Prismasonic HD-6000M vs Panamoph UH480 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-01-2012, 06:11 AM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
Hi all,
I'm looking at these two lenses and needed some input. I'm shooting (not all purchased yet) 54" x 130" (140 diag) screen with an Epson 6010. My throw distance is 17.5'. Also will be using most of the lens shift to keep the projector higher.
I noticed on the UH480 that I'm just on the edge of the "optimal" throw distance. On the HD-6000 I didn't notice any range mentioned.
My questions are
1) which one is better given my situation? About the same?
2) will using lens shift give me any issues with the lenses?
Here is my build thread:
---->Like a Boss Theater Build<----
Yzfbossman is offline
post #2 of 6 Old 05-03-2012, 05:56 AM
stanger89's Avatar
Quoted: 2634 Post(s)
Liked: 1354
My understanding is the HD6000 is a cylindrical lens design which is fundamentally better than the UH480's Prism based design, so it should definitely be the better lens. The tricky part is if it's enough better to justify any additional cost (I haven't kept up with the HD6000 prices).
Vertical lens shift shouldn't be a problem as long as its not "excessive".
stanger89 is offline
post #3 of 6 Old 05-03-2012, 07:15 AM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
Yzfbossman,
Here is the pdf of the UH480 Owners Manual And Install Guide.
http://www.panamorph.com/library/pro...SYS_Manual.pdf
It has all the info regarding Throw Distance, Throw Ratio and Lens Shift.
...Glenn
Glenn Baumann is offline
post #4 of 6 Old 05-03-2012, 08:17 AM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
There are some 480 owner's who bought the prismasonic lens, they have posted some comparisons in the Prismasonic owner's thread:
http://www.avsforum.com/avs-vb/showt...hlight=rboster
If you use the search within a thread engine and UH480 or 480 or panamorph as your individual search words, you'll for their posts.
Ron
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
post #5 of 6 Old 05-03-2012, 08:57 AM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
Thanks guys
post #6 of 6 Old 05-04-2012, 01:17 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
In brief, the lenses used in a cylindrical lens are just that - lenses, each with its own focal length (positive and negative in the case of an A-Lens). As I understand it, when the two lenses are aligned, both the pos and neg focal lengths are cancelled resulting in a device with infinite focus.
Prisms don't have a focal length so rely on additional elements being added to allow focus.
It may or may not have a bearing and will be set up/projector dependent.
What I found with my own set up which has the projector shelf mounted level to the top of the screen (projector is not inverted in this case) is that my extreme lens shift usage (due to the way the projector is mounted) results is a slightly painful set up and alignment proceedure. As we all know, the HE A-Lens creates pincushion which kind of looks like )( only horizontally. When the A-Lens/projector is mounted high (as is the case with mine), the pincushion tends to be uneven, so it common practice to tilt the A-Lens towards the centre of the screen. However, too much tilt and the shape of the pincushion goes from )( to )), so even with a curved screen, you will get geometry issues.
When I built my curved screen, I made it with adjustments for both the top and bottom, so I could correct )) by offsetting the amount of curve top to bottom. I would rather not do that, so learned how to "optically" balance the pincushion to )( and let the curve of the screen do what it is supposed to do. The end result is no geometric distortions and lovely straight horizontal lines.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
Reply 2.35:1 Constant Image Height Chat
