Help Prismasonic 5000m - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-22-2012, 02:09 PM - Thread Starter
Cinema Gary's Avatar
I have my set up with the Themscene HD80 with the prismasonic HD5000M prism anamorphic lens, it has great even sharp focus corner to corner when on scope, but when I set it to pass to show 16:9 the image is off center on my scope screen
I took the lens away it is ceiling mounted as is the projector and the 16:9 image without the lens is centered on the screen, when I put the lens in front and set it to pass mode its off center
I predominately watch scope movies but I do have a number of 16:9 movies that I do want to watch, does anybody have any ideas suggestions etc would be most welcome
Cinema Gary is offline
post #2 of 11 Old 06-03-2012, 12:51 PM
CRGINC's Avatar
Might be able to help you. I have a 1500 that is somewhat smaller but similar enough. There are to knobs to adjust the stretch. Inside the lens there are stops on both knobs. Sounds like one of the stops is out of adjustment. This would certainly cause the problem you describe. In my lens the stops are accessible from the rear of the lens. For the front adjustment I had to remove the astigmatism lens to get access. I am sure there are some instructions on the Prismasonic website, in the manual or you could email them.
CRGINC is offline
post #3 of 11 Old 07-12-2012, 03:16 AM
woosha188's Avatar
Hi Cinema Gary
I bought the same lens and also have the same issue. I don't believe the internal stops will help! Did you find a soulotion?
woosha188 is online now
post #4 of 11 Old 07-12-2012, 09:36 AM
stanger89's Avatar
Quoted: 3566 Post(s)
Liked: 1978
stanger89 is offline
post #5 of 11 Old 07-12-2012, 12:44 PM
CRGINC's Avatar
There are four adjustments or stops. two are in the back and the other two are behind the focus lens. Have you adjusted all of the stops? The ones in the rear are easy to adjust but the ones in the front require removing the focus lens for access.
CRGINC is offline
post #6 of 11 Old 07-12-2012, 12:55 PM
stanger89's Avatar
Liked: 1978
Yeah, basically what I did was adjust move the lens fully to the "mode" that was off center, at which point two of the four stop screws should be touching the lenses. Then you adjust one of those two in (towards the lens) and the other out) away from the lens, which shifts both lenses the same direction, keeping them roughly in the same orientation relative to one another, but shifts the image.
post #7 of 11 Old 07-20-2012, 02:13 PM - Thread Starter
Thanks for your input I have not had access to the internet for just over a week.... frown.gif
In your post which stop screws are you adjusting are they the ones behind the focus lens at the front, or the ones at the rear where the projector image goes into the lens and which stops are they to get the image centred could you be more specific smile.gif
post #8 of 11 Old 07-22-2012, 02:12 PM
stanger89's Avatar
Liked: 1978
You have to adjust both. There are 4 stop screws, two for each prism. One pair are used (touched) when the lens is in stretch mode, the other two are used for pass mode. You put the lens in to pass mode and then you adjust the two stops that are touching the prisms (one on each prism).
Cinema Gary likes this.
post #9 of 11 Old 07-25-2012, 04:18 AM - Thread Starter
thank you for the response so i can understand as i am new to anamorphic lenses, I need adjust all the stops in the rear and front of the lens till the 16:9 image is centered ?
But the scope image will not need any adjustment am i correct in thinking that ?
post #10 of 11 Old 07-25-2012, 04:36 AM
stanger89's Avatar
Liked: 1978
Almost, there's one pair of stops (one for each prism) that stop the prisms in pass mode (16:9) and one pair that stop them at the other end of travel for scope/stretch mode (2.37:1). So basically whichever mode is "wrong" you put the lens in that mode, and then adjust the stops to fix it. If it's shifted, you screw one in (toward the prism) and the other out/away from it.
That's the other set of stops, so if you don't change those, that "mode" won't change.
post #11 of 11 Old 07-25-2012, 06:46 AM
Mike Garrett's Avatar
Quoted: 6949 Post(s)
Liked: 4633
Here is the owners manual for this lens: http://www.prismasonic.com/pdf/hd5000m_manual_web.pdf It basically tells you what was discussed above. Thought that you might want the link for future reference.
mjgarrett100@gmail.com
Mike Garrett is online now
Reply 2.35:1 Constant Image Height Chat
