Auto lens memory - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-27-2012, 02:13 PM - Thread Starter
davdev's Avatar
I have just recently begun looking into projectors again and I have a question.
I would look a PJ that autodetects 2.35 or 16/9 and automatically zooms to the proper lens setting. I believe the Panny AE7000U does this, but is there anything else?
I know there are others where you can use presets to go back and forth with the click of a button, but I think for WAF having this automated would be best.
I did a search on Lens Memory and too much unrelated info came up, so I am sorry if this has been hacked to death in the past.
davdev is offline
post #2 of 13 Old 01-27-2012, 02:34 PM
stanger89's Avatar
Quoted: 2635 Post(s)
Liked: 1354
JVC added lens memory for the latest generation, and then I think Epson has talked about it (don't know if those ever came out yet) and of course there's the high end guys that have it too.
I don't, my understanding is that it takes a good while (5-10 seconds?) for the transition to take place, with stuff like Transformers and The Dark Knight switching back and forth (as an example) and trailers being differing ARs, and all of that, I wouldn't want my projector automatically trying to keep up with all that.
Now if you had an automation system that could do it automatically based off some metadata for the movie (like I believe Kaleidescape does), that would be cool.
stanger89 is offline
post #3 of 13 Old 01-27-2012, 03:03 PM
taffman's Avatar
Yes, the auto transition is not instantaneous on the AE4000. It takes about 6 seconds and you get that annoying "processing' pop up on the screen. So I dont use it, and I cannot see this working very well in multi format movies. But the lens memory is great for switching aspect ratios at the start of a movie, and multi-format movies are so rare that its really not an issue.
taffman is offline
post #4 of 13 Old 01-27-2012, 03:07 PM
tbase1's Avatar
Quoted: 43 Post(s)
Liked: 66
+1
tony4k
tbase1 is offline
post #5 of 13 Old 01-30-2012, 12:47 PM - Thread Starter
davdev's Avatar
The only multi aspect movie I have ever watched is TDK, so I am not so worried about that. To me the benefit of having it set automatically would far outway this particular drawback.
So beyond the Panny models, what other PJ's offer this solution.
davdev is offline
post #6 of 13 Old 01-30-2012, 01:58 PM
ilsiu's Avatar
JVC 45,55,65
Sony VW95
Epson 61000 (not available in US)
ilsiu is offline
post #7 of 13 Old 01-30-2012, 06:29 PM
rukus29's Avatar
Quoted: 35 Post(s)
Originally Posted by ilsiu View Post
JVC 45,55,65
Sony VW95
that is incorrect, at least for the JVCs. They have the zoom memory but do not AUTO zoom based on the PJ detecting content automatically, you must push a button. the OP was looking for auto-zoom so he didnt have to push a button.
rukus29 is offline
post #8 of 13 Old 01-30-2012, 07:32 PM
Maestro J's Avatar
Quoted: 75 Post(s)
Liked: 55
I believe the Panny is the only one with an "auto" lens memory detection feature. The JVC and Sony doesn't offer this.
Maestro J is offline
post #9 of 13 Old 01-30-2012, 08:10 PM
ilsiu's Avatar
oops - missed that important point.
AFAIK, the panny is the only one that has auto detection of content.
ilsiu is offline
post #10 of 13 Old 01-30-2012, 11:11 PM
vagpwner's Avatar
hey guys im having an issue with my sony.
when i press the wide mode button for anamorphic zoom, it says not available
vagpwner is offline
post #11 of 13 Old 02-01-2012, 10:10 AM - Thread Starter
davdev's Avatar
Thanks guys. I was leaning heavily towards the panny's to begin with and now it looks like my only option.
davdev is offline
post #12 of 13 Old 02-01-2012, 10:38 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
I believe it will also auto switch while going through the previews and adverts that are on before you even get into the actual movie menu.
I have my function button set to scroll between the aspect ratio modes so I can go to S16:9 if the menu is off the screen once I actually get to the movie menu. Then back to 16:9 for the actual movie.
Bill
mrfattbill is offline
post #13 of 13 Old 02-03-2012, 07:19 AM - Thread Starter
davdev's Avatar
Bill
I have an HTPC with all movies ripped so only the main movie is present. Don't have to worry about Adverts, Trailers, FBI Warnings, Menu's etc.
davdev is offline
Reply 2.35:1 Constant Image Height Chat
