My turn to beat on the 2.37 vs 2.35 vs 2.40 discussion w/ a 1.33x lens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-30-2012, 09:55 AM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
I know that this is not a make or break deal for CIHand typing this out makes me realize more that they all will work fine..but here we go
Ok if I use an ISCO IIIs 1.33x lens and a CIH set up.that's a 2.37?
So no matter the content (assuming I want true CIHno zoom adjustment for each format) I'm physically bound by a 1.78 image chip and a lens that expands 1.33x.
1.78 chip X 1.33 lens = 2.37 projected image
If I'm looking at a 53 tall screen my math tells me this:
2.35 = 124.55 wide
2.37 = 125.60 wide
2.40 = 127.20 wide
So 2.37..or go with a 2.35 and spill .5 on each side?
It seems like a 2.40 screen is just setting up to have very very small black bars on the side or the need to spill a very small bit on top and bottom.
Am I missing anything?
Lastly at a 2.15 TR how much pincushion will I have?
Thanks!!!
Here is my build thread:
---->Like a Boss Theater Build<----
Yzfbossman is offline
post #2 of 6 Old 05-31-2012, 03:33 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Double post
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #3 of 6 Old 05-31-2012, 03:35 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Originally Posted by Yzfbossman View Post
Ok if I use an ISCO IIIs 1.33x lens and a CIH set up….that’s a 2.37?
Yes, but in theory only.
All anamorphic lenses and adapters will introduce a degree (small as it may be) of grid distortion. So pending how much, the said 2.37 image may actually be 2.40 or wider when measured. GD is also made worse with shorter throw ratios (as is Pincushion Distortion).
Will you project into a flat screen or a curved screen? A curved screen optically compresses the image (to a very small degree) which may assist to cancel out grid distortion.
When I curved my screen, the goal was just to correct pincushion, but as it turns out, it also helps with GD and even though my lens has multi-aspheric ground glass lenses (technically they are ground to correct for GD), there is still going to be some GD when projected onto a flat screen. There is none on my curved screen.
Mark Techer
CAVX is offline
post #4 of 6 Old 05-31-2012, 08:38 AM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
I thought that might be the casemore than two variables
I just got my used ISCO IIIs & Cineslide in yesterday! so my set up *as of now* (all is subject to change) will be Epson 6010 to ISCO IIIs to flat AT 53 high micro perf 1.3 screen. My TR is 2.20
Will my long TR help the pincushion and GD? Also any guess on what that does to the aspect ratio?
Thanks for all your input into the forum Mark!
post #5 of 6 Old 05-31-2012, 04:23 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
It wasn't that long ago when we were all concerned about CA and Astigmatism. Of course with a properly ground glass lens like the ISCO III (or my MK5), these issues are no longer a concern. Yet even with the best in optics, we seem to need to find something wrong - hence Grid Distortion.
Congrats on the purchase. It is a great combo and will serve you well, regardless of how many projectors you upgrade.
You will still have pincushion and GD, but the amounts will be so small that I doubt you will see any signs of this in actual video program. Load test patterns and I am sure you will see something.
Mark Techer
CAVX is offline
post #6 of 6 Old 05-31-2012, 06:38 PM - Thread Starter
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
Thanks Mark!
Reply 2.35:1 Constant Image Height Chat
