, yes, that's the theory. The studio crops 64 pixels off each the left and right sides to get to 1920, and then applies further matting to the image top and bottom to maintain the original aspect ratio. The picture has the same aspect ratio, but loses image from all four sides.
I don't know that this has been proven anywhere, but comparisons of the Alien Blu-ray and DVD appear to back it up.
Josh Z
Josh Z is offline
post #18 of 20 Old 09-27-2011, 01:42 PM
ABCTV99's Avatar
2048x1556 is full aperture 2k resolution. For a 2.39 crop it would be 2048x854 resolution at 2K. In the case of anamorphic photography since the entire negative is used the resolution will be the full 2048x1556 just stretched out to 2.39. In theory anamorphic should have a decided advantage in terms of picture quality, but on a home video the differences would be almost completely negated by downscaling everything to HD resolution. In fact in many cases on Blu-Ray, ironically, anamorphic photography, for a variety of reasons, can appear less-sharp than its Super 35 (and certainly Digital) counterparts, despite the resolution advantage up front.
Just compare Inception or Training Day (anamorphic) to No Country For Old Men or Kingdom of Heaven (Super 35). Or maybe a better comparison might be two digital films Killers or The Girlfriend Experience (anamorphic) and Knowing (RED at 2k). (I would mention The Social Network but it was acquired at 4k - not sure what the DI was done at.)
ABCTV99 is offline
post #19 of 20 Old 09-27-2011, 01:48 PM
Josh Z's Avatar
Liked: 1433
King of getting off the subject here. In any case, there's still no standard as to whether 'scope movies wind up on video at 2.35:1 or 2.40:1, regardless of whether they were shot on film, used a DI, or were photographed digitally. It's a total crap-shoot what you'll get.
Josh Z
Josh Z is offline
post #20 of 20 Old 09-29-2011, 09:15 PM
coolrda's Avatar
Quoted: 852 Post(s)
Liked: 614
I prefer to zoomed a little so 2.40 has no bars. Rezoomed for with TransformersDOTM and the presentation made a difference. It bothered me with this movie though it hasn't in the past. I have about an inch and a half off both sides which is not offensive at all.
Reply 2.35:1 Constant Image Height Chat
