HC3800 and HC4000 have a memory zoom function - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 01-20-2012, 02:38 PM - Thread Starter
jamieuk147's Avatar
Quoted: 69 Post(s)
am sure I read this some were that the mits ptojectors have some type of secret zoon memory function for 2:35.1 viewing
Is it true?
jamieuk147 is offline
post #2 of 23 Old 01-20-2012, 02:50 PM
MysticalJet's Avatar
Quoted: 81 Post(s)
Liked: 151
not sure about 3800 and 4000, but these do. Well to be straight, its not a zoom function but rescaling.
MysticalJet is offline
post #3 of 23 Old 01-20-2012, 03:35 PM
stanger89's Avatar
Quoted: 2635 Post(s)
Liked: 1354
I'm thinking the feature you're thinking of is the ability to "shrink" 16:9 down to the right size so that you don't need to zoom for 16:9 to fit the height of a scope screen.
stanger89 is offline
post #4 of 23 Old 01-20-2012, 03:55 PM - Thread Starter
jamieuk147's Avatar
Quoted: 69 Post(s)
Am very confused. Can I buy a 2.35.1 screen and store some zoom or scaling so I dont have to manually touch the projector for cinemascope and 16.9 movies.
There is defo some secret menu or something, so I remember reading
post #5 of 23 Old 01-20-2012, 04:09 PM
Liaury's Avatar
The full 16x9 is projected at all times.
When I watch a 2.35:1 aspect ratio movie, the upper and lower parts of the 2.35:1 video (black bars) is projected above and below the 2.35:1 screen. When the movie is 16x9 aspect ratio, I hit the aspect ratio button on the remote, then the full 16x9 video is "shrunk" to fit in the center portion of the 2.35:1 screen (black bars on the side). It's like a small 16x9 screen within the larger 16x9 projection.
There is no manual adjustment required except for a push of a button on the remote.
Liaury is offline
post #6 of 23 Old 01-20-2012, 04:30 PM
Quoted: 81 Post(s)
Liked: 151
Which projector do you have?
post #7 of 23 Old 01-20-2012, 04:31 PM
Quoted: 81 Post(s)
Liked: 151
See the link in my initial post for the "how" to do it.
post #8 of 23 Old 01-20-2012, 04:50 PM - Thread Starter
jamieuk147's Avatar
Quoted: 69 Post(s)
Ok thanks for that link it seems there is a memory save function so am guessing it will push the black bars off the screen via aspect ratio change.
So I will now order a 2.35.1 screen and use thid function I hope it works
post #9 of 23 Old 01-20-2012, 04:50 PM
Liaury's Avatar
Hc4000
Liaury is offline
post #10 of 23 Old 01-20-2012, 09:48 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
The shrink method works by window boxing the 16:9 image at the same height (about 810 pixels) as Scope. When set up on a Scope screen, both ARs will use about 810 vertical pixels of the 1080 on the panel with the remaining 270 thrown off the top and bottom of the screen. The plus for this method over zooming is that your pixel size remains the same.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #11 of 23 Old 01-21-2012, 06:25 AM
mmoore2's Avatar
I have question about HC4000 placement. I'm thinking about buying this projector, but I'm looking at the user manual, it seems that the offset is much greater for the 2:35 vs. the 16:9 screens.
For example, for a 16:9, 49" high (100" diagonal) screen, the offset (Hd) is 16.5"
but for 2:35, a 47" high (120" diag) screen, the offset is 28.5"
When using this method of zooming/scaling for the 2:35 size, do I go by the 16:9 offset or the 2:35 offset?
I only have a 91" ceiling, so I'm trying to keep the screen bottom to be not so close to the floor.
mmoore2 is offline
post #12 of 23 Old 02-06-2012, 02:10 PM
clausdk's Avatar
Quoted: 205 Post(s)
Liked: 78
Do you know if any scaler, for instance the DVDO or lumagen can do this as well? or any BD player for that matter.
clausdk is offline
post #13 of 23 Old 02-06-2012, 02:50 PM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
A HTPC can do this.
MovieSwede is offline
post #14 of 23 Old 02-06-2012, 04:59 PM
5mark's Avatar
Quoted: 34 Post(s)
Liked: 24
The Lumagens can all do this(even the older Vision models) but it takes several steps to set up. A new firmware update is supposed to make it easier with the dedicated function "letterbox zoom".
The Oppo BD players can do it as well. I believe the command is "1/2 zoom".
As far as DVDO, I know the VP50 could do it but the Edge could not shrink the image quite enough(it could work if you cropped a little off the top and bottom). Not sure about the Duo.
5mark is online now
post #15 of 23 Old 02-06-2012, 07:40 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
So have they added Horizontal and Vertical Shrink to the EDGE? The last time I played with an EDGE, it only offered custom Vertical Stretch and offered no Horizontal Shrink to counter the effects.
Mark Techer
CAVX is offline
post #16 of 23 Old 02-06-2012, 10:34 PM
5mark's Avatar
Quoted: 34 Post(s)
Liked: 24
I just remember someone reporting it could do a fair amount of shrink by either the zoom commands or maybe something like overscan/underscan. But this was some time ago so not new.
5mark is online now
post #17 of 23 Old 02-06-2012, 11:01 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
I guess if the image is being processed with the full 33.3% VS, and you progressively shrunk the image, the geometry should remain correct. That could be a work around, thanks.
Mark Techer
CAVX is offline
post #18 of 23 Old 02-06-2012, 11:55 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Apparently these projectors have "shrink" built in. Once set up, it should be a one button solution.
Mark Techer
CAVX is offline
post #19 of 23 Old 02-17-2012, 01:44 PM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
Question guys....how does this setup handle movies with Subtitles?
JoeBoy73 is offline
post #20 of 23 Old 02-19-2012, 06:43 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Subtitles needs to be shifted in the player stage. Either you use a player like Oppo or Philips with subtitle shift, or a HTPC with TMT5 that can move subtitles.
post #21 of 23 Old 03-05-2012, 09:22 AM
AVS66's Avatar
I have HC3800 model. I've never heard this feature. Will pq be reduced if I use this feature?
AVS66 is offline
post #22 of 23 Old 03-05-2012, 11:42 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Yes the 16:9 image will "suffer" since it has to be downsized to fit inside the 2.35 frame.
2.35:1 = 1920*817 gives us 16:9 = 1452*817. (I guess its 1440*810)
But it equals the quality of 2.35:1 movies. Same resolution/area.
post #23 of 23 Old 03-05-2012, 03:59 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Why don't you just use it and see for your self.
Mark Techer
CAVX is offline
Reply 2.35:1 Constant Image Height Chat
