Dust with Lens - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 04-07-2012, 07:21 PM
CIH USER
Franin's Avatar
Quoted: 2189 Post(s)
Liked: 1311
Originally Posted by Highjinx View Post
What's the wind tube?
I agree what's the wind tube?
_________________________
Franin is offline
post #32 of 37 Old 04-08-2012, 03:01 AM
coolrda's Avatar
Quoted: 852 Post(s)
Liked: 614
You've cleaned the filter have you ever cleaned your 'A' lens coolrda ?
Hi Franin. Yes. I clean the A lens every six months when I clean the filters. I've measured my ANSI and CR on/off with no change using an eye one LT & hcfr.
coolrda is online now
post #33 of 37 Old 04-08-2012, 06:07 AM
CIH USER
Franin's Avatar
Liked: 1311
May i enquire how you clean your lens? Is it an easy process? Im yet to do mine.
That's very good to know thank you.
Franin is offline
post #34 of 37 Old 04-08-2012, 12:25 PM
Gary Lightfoot's Avatar
Quoted: 588 Post(s)
Liked: 344
Glass is not 100% transparent, granted better glass is more transparent than ones of lesser quality, dust is a light blocker altogether(dirty sunglasses/reading glasses anyone?)thus light passing through will be affected to varing degrees in reaching it's destination.
Have you done much (any?) measuring of your own? It's around 1%.
Measured results depends on the quality and sensitivity of the measuring instrument.
UMR(Jeff Meier) uses some SOTA measuring gear:
Lol. You're showing your ignorance - you don't need 'SOTA' equipment to take basic contrast measurements.
http://homecinemaguru.com/?p=698
"I recently aided a test with a Prismasonic H-FE1500R and a JVC DLA-RS35. The projector was mounted at a 2.0 throw ratio. Using lens zoom to fill a 10 ft wide 2.35 screen the ANSI contrast was measured at 250:1. With the anamorphic lens the ANSI contrast fell to 112:1."
And if you continue to read further down you will see he has this to say in reply to someone who is questioning his methods:
Originally Posted by W. Jeff Meier View Post
I have also measured many quality lenses that do not affect ANSI much as well. This is the worst I have seen. I suspect it is the fact it is a prism and not just a lens.
Seems you want to use one unusual result as a metric to which all others should be judged by.
and that is just the A-lens.........I would think dust would have a significant effect on light scatter and a decrease in ANSI and light transmission further.
Like I said, the effects (measured or otherwise), are inconsequential in real terms.
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is online now
post #35 of 37 Old 04-08-2012, 12:30 PM
Quoted: 588 Post(s)
Liked: 344
I used to measure mine with a dedicated light meter with the same results.
Seems pretty conclusive to me.
Gary
post #36 of 37 Old 04-08-2012, 07:20 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
The wind tube is a DIY cleaning station 400mm long x 250mm dia piece of PVC pipe. A round desk fan with an OD of 250mm is mounted to one end blowing into the pipe. I simply stretch a stocking with finest denier (weave) I can find over the fan and back of the wind tube. This now filters air born partials. They can't enter from the front because of the air flow. I ended up using the fan's stand for the stand of this rig. It fits in a small sports bag and I was even able to take it to Melbourne as carry on to service an MK4 lens last year.
All up, it cost me about $40.00 to make and seems to work very well.
Now that's a lens with great transparency!
It really is about technique and one I am still learning. Getting rid of the dust is the easy part. Getting rid of oil from finger prints is not so easy and using cloths and fluids to remove these can often leave further smudges or residue.
I use a bright LED light behind the optics when cleaning so I can see if I am actually removing or adding more. I have not mounted the light yet, and am not sure I want to because you do need different angles at times.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #37 of 37 Old 04-09-2012, 04:05 AM
Highjinx's Avatar
Quoted: 323 Post(s)
Liked: 152
That would depend on the thickness of dust and the type
Are you saying SOTA gear is a waste of time.....accurate measurement requires good equipment.
I believe I did leave in the make of lens
Gary
In your opinion, not only the additional glass but the dust too will act as a filter.
Would you take a photograph with a dusty lens?
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is offline
Reply 2.35:1 Constant Image Height Chat
