Zoom with 4K ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 11-14-2011, 05:54 AM - Thread Starter
Art Sonneborn's Avatar
Quoted: 348 Post(s)
Liked: 471
I'm considering a large 4K projector for my theater. Till now pixel visbility has been one of the primary reasons to use an anamorphic lens over zooming at least in my case. Additionally, better use of light from the projector is a factor but these seem to be moot with a projector that ouputs 3500 lumens and has 4K resolution.
Any thoughts would be appreciated.
Art
Art Sonneborn is online now
post #2 of 40 Old 11-14-2011, 09:24 AM
MovieSwede's Avatar
Quoted: 124 Post(s)
Liked: 87
While more pixels can help in this regard, its also depends on the tech that the projector uses to create its pixels. The pixelgrid visibility varied very much between different 1080P projectors. So its not just a resolution issue.
On the other hand, if you already own a anamorphic lens, why not use it on a 4K projector?
MovieSwede is offline
post #3 of 40 Old 11-14-2011, 03:06 PM
coolrda's Avatar
Quoted: 980 Post(s)
Liked: 712
I'm using mine when I move to 4K. No masking needed for 2.35, more light output, 33 percent more pixel density, lightening quick aspect changes, etc. I sit 2-2.4x PH and still clearly see screen door on bright picture elements even at +3x. At 4x the picture is perfect so a 4k/Isco3 combo should be good at 2x. Without the lens I'm looking at 2.66xPH for same pic quality.
coolrda is online now
post #4 of 40 Old 11-14-2011, 11:26 PM
MovieSwede's Avatar
Quoted: 124 Post(s)
Liked: 87
The screendoor depends alot on the projector. And since we talking 4K. You have better pixeldensity then a 1080P with lens.
post #5 of 40 Old 11-16-2011, 10:25 PM
sipester's Avatar
No experience with a 4K projector, but just doing some math. With a 4K projector, I believe you could upscale 1980 * 817 content to 4,096 * 1,743 to be displayed on the screen (assuming you had the right scaler).
With a 1920 * 1080 projector, you get roughly 32% more pixels by scaling/using anamorphic lens than by just zooming (i.e. 2 million pixels vs. 1.5 million). That is a benefit that is not easily ignored.
However, with a 4K projector, I think the issuing of scaling just to 2.35 and zooming vs. scaling to 16:9 and using the lens is much less of a benefit for the lens option. Here's what I mean. With scaling to 4,096 * 1,743, that is 7.1 million pixels, which is roughly 455% more than the original content.
Sure, you can keep scaling to fill up the whole panel, which is 8.9 million pixels (4,096 * 2,180) or 569% more than the content.
I know scaling has benefits, but is there really that much more to be gained by having 569% more than the content vs 455% more than the original content. Even if there is some small benefit, I can't imagine it would be worth the other issues that might come into play with having a lens in there.
So assuming the light output is okay, it sure seems that with all the extra resolution available with a 4K projector, is it really necessary to fill out those last pixels?
sipester is offline
post #6 of 40 Old 11-17-2011, 04:12 AM
CAVX's Avatar
Quoted: 220 Post(s)
Liked: 115
For Art,
Whilst I would normally say keep the lens, is this 4K projector a true 4096? Because if it is, you may not be able to use your ISCO III as it is a 1.33x lens and you actually need a 1.25x. ISCO made the 1.25x for original 2K (2048) projectors.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #7 of 40 Old 11-17-2011, 08:12 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 471
Mark,
It's 4096x2400.
Art
post #8 of 40 Old 11-17-2011, 09:16 AM
stanger89's Avatar
Quoted: 3384 Post(s)
Liked: 1844
I was just going to say, if you go through the math, based on visual accuity, there's a case to me made for added pixel density even at 4K without zooming.
At the bottom of this post I posted some numbers for resolution vs required screen heights to not benefit from more resolution, we were talking about "nearly 4K" 3840x2160 projectors. With those, even unzoomed, at 2160 vertical lines if you're within 2.5 picture heights, you can resolve more resolution.
If you zoom your 4096 projector, a scope image would be only about 1720 pixels, a resolution at which even at a bit over 3 picture heights you could resolve more resolution.
Of course we're getting farther into the realm of diminishing returns with 4K displays, but it would be interesting to hear your impressions.
stanger89 is offline
post #9 of 40 Old 11-17-2011, 11:10 AM
5mark's Avatar
Quoted: 50 Post(s)
Liked: 30
Art
With that resolution and brightness I doubt if PQ while zooming will be an issue. The question may be whether you can implement the zoom method in a smooth and seamless way. If the projector has lens memory, how long will it take to change ARs and will it be extremely accurate? Will you have to make small manual adjustments to the lens shift like Sony 95 users are reporting? Does the projector have electronic masking for the black bar areas in 2.35 mode? IMO it looks very bad when you're zoomed for 2.35 and a menu or FBI warning comes up and bleeds off the screen. I always keep my VP masking activated in 2.35 mode to keep the image looking clean. And it works great for variable AR films like TDK.
You might also consider the shrink method where 16:9 is downscaled to fit the height of a scope screen. I believe even CAVX and coolrda have stated that if they couldn't use an anamorphic lens they would do the shrink method. The advantages over zooming being constant brightness, calibration, pixel density and instant AR changes. Of course these could also be achieved with an anamorphic lens by leaving it in place and scaling for 16:9.
5mark is online now
post #10 of 40 Old 11-17-2011, 12:11 PM
R Harkness's Avatar
Quoted: 2082 Post(s)
Liked: 1786
Art,
Would there be ergonomic benefits to keeping or dropping the A-lens?
I'm betting that the type of projector you'd be looking at would have lens memory pre-set features for automated zooming, but I don't know if that makes it as easy to implement as an A-lens, or visa versa.
R Harkness is online now
post #11 of 40 Old 11-17-2011, 02:59 PM
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Seems to me that a 4K projector plus lens and scaler would be great. Using the shrink method for anything less than 2.40:1, you'd still be able to display more pixels that the source has. Am I missing something? (still a zoomer, but I can dream...)
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #12 of 40 Old 11-17-2011, 04:05 PM
CAVX's Avatar
Quoted: 220 Post(s)
Liked: 115
Mark,
It's 4096x2400.
Art
Why do they make pro gear with obscure ARs like this? 4096 / 2400 = 1.7:1.
So it seems you might need a 1.39x. I know Schneider used to make a 1.42x, but not sure if they still do. Otherwise, your scaling and still not using the full panel. Kind of defeats the purpose here IMO. Granted each pixel is now 1/4 the size of your current pixels, you might just be forced to convert to the dark zoom side
If that is your option, I'd suggest the shrink method over zooming anyway. You have more than enough pixels to throw a few away.
Looks like one ISCO III + Cineslide + 14 foot wide curved screen will be listed on the 4 sale section soon
Mark Techer
CAVX is offline
post #13 of 40 Old 11-17-2011, 06:11 PM
stanger89's Avatar
Liked: 1844
A 1.33x lens would work, you just wouldn't be able to use quite all the vertical resolution, only about 2300 lines of it.
post #14 of 40 Old 11-17-2011, 10:15 PM
CAVX's Avatar
Quoted: 220 Post(s)
Liked: 115
What I said. If Art was to speak to Peter (Cineramax), I'm sure Peter would suggest no A-Lens. It will be interesting to see where Art goes with this given the money he has spent so far on his system.
Mark Techer
CAVX is offline
post #15 of 40 Old 11-19-2011, 06:08 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 471
Thanks all ! I need this since there is simply no way I'm going to think of everything before the purchase.
I'm not seeing much on paper at least that would make this a bad move.
Art
post #16 of 40 Old 11-19-2011, 06:56 AM
MovieSwede's Avatar
Quoted: 124 Post(s)
Liked: 87
If it turn out to be a bad move, you can always use a lens.
post #17 of 40 Old 11-19-2011, 01:53 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Quoted: 2118 Post(s)
Liked: 1205
Send a message via Skype™ to CINERAMAX
Art,
Better than that is using a fixed lens that matches your screen width and do electronic resizing, from 2.39 to 1.78 works great . THE MOST IMPORTANT PARAMETER WITH 4k, (besides using cinema dlp if you can) is the lens.
What is your throw distance Art?
You will never ever want to go back to 2k, with the right lens.
The stairstepping is gone... and still you get great mtf and ansi. Of course if you want maximum contrast get one that holds a 7kw lamp, step it down to the max and put a smaller lamp in it (not to melt the lightpipe).
If your td isgreater than 1.85 then you are ok with zooming some of those are certified for 4k with zoom, the shorter throws suck in resolution.
CINERAMAX is online now
post #18 of 40 Old 11-19-2011, 02:27 PM
5mark's Avatar
Quoted: 50 Post(s)
Liked: 30
By electronic resizing I assume that means downscaling 1.78 until it fits the height of the scope screen? Do any 4K projectors have this feature built in or would a VP be necessary?
5mark is online now
post #19 of 40 Old 11-19-2011, 02:45 PM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1205
post #20 of 40 Old 11-20-2011, 03:21 AM
CAVX's Avatar
Quoted: 220 Post(s)
Liked: 115
Peter,
I assume by this you are referring to the projector's primary lens, not the ISCO III which would be considered a secondary lens in the light path.
Mark Techer
CAVX is offline
post #21 of 40 Old 11-20-2011, 05:13 AM
LICENSED TO THRILL
CINERAMAX's Avatar
Liked: 1205
I don't think the isco would be of any help in resolving the 4k pixels.
For cinema dlp the best 4 k , cost no object situation is a specially fitted lens ($60,000 up), second best is one of the fixed lenses available. .65,.78,.92,1,1.1,1.2,1.3.(11-000-22,000)most made by Isco as well.
Then there is a GAP where there is no 4k lensing (you have to live with the 2k), and then in the 1.8-2.6 zoom range and up they start getting better but not as good as second best a good third best.
The isco 3 would have to hurt the resolvability somehow, how much? Don't know.
post #22 of 40 Old 11-20-2011, 05:16 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 471
I'm looking at one of the JVC Pro units instead of the Barco. The tale, at this point at least, is the black floor of the Barco unit.
I'm going to look at it in a few weeks to see if it is right for me. Since 4K content isn't available yet I need to look at how well it does the processing of BD.
I sit really close and would love more light so my 14' wide scope image is always bright giving it more pop than I have now. With a native sequential contrast of five times the Barco I hope this is a good choice.
Art
post #23 of 40 Old 11-20-2011, 07:35 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
Meridian doesn't think so. Isco III and Cinesilde is built in to their Phelps tuned rebadged 4k. They are pretty picky, too. But what do they know...
GetGray is offline
post #24 of 40 Old 11-20-2011, 09:17 AM
MovieSwede's Avatar
Quoted: 124 Post(s)
Liked: 87
This may seem like a stupid suggestion, but if brightness is one of the reasons you would buy the 4K projector. Another solution would be a to use twin projectors.
post #25 of 40 Old 11-20-2011, 05:49 PM
CAVX's Avatar
Quoted: 220 Post(s)
Liked: 115
Maybe I didn't word my question right. ISCO might very well make the lenses, but they are spherical, not cylindrical like an ISCO III. Is that correct?
Art
Art,
Are you referring to their 4K beast? If so, I've had a little experience with this machine and in all honestly, I don't think up-scaled BD looked as good on that machine as on one their HD projectors (1920 x 1080) for the same size image. I believe it was designed to run 4 x HD program, not 1 massive image at 4x the size. Sure it capable of doing that, but I think it would need an external VP to look its best.
Might be not be important to you, but the xenon lamp for that thing is good for 1000 hours and cost $7K. The benefit is its true colour fidelity where UHP lamps need correction for white to be white.
Mark Techer
CAVX is offline
post #26 of 40 Old 11-21-2011, 07:37 AM - Thread Starter
Quoted: 348 Post(s)
Liked: 471
Mark,
This is the unit I'm considering:
http://pro.jvc.com/prof/attributes/f...l_id=MDL101793
Art
post #27 of 40 Old 11-21-2011, 07:58 AM
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
Here it is with a lens
Prototype:
Shipping (although the dummy who took the photo didn't know the lens was turned wrong):
GetGray is offline
post #28 of 40 Old 11-21-2011, 03:17 PM
CAVX's Avatar
Quoted: 220 Post(s)
Liked: 115
Mark,
Art
The very one. JVC allowed me to operate this for both CEDIA and SMPTE in 09 and CEDIA for 2010. I missed out this year because I got married. The chips are DiLA 4096 x 2500 (according to JVC) which makes it about 16:10. I remember the jokes about the running costs and when I asked how much for the replacement xenon lamp, was told it was $7K for 1000 hours.
The thing easliy weights 80 pounds, so its a stable table mount for this big boy. And it is not the quietest unit around so you'll be thankful you have a "booth" to house it in your HT. It also pumps out some heat too but I am sure you have that covered too.
When fed from a PC source, the image was awesome. I didn't think its scaling of a BD was that great though as I did see the jaggies quite a bit with all the demo screenings we did using Blu-ray. We didn't have any true 4K material but did have some 3K (shot on RED) that was down converted to 2K and then up-converted to 4K which we fed by the PC. The only way we could show a true 1:1 pixel mapping was to open 4 HD windows. The idea was neat, but because each window was half the width of the screen, I felt it was underwhelming for the $$$$$$ (yes 6 figures at the time) outlay.
Scott,
So have Meridian simply re-badged the JVC?
Mark Techer
CAVX is offline
post #29 of 40 Old 11-21-2011, 04:32 PM
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
William Phelps was using his proprietary panel calibration on their units. I believe he persoanlly tweaked every one of them. Theirs included a automated lens and a Marvel (I think) 4k scaler. Not sure what other tweaks.
This 4k is the one Coldmachine used to dog pretty hard compared to DLP options. Don't remember the explicit beef he had though. ANSI contrast maybe.
GetGray is offline
post #30 of 40 Old 11-21-2011, 04:48 PM - Thread Starter
Quoted: 348 Post(s)
Liked: 471
These are all questions I have and will need to be ironed out. Uniformity is the big one. No LCOS will compete with DLP on ANSI but it has five time the native sequential contrast of the Barco units with plenty of light as well as the ability to align the panels in 1/10 pixel steps.
The big Barco was out for me as soon as the black floor reared it's head despit the other traits.
Art
Reply 2.35:1 Constant Image Height Chat
