Hypothetical A-Lens Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-10-2012, 01:50 PM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
I had a question regarding throw and lens size....this is a bit theoretical and NOT a practical issue I'm dealing with. I don't have an A-lens yet but I'm planing to for my upcoming build.
I know I need to fit the beam inside the lens. Assuming a long throw ratio of say 2.2+....My question is can we get the beam too small? In other words if we are using only the middle on the lens will it modify the horizontal stretch enough to make a difference?
Thanks for your thoughts
Here is my build thread:
---->Like a Boss Theater Build<----
Yzfbossman is offline
post #2 of 4 Old 05-12-2012, 09:37 AM
Gary Lightfoot's Avatar
Quoted: 593 Post(s)
Liked: 349
I've never heard of it being a problem, and there is a member here with a JVC and ISCO II lens who is using a throw of around 2.8 IIRC, and he'd never mentioned any issues.
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #3 of 4 Old 05-12-2012, 07:53 PM
Mike Garrett's Avatar
Quoted: 5584 Post(s)
Liked: 3565
With 2.2, you certainly would not have to worry about that, beside I don't think it would ever be an issue. With 2.2, you would be able to use a flat screen with little geometry issues.
mjgarrett100@gmail.com
Mike Garrett is offline
post #4 of 4 Old 05-14-2012, 09:09 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Generally speaking, and assuming your lens has uniform expansion, the smaller the beam, the better.
GetGray is offline
Reply 2.35:1 Constant Image Height Chat
