Genuine 2.35:1 test patterns Blu Ray - AVS Forum | Home Theater Discussions And Reviews
Old 08-13-2012, 09:32 AM - Thread Starter
Cinema Gary's Avatar
Is there anybody producing any discs with an genuine anamorphic test patterns rolleyes.gif
Cinema Gary is offline
Old 08-13-2012, 10:51 AM
Josh Z's Avatar
Quoted: 2143 Post(s)
Liked: 1439
What did you have in mind? Do you just need a geometry pattern? I'd think that most other common test patterns would still be usable, even if stretched.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
Old 08-14-2012, 02:54 AM - Thread Starter
I remember seeing one on this forum I think it was the Home Theater Brothers and it had color bars and circles and a grid pattern all in one, I wondered if its available on blu ray rolleyes.gif
Old 08-14-2012, 04:43 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
That was a 720 pattern they borrowed from the HCFR site. If you want a true 1920 x 1080 anamorphic pattern, then use Paint and follow these steps (for W7).
  1. Open Paint > Properties > pixels.
  2. enter 1920 for width and 1080 for height
  3. You can now start drawing your pattern with single display lines for a 1080P projector.
  4. To make it anamorphic, you need to draw your circles as 300 x 400 pixel ovals. If you want to make them larger, you need to work off the height and times that by 0.75 to find the width.
You can create a PLUGE and grey scale steps (Ramps) to add to your pattern as well if you want.
If your PC has a HDMI out, you can connect to the projector (either direct or via your AVR) and use the window key + P to select "projector only". This will ensure that you map 1:1. If you duplicate, the projector feed will be what ever your PC monitor rez is and will use scaling resulting in a less sharp image.
Hope that helps
Mark Techer
I love my Constant Image Height system!
CAVX is offline
Old 08-14-2012, 06:55 AM - Thread Starter
Old 08-20-2012, 05:28 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Your welcome smile.gif Did that work out for you?
Mark Techer
CAVX is offline
Old 08-22-2012, 12:42 PM - Thread Starter
yes worked out great
Old 08-23-2012, 04:15 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Awesome! Now if you want a sample of true anamorphic video at 1080P, you can see my Anamorphic Bees footage HERE Just make sure to select 1080P and allow a decent buffer smile.gif
Mark Techer
CAVX is offline
