ISCO-ii suitable for RS-1? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-29-2012, 03:34 PM - Thread Starter
Gunnar's Avatar
Quoted: 13 Post(s)
Throw will probably be about 2. Radiance-XD processor.
Gunnar is offline
post #2 of 9 Old 07-30-2012, 06:49 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
Based on what I have read that should work just fine. The RS1 doesn't have the recessed lens of the newer JVC's so you don't have that problem to contend with. A throw of 2.0 should be plenty long enough to avoid the most obvious of bowing and pincushion but you may still have some.
dropzone7 is offline
post #3 of 9 Old 07-30-2012, 12:53 PM
Gary Lightfoot's Avatar
Quoted: 624 Post(s)
Liked: 367
I tried an ISCO II in front of an HD100 and it was fine other than some pincushion (which is always present to some degree). I think the HD1 and 100 are very similar in construction IIRC so you'll be fine
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is online now
post #4 of 9 Old 07-30-2012, 01:18 PM - Thread Starter
Gunnar's Avatar
Quoted: 13 Post(s)
Thanks! though I`m a bit hesitant, since I`m not sure if it would be better to spend the money on a new projector? Not sure how the RS-1 compares to a eg. Sony VPL-HW30? I`m not yet interested in 3D, so I might skip a PJ generation or two..
Gunnar is offline
post #5 of 9 Old 07-30-2012, 01:59 PM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
That depends on what your ultimate goal is I suppose. If you don't already have a lens and want to do scope then I would buy the best lens you can afford and upgrade the projector later if you already have something to use. Projectors change so often that you can wait a few months and buy what was the latest and greatest at a discount, especially if you don't mind used. Lenses are not really changing much so I would put your money in the best lens you can find. Of course, I did pretty much the opposite but if I had it to over again I would take my own advice. I had an RS1 briefly and it was very nice, solid built projector and I probably would have kept it a while had I not found a great deal on an HD350 (RS10).
post #6 of 9 Old 07-30-2012, 03:29 PM - Thread Starter
Gunnar's Avatar
Quoted: 13 Post(s)
I`ve been very happy with the RS-1, got it new 2007, and still only 600 hours on the original bulb!
As an previous CRTer I read your thread at http://www.avsforum.com/t/1325257/help-an-old-crt-user-with-transitioning-to-digital-and-cih/120 with interest.
I like to experiment and DIY, and it would be nice to try a CIH-setup w/lens and maybe a curved screen. I`m currently thinking AT or not. My seating distance from the front row will be only about 10' and I`m a bit worried about visible structure. The room is about 16x11'. I can increase the throw a bit by making a hole in the back wall for the projector. Currently it sits on a shelf on the back wall.
Gunnar is offline
post #7 of 9 Old 08-13-2012, 01:52 PM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
That's actually about the size of my room. (16' x 12'). So your throw is about 16' minus the shelf depth the projecctor sits on now? What size screen would you plan on for CIH?
post #8 of 9 Old 08-13-2012, 02:42 PM - Thread Starter
Gunnar's Avatar
Quoted: 13 Post(s)
About 280cm is the widest I can go, since I need to leave some space at the sides for the side masking system. Also, there is some space behind the screen, but not in the full width of the room. So the separation between the L and R speakers is only about 185cm without building a false wall. But then my throw and seating distance will suffer. Grr..
Since my previous post I got a great deal (hopefully..) on a X30 (RS45) projector. Will pick it up wednesday. Possibly later also an ISCO-ii, but I`m not sure it will be compatible with the recessed lens of the X30? I did a quick search, and at least I found a German that use a ISCO-ii with a X30. Seems that he was ok, but my German isn`t that great..
Gunnar is offline
post #9 of 9 Old 09-06-2012, 01:21 PM - Thread Starter
Gunnar's Avatar
Quoted: 13 Post(s)
I got the ISCO-ii, and the X30. Have tried it briefly with the ISCO-ii, and it works just fine. Throw is about 2. Pincushion at the sides is about 1-1,5cm. Picture size was about 2,8m wide, 2,35:1.
I decided on a curved frame from square steel tubes with DIY-masking and a motorized DIY-lift for the lens. Will start a new thread when I have something to show..
Gunnar is offline
Reply 2.35:1 Constant Image Height Chat
