ISCO Anamorphic Projector Widescreen Lens 1.33x S w - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 07-27-2012, 09:04 PM - Thread Starter
RapalloAV's Avatar
Quoted: 1299 Post(s)
Liked: 292
How far down the food chain was this model and how old is it?
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #2 of 18 Old 07-28-2012, 07:02 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
If it is the A-Lens I think it is, the S stands for small. Its glass design should be identical to the L and M units. Probably about 3 years old now. Performance should be on par with the larger versions.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #3 of 18 Old 07-31-2012, 04:57 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Don't know about the "w" on the end of your subject line, but that implys a "medium" size Schneider/Isco "IIIS" ( = M). The IIIS is a smaller than Ton'ys XEIT lens.
GetGray is offline
post #4 of 18 Old 08-01-2012, 01:19 AM - Thread Starter
RapalloAV's Avatar
Liked: 292
I now know the "W" was not meant to be on the end, the lens is a "S" small.
Murray Thompson
X Owner RapalloAV
post #5 of 18 Old 08-01-2012, 06:03 AM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
No, not a "small". To be clear, the lens is a S, medium. I personally named that lens. Isco was going to call it the Isco II again, and I told them that would be a mistake since there was already the older out of production "Isco II" with a lower performance conotation. They agreed and we called it the IIIS. "S" for smaller than the "L" of the IIIL but of the same design.
The "M" came later when Isco began making/branding the lenses for Schneider who had the tiny CineDigitar. They thought to avoid confusion in thier line they named the Schneider branded lenses "M" and "XL", which was confusing IMO, but Schneider didn't take input from me like Isco did. The Isco IIIS and the Schneider "M" are the same lens, made by the same machines and poeple, with a different focus ring. Identical size glass. Both are "medium" in size.
Cheers
GetGray is offline
post #6 of 18 Old 08-01-2012, 01:57 PM - Thread Starter
RapalloAV's Avatar
Liked: 292
Cheers
Thats very interesting and also very confusing...ha!
Nice to know the truth that the "S" is not really a small lens and in the end its actually the same lens as the Schneider "M", its a good lens and will work with most projectors just as the "M" does.
Murray Thompson
X Owner RapalloAV
post #7 of 18 Old 08-01-2012, 02:03 PM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Yep. "Fit" depends on throw ratio and the PJ technology (panel size), and lens recess (e.g Sim2 C3X chassis). It will fit anything the Sch M fits as they are identical in size. Since you are in AU I'd point out the XEIT will fit a few more as it's larger. The Isco IIIL (now changed to the Isco 4XL) fits most everything.
GetGray is offline
post #8 of 18 Old 08-01-2012, 02:38 PM - Thread Starter
RapalloAV's Avatar
Liked: 292
Ok good to know!
Murray Thompson
X Owner RapalloAV
post #9 of 18 Old 08-05-2012, 12:37 PM
Home Alone's Avatar
Anyone have some info on the following lens?
Runco WideVisionTM Cinema Grade Anamorphic Lens 720p 2.35:1.
Looks alot like an ISCO III. Is there a difference between ISCO III and IIIL?
Home Alone is offline
post #10 of 18 Old 08-05-2012, 03:42 PM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Show me some pictures and I can tell you what it is. There is no "III", only a "IIIL" or a "IIIS".
GetGray is offline
post #11 of 18 Old 08-05-2012, 04:41 PM
Home Alone's Avatar
Thanks for the help. Much appreciated.
post #12 of 18 Old 09-04-2012, 04:41 PM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Sorry, I missed your photo post. I need to see it from the side. That should do it but preferably with a size reference in the photo to be positive. Like a DVD laying beside it for example.
GetGray is offline
post #13 of 18 Old 02-12-2016, 03:36 PM
gitongisip's Avatar
Quoted: 52 Post(s)
will you be able to tell me if this is an Isco IIIs? Marantz used to sell this back in 2007-2008.
http://www.amazon.com/Marantz-Motori.../dp/B002AKKKSA
gitongisip is offline
post #14 of 18 Old 02-12-2016, 05:22 PM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
That is a IIIL. No longer in production. Replaced by the slightly larger cased Isco 4 XL. Which is now only branded as Schneider XL. All of which have the same size glass. Isco still makes them (as Schnieder's anamorphic division).
GetGray is offline
post #15 of 18 Old 02-17-2016, 11:55 AM
gitongisip's Avatar
Quoted: 52 Post(s)
The new Jvc's will not vertically stretch 4K content, only 2k. Unless I'm doing something wrong. I'll stay with zooming for now.
post #16 of 18 Old 02-17-2016, 12:25 PM
Seegs108's Avatar
Quoted: 4195 Post(s)
Liked: 2084
I'll have to test this feature out later, but I'm fairly certain you can still use the anamorphic stretch with a 4K input with these new JVC units.
Seegs108 is online now
post #17 of 18 Old 02-17-2016, 01:12 PM
gitongisip's Avatar
Quoted: 52 Post(s)
Thank you. Btw, my device is Roku4 directly connected to the rs400 with the latest hdmi 3ft cable. Display Output of the roku4 is set to 4K 10bit. Source is Netflix & YouTube.
post #18 of 18 Old 02-17-2016, 03:06 PM
stanger89's Avatar
Quoted: 2628 Post(s)
Liked: 1352
I was thinking, but I don't remember where I saw it, that it will stretch 4K24, but not 4K60. The Roku may be outputting 4K60 for everything.
stanger89 is online now
Reply 2.35:1 Constant Image Height Chat
