I've Joined The A-Lens Club! - AVS Forum | Home Theater Discussions And Reviews
Old 05-01-2012, 11:18 AM - Thread Starter
R Harkness's Avatar
Quoted: 1931 Post(s)
Liked: 1637
As I mentioned in the projector forum, I've picked up a used Panamorph UH480 Anamorphic Lens, from another AVSforum member, and I'm all giddy. So I thought I'd share...and ask some questions.
As a dedicated "zoomer," why did I buy one?
As some here know, my system was deliberately designed as a Variable Image Size system, to use the projector's zoom with 4-way masking to vary the image size to my desire. I had bought the largest possible screen for my wall - larger even than could be accommodated by the throw distance (maximum zoomed out image size) of many projectors. And my throw distance is limited, so any projector ends up being placed within an inch or so of the back wall (actually, it's a bay window). So the mere depth/length measurement of a projector can add or subtract from my maximum image size. I have up to 124 or 125" or so available screen width, with my side masking fully retracted, that I want to be able to take advantage of.
My first Panasonic AE900 projector, being small, gave me the largest image size. My next, the JVC RS20 still gave a pretty big scope image, but not as wide. Now my new JVC RS55 projector, being even deeper, has limited the size of my 2:35:1 images even more. I was down to between 118" and 116" wide for scope. Only an A-lens would allow me to re-size scope images larger, in my room. And, I'm not one of those who is terribly worried and an A-lens affecting the image quality adversely (by putting more glass in the way) - every A-lens set up I've seen always struck me as looking great.
So, from the beginning, I designed my projector lift area to accommodate an anamorphic lens at some point. However, holding me back was the fact they are so darned expensive. Further holding me back is the fact I'm so happy zooming the image, including for scope, and it's not like I had a small image. An A-lens just gets me a few inches more, so it would have been hard to justify spending thousands of dollars on an A-lens given I don't use a strict CIH system, and that it would only be for those times when I wanted the widest image possible. But...a great deal I couldn't refuse came up so now it made sense and here I am. And, I know those last inches can really add impact - with an A-lens I'm back to about a 124" wide scope image again.
I'm at about a 1.8 throw ratio with the 16x9 image size, so I am told I can expect a bit of pincushion.
Pictures, and then first impressions and questions to follow...
R Harkness is offline
Old 05-01-2012, 11:23 AM - Thread Starter
R Harkness's Avatar
Liked: 1637
Photos of the UH480 A-Lens with my RS55 projector. My projector sits on a lift that sits close to the floor, but telescopes up to about 6 feet or so. (The green tape is temporary for marking positions).
The member who sold me the UH480 had built is own cost effective lens sled, out of drawer slides, screwed to a black shelf board. He gave me that slide/shelf as well.
So for now I've just plopped the whole thing under my JVC RS55, which makes it easy for initial testing:
You can see how close the back of the projector is placed to the ledge of the window, hence maxing out my throw distance:
Projector Lift is up a bit: A-Lens in position:
A-Lens shifted out of light path:
Old 05-01-2012, 11:59 AM - Thread Starter
R Harkness's Avatar
Liked: 1637
First Impressions:
These are so preliminary as to be almost invalidated by the technical issues I ran into...but since some of them are positive I'll mention them anyway.
When my projector lift is fully raised, the Projector sits about 3" above the height of my largest 2:35:1 image on the screen.
The first issue is that I set my image size, switched my RS55's anamorphic processing on, and then slid the UH480 into place. Right off the bat (looking at the lens pattern) the geometry was crazy-off, warping all over the place. So I tilted the UH480 to try to try to compensate, and it got a bit better, but was still a mess. The other issue was about 1/3 of the bottom of the image was in shadow - it was missing. I realised later, especially from looking at A-lenses in the "2:35:1 Screen Picture Thread," that my UH480 is riding too high on the shelf. It's mounted to a 1" high wood block, which appears to put it up too high in front of the lens as you can see here:
So it looks like I'll have to fix that issue somehow, for now I'll put something under my projector to raise it up. But my question is: do I need the projector to be perfectly level with the lens? Or, because it's slightly higher than my screen, will the lens be best placed slightly lower down, angled slightly down toward the screen? (That's how many of the ceiling-mounted A-lens set ups look to me, from pictures).
Anyway...
I ended up lowering my projector lift to the point I could tilt the UH480 up just enough to eliminate the bottom shadow from the 2:35:1 image. However, the image geometry was still pretty awful - not just the fringes of the image, but there was warping on either 1/2 of the image as well. I can really use some advice as to how to best situate and dial in this lens.
All that said, I watched some movie scenes anyway, just to see them fill my screen.
It was awesome seeing that even-more-huge-and-cinematic impact of using most of my screen width. The bigger the image, the more cinematic it feels.
The Alien Blu-Ray scenes had me feeling I'd lost a bit of clarity (hopefully attributable to the current crappy lens set up) and perhaps a bit of contrast (black levels seemed a tad higher). But then as scenes went on, many exhibited quite nice contrast. I was happier as I continued to view...it was at least quite promising. Was it brighter? I don't know objectively, but my over all impression from everything I watched was "hey, this is quite bright, especially given it's an even bigger image size than the biggest I've watched in quite a while." I had my RS55's iris down most of the way, to about -12 and the image was vivid at 123 or 124" wide.
After that I watched some of The Fifth Element and The Island. Holy cow they looked fantastic! (Though I could spot the poor geometry, it was far less intrusive than the lens pattern would have led me to predict). I think this is where a projector like the RS55 really comes into play, with it's amazing contrast and the added clarity you can bring in with the E-shift/MPC settings. But the huge scope image was just gorgeously sharp and detailed, with tons of "pop" and contrast. It just looked better than it had any right to at that size. Once those two movies went on, I was just "wow...wow!" for the rest of the night. I put on 2001 Space Odyssey and it looked astonishingly good!
Better than I thought it could at that size. And of course, no film demands more immersion than that one.
I don't know yet if I can attribute the excellence of the image to adding an A-lens or not. Maybe, in allowing this image size at a smaller zoom setting, it's allowing for more contrast in the image. That's the feeling I was getting.
But I won't know better until I do some good zoom vs A lens comparisons.
But it was a very promising first look in terms of the image experience. I just hope I can lick the geometry problems.
Any advice would be much appreciated as to what type of angling I should aim for with the A-lens.
Thanks for reading....
Old 05-01-2012, 01:29 PM
HogPilot's Avatar
Liked: 25
Rich,
As you've discovered already, alignment with an anamorphic lens is crucial to minimizing optical distortion. Here's the steps I take in aligning my projector and lens to the screen:
Align the projector first so that the image on the screen isn't distorted at all (i.e. any keystoning resulting from the projector being off center and angled at all). Vertical lens shift isn't bad, but try to avoid horizontal lens shift. Even a perfectly aligned anamorphic lens will still yield excess distortion if the projector itself isn't first properly squared off to the screenj, so this step is just as key as the others!
Once you have an image that is perfectly square with the screen, insert the lens into the light path. Make sure that the lens is 100% parallel with the light beam coming from the projector in both the horizontal and vertical axes. Assuming you're not using any horizontal lens shift, the rear face of the lens should be perfectly parallel to the face of the projector. You'll want to angle your lens up or down if you're using any vertical lens shift so that, from the side, the light beam passes right through the center of the rear and the front of the lens. In other words, if the light beam is angling down from the projector, you'll want to angle the anamorphic lens down at the exact same angle so that the beam of light passes right through the central axis of the lens from entry to exit. Part of this step is sliding the lens up or down on its mount to make sure that one side isn't higher than the other (which will cause distortion) and that the light beam is (as previously mentioned) passing through the central axis of the lens to avoid vignetting. Failing to angle the lens up or down will cause more distortion on the top or bottom of the image.
At your throw of 1.8, you will see some pincushion and that will be unavoidable. However it should be easily masked off of the edges of your screen.
Good luck and enjoy your new lens, the UH480 is an outstanding lens, especially for the price!
There are 10 types of people: those who understand binary, and those who don't.
HogPilot is offline
Old 05-01-2012, 01:59 PM - Thread Starter
R Harkness's Avatar
Liked: 1637
Thank you HogPilot! Your quick reply is just what I need, as I'll be trying to address these issues tonight.
I did start with aligning my projector to the screen (in a quick and dirty way, as opposed to the very precise way I'd aligned it before I had to lift it off and place the lens shelf under it). Though, once I build the new shelf to accommodate the new lens, I'll be extra precise in re-aligning my projector to the screen again.
I am not using any horizontal lens shift. I am using a fair amount of vertical lens shift, to shift scope images downward to fit my screen. Given that: do I still want the A-lens perfectly aligned, level with my projector, and then I angle the A-lens more down toward the screen? Or...do I want the A-Lens to be mounted slightly down from the projector lens, to best accommodate the downward vertical lens shift? (It seems to me a number of ceiling mounted A-lens users have their A-Lens hanging a tiny bit lower than the projector lens).
Good point about making sure neither side of the A-lens is higher than the other. Though I have the A-lens slid down to the bottom of it's vertical position, so I think both sides must be level.
However, I did note that my A-lens was not perfectly parallel to my projector lens, being a little bit closer to one side. I'll correct that.
Especially at the price I paid for mine.
Much obliged!
Rich
Old 05-01-2012, 02:06 PM
HogPilot's Avatar
Liked: 25
Much obliged!
Rich
Glad I could be of help
To answer your question, you want your lens to be slightly down from the projector - since the light is angled down coming out of the projector, putting the lens slightly down will allow the light to hit the rear of the lens in the exact center of its entry.
HogPilot is offline
Old 05-01-2012, 03:01 PM - Thread Starter
R Harkness's Avatar
Liked: 1637
Will do!
Also, one other issue was on my mind: When the lens is slid out of the light path it ends up in front of the left fan exhaust vent (there are two intakes on the back of the projector; 2 exhaust vents on the front, one to each side). You can see that in the last image of those first 4 I posted.
That has me curious if it would be a problem either with ventilation for the projector, or just vent heat flowing toward the lens.
It seems to me the slides other people have made, and also the slides offered by Panamorph, put the A-lens in essentially the same position when not used (in front of one side of a projector - hence likely in front of an exhaust vent). But I haven't heard any problems with this, nor did Mr.littlejeans (who sold me the UH480) seem to have an issue on his projector.
Thoughts, anyone?
Old 05-01-2012, 03:33 PM
b curry's Avatar
Quoted: 317 Post(s)
Liked: 159
Welcome to the Bright Side!
Here's a link to the Panamorph UH480 MANUAL AND INSTALLATION GUIDE: http://www.panamorph.com/library/pro...SYS_Manual.pdf
What HogPilot said; very important to get the projector square and centered with your screen with a good 16:9 image first. A little overscan is ok and will probably help with your throw ratio/pincushion. Pay close attention to Pitch and Yaw.
If you Google TECHHT or CineSlide, GetGray has setup instructions for the ISCO. Some of it will translate for your Panamorph.
Before you know it, you'll be lusting after an ISCO.
b curry is offline
Old 05-01-2012, 08:23 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 246
Thoughts, anyone?
Hi Rich - It looks like your exhaust maybe vents off at an angle and that you would have enough space between the lens and the vent to have the lens positioned between them. I think as long as you get the lens out of the light path, your exhaust shouldn't be impeded too much. I didn't have the problem with the RS35 as the RS35's layout is different - the exhaust is on the right side of the projector and the lens is on the left side. With the lens slide off to the side, the lens slid completely free of the front of the projector. Glad you are enjoying the lens.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
Old 05-02-2012, 04:24 AM
Highjinx's Avatar
Quoted: 325 Post(s)
Liked: 153
Looking forward to a brightness Eq's same size image( A-lens & Zoom), assessment, masked of course.
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is offline
Old 05-02-2012, 07:56 AM
taffman's Avatar
Hi Rich,
I don't know anyone else on this forum who will give a more impartial assessment of zooming versus lens than you. I will be eagerly following this thread to see what conclusions you come to.
taffman is offline
Old 05-02-2012, 10:11 AM - Thread Starter
R Harkness's Avatar
Liked: 1637
Thanks mrlittlejeans, I'll check it out.
Highjinx, taffman...
I don't want to raise expectations unduly. I'm not able to be too technical about the comparison as I do not have a light meter. I'll just be eye-balling the difference between zoomed/A-lens to see what I think.
I'm finding the positioning of the A-lens even tougher than I thought it would be. Last night I raised my projector, maneuvered positions. Even though it seems to me the projector beam is centered through the A-lens I'm still getting nowhere near normal geometry. I still had to lower my lift a lot to get the geometry better. Still, watching more content through the lens at full size looked absolutely amazing last night. Also, pixel focus through the A-lens, at least near the center of the screen, is quite impressive. Without a quick A/B, I'm not sure I can tell any difference from no lens. So my hopes are somewhat up...
Old 05-02-2012, 10:49 AM
stanger89's Avatar
Quoted: 2634 Post(s)
Liked: 1354
OK I browsed quickly through the thread and didn't see this answered so forgive me if it's already been said.
What you want to do is two things:
1) Make sure the light is roughly centered in the lens. This will avoid shadows you were seeing and minimize any issues.
2) Tilt the lens so that the pincushion is equal top and bottom.
If you do this, depending on how your light beam travels the lens may or may not be level, and may or may not be "even" with the projector. The fact is the orientation of the lens to the projector is really inconsequential, you want it aligned with the light passing through it.
My Planar 8150 is ceiling mounted which results in my lens having to be tilted down a bit.
stanger89 is offline
Old 05-02-2012, 11:48 AM - Thread Starter
R Harkness's Avatar
Liked: 1637
Thanks stranger89.
Right now the A-lens is slightly below my projector's lens, and tilted downward toward the screen. Since I'm still experiencing issues, it looks like I have to raise my projector even more. Or...and this is the question on my mind...would I want to also tilt my projector on a slightly downward angle toward the screen, so that both my projector and A-lens are tilted down toward the screen? (Off hand, I would have figured one would want the projector's lens as parallel to the screen surface as possible, hence no downward tilting).
Right now, when I bring my projector lift down half-way I can get geometry that, using the projector's lens pattern, has the top and bottom of the lens pattern line fairly straight along the top and bottom of my screen frame. But I see significant bowing on both the outer side vertical lines of the lens pattern AND bowing on the inner vertical lines - the ones that designate the 16:9 and 4:3 areas of the image.
Old 05-02-2012, 12:06 PM
stanger89's Avatar
Liked: 1354
Thanks stranger89.
No, if you do that your picture will no longer be square. You can't "fix" an unsquare picture with a lens.
That's weird, that sounds like what you get with a vertical compression lens.
Old 05-02-2012, 06:40 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Next to Taffman I thought you'd be one of the last to go (kidding both of you). Align pj perfectly then deal with lens. Do NOT tilt PJ. The Pana has no roll adjustment AFAIK so you are limited there. Be sure it is level with pj. Shim as needed to correct skew, if you can. Otherwise, shouldn't be that hard to adjust. Well, the ones I use aren't anyway
GetGray is offline
Old 05-04-2012, 08:16 PM
Mike Garrett's Avatar
Quoted: 5570 Post(s)
Liked: 3550
Harkness, one thing that you might consider, is adding a video processor. My image looks better using the Lumagen Mini 3D with the lens (Prismasonic HD6000F) than it does using the projector for the vertical stretch. For me it makes more of a difference, since my lens stays in place.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 05-06-2012, 10:06 PM - Thread Starter
R Harkness's Avatar
Liked: 1637
I just wanted to say: thanks Mike, GetGray, stranger89 for the suggestions.
Boy, this is still proving to be challenging. I have to get back to trying to get that geometry straight tomorrow.
Old 05-07-2012, 02:09 PM
230-SEAN's Avatar
Are you sure the UH480 can work with the JVC? It looks like its gonna be a tight fit regardless of placement, you might end up with vignetting no matter what you do. I hope it works though, welcome to the club!
-Sean
230-SEAN is offline
Old 05-07-2012, 02:39 PM
jkscherk's Avatar
Quoted: 61 Post(s)
-Sean
Man.....I sure hope it can as I just bought one to pair with my RS-45 and it will be here tomorrow!
jkscherk is offline
Old 05-08-2012, 05:08 AM
coolrda's Avatar
Quoted: 852 Post(s)
Liked: 614
I just knew the stars would align for you one day Rich. Welcome to Euphoria.
coolrda is offline
Old 05-08-2012, 06:40 AM - Thread Starter
R Harkness's Avatar
Liked: 1637
Well, silly lil' me...
See, I told you I was a newbie at this A-lens stuff.
As I've mentioned, I was trying to adjust the geometry with the A-lens in place, using the projector's lens pattern. With the A-lens in place and anamorphic stretch employed, I'd been wondering why no amount of fiddling with the A-lens could fix the obvious warping/stretching of the geometry lens pattern.
I only realised last night that the anamorphic stretch is automatically TURNED OFF when I switch to the projector's lens pattern. Whereas I'd presumed the anamorphic stretch had been applied to it, like the movie image. That obviously explains the un-fixible warped geometry: it was a regular 16x9 image that was being stretched wide by the A-lens!
Doh.
So I threw in the Spears and Munsil Blu-Ray for the geometry pattern and things looked much better. Still not perfect, there are challenges still to be met. But that explains why the image looked ok with movie material.
I'm still awestruck by how good the image looks this big.
Old 05-08-2012, 11:11 AM
230-SEAN's Avatar
Right? It really is something one has to experience in person.
-Sean
230-SEAN is offline
Old 05-08-2012, 11:26 AM
tgrinch's Avatar
Quoted: 21 Post(s)
Doh.
This is really good info, actually. I'm awaiting my lens and wouldn't of thought to check this either!
tgrinch is offline
Old 05-08-2012, 12:05 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 364 Post(s)
Liked: 355
Congrats Rich. This is one reason I like the Onkyo AVR/AVCs; they can do the vertical stretch and then you can use the projector patterns if you wish. Quality of scaling appears very good, but probably not as good as Lumagen would provide. Your throw ratio should be excellent for the JVC and 480. That's what I have...and done others. It is kind of surprising to see the 480 aimed down so much to render the proper geometry, but that's what it takes. Enjoy.
Cam Man is offline
Old 05-11-2012, 05:58 AM
CIH USER
Franin's Avatar
Quoted: 2189 Post(s)
Liked: 1311
Welcome Rich good to have you in the club.
_________________________
Franin is offline
Old 05-23-2012, 05:44 AM
Andy Lammer's Avatar
Rich: any further comments after a few weeks with the lens ?
Andy Lammer is offline
Old 05-23-2012, 07:31 PM - Thread Starter
R Harkness's Avatar
Liked: 1637
Sort of.
I had such a heck of a time trying to figure out the best position for the A-lens that I threw in the towel for a while and just started using it. I have to get back to decide on it's final position, hopefully this week (and then have a proper shelf built). I've been busy with other things in the home theater, room upgrades, moved from an Oppo 83 to Oppo 93 blu-ray player and for some reason I'm now tracking down a lipsync issue.
I'm thrilled to finally own an A-lens, mostly for it's allowing me to finally use every inch of my screen real estate. I can now get that really massive feel for scope when I want it, so there is a sense of completion there.
I haven't done any strict zoom vs A-lens comparisons yet, but it looks tremendous with the A-lens. Probably because I just got the A-lens I've been viewing more scope films larger than before, though I'm still glad to have the option of varying the image size. Last night we opted to watch Kurosawa's '63 scope film High And Low at a smaller size, which preserved the image quality better of that older film.
Guests think the A-lens demos are neat, though altering the image size via zooming seems to get more of a "wow" out of them - it's that JVC lens pattern that looks to guests like the image has been replaced by a laser show, and then the image pops back on and its a new movie at a different size.
Once I get to re-adjusting my lens I'm going to be back here with a question or two. I'm very happy with my purchase as it is.
Old 05-26-2012, 04:46 PM
Highjinx's Avatar
Quoted: 325 Post(s)
Liked: 153
.................mostly for it's allowing me to finally use every inch of my screen real estate............
Totally understandable.
Since you have 4 way masking and a user adjustable lens aperture, I'm eagerly awaiting objective evaluation between two same sized images with no black bars, brightness equalized, one with the lens in place and the other without.........
Highjinx is offline
Old 05-27-2012, 02:04 AM
RapalloAV's Avatar
Quoted: 1302 Post(s)
Liked: 292
Looks like you may have finally seen the light Rich!
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
