Panamorph P752...how much time? - AVS Forum | Home Theater Discussions And Reviews
Old 01-25-2012, 08:22 AM - Thread Starter
VinnyS's Avatar
Liked: 54
Hi guys,
I just purchased a P752 lens on-line and I just received and noticed that there's a bit of oil. I've already read up on the lens about it loosing oil is not a good sign. I was wondering how long I have before the lens is completely finished. Is there anything that can be done to even slow it down?
Get all your A/V News at: AVS Latest News
Like AVS Forum on Facebook
Follow AVS Forums on Twitter
AVSForum
Bringing the AV Community Together
VinnyS is offline
Old 01-25-2012, 08:23 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
It's just mineral oil. If the leak isn't bothering you, I guess you can fill it back up. Some carefull cleaning and silicone and oyu may be able to stop the leak.
GetGray is offline
Old 01-26-2012, 06:22 AM - Thread Starter
VinnyS's Avatar
Liked: 54
Ok, so there is a "way" to fill it up...somewhat? I might just try and see where it's leaking and try to stop it. I am more worried about how long I have until I really see a bad image. It is not a major leak, one part of the outer lens, get's a little sweaty.
AVSForum
VinnyS is offline
Old 01-26-2012, 09:42 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
I'd find the leak, then empty it first before attempting to seal the leak. Clean the outside so that you don't have any oily residue to prevent the adhesive from sticking and re-fill using a syringe fed in from the top.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
Old 01-27-2012, 07:10 PM - Thread Starter
VinnyS's Avatar
Liked: 54
What type of oil does this piece use?
AVSForum
VinnyS is offline
Old 01-27-2012, 07:26 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
It should be a very fine mineral oil.
Mark Techer
CAVX is offline
Old 01-29-2012, 06:51 PM
programmergeek's Avatar
If it is new I would send it back for warntee. Why mess with it.
Jason
Note: Any posts are of my personal opinions and not to reflect upon any business.
Jason@programmergeek.com
908 578-6466
programmergeek is offline
Old 01-29-2012, 09:26 PM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
They stopped making that lens about 10 years ago. It was one of the first.
GetGray is offline
Old 01-29-2012, 09:31 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Oil was chosen because it would not 'go off' like some other liquids do, but I think its problem is that it breaks down the rubber used to seal the prisms. This certainly was the case with all the DIY attempts at making oil filled prisms (about 10 years ago). You could even use glycerol if you can find the right one. Just some are said to be 'volatile' in bright light which is something you want to avoid given where the lens will sit when in use.
Mark Techer
CAVX is offline
Old 01-30-2012, 07:18 AM - Thread Starter
VinnyS's Avatar
Liked: 54
I actually got it for my dad, gave him my 2.35 screen and wanted to project on the full screen. He's got a 720p InFocus PJ and didn't want to spend alot of money. I managed to have found the P752 on audiogon for roughly 300$. I figured it would last him until he get's a new PJ. I think after he see's how amazing it is, I think he'll go all out on a new lens for his next PJ.
Thanks CAVX for all the info, much appreciated. I'll let you know when he'll be looking for his next lens.
AVSForum
VinnyS is offline
Old 02-03-2012, 06:29 PM - Thread Starter
VinnyS's Avatar
Liked: 54
Hey Guys, I feel a little sheepish asking this, but I'm helping my dad setup the lens and it was a little bit more tricky then I thought it was going to be. I found a user on the forum who had an IN76 with the P752 lens and used the projector presets (4:3, 16:9) as the scaler.
How does one setup an anamorphic lens? Any help is very much appreciated.
AVSForum
VinnyS is offline
Old 02-03-2012, 08:38 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
All adapters can be tricky
Yep, the easiest method is to use the projector. 4:3 mode is used for 16:9 and Letter Box will be used for Scope. If you use the 16:9 mode and do not have another means to Scale, the image geometry will be out.
For a VC, you must have the projector far enough back so that the native image (16:9) width is the same as the Scope screen. You then add the VC which compresses the image down to fit the height. What you might find is that the amount of tilt can actually increase or decrease the amount of compression the lens applies. This will require you to have a screen set up in place so that you have a point of reference.
Mark Techer
CAVX is offline
Old 02-04-2012, 05:52 AM - Thread Starter
VinnyS's Avatar
Liked: 54
I see. I guess I need to bring the projector back enough to fill the scope screen in 16:9 so that it fills the screen and the lens will compress the top and bottom to fit the image properly....correct?
AVSForum
VinnyS is offline
Old 02-06-2012, 11:58 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Correct. Move the projector back first. You may have to use some zoom, but only do so as the last resort after running out of throw.
Mark Techer
CAVX is offline
