Anamorphic lens or new PJ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 08-30-2012, 10:36 PM - Thread Starter
bass addict's Avatar
Quoted: 447 Post(s)
Liked: 510
I always chuckle at these threads but I'm bored tonight and would love to hear some input. I'm just finishing up my 2.35 setup and am kind of in a quandry on which way I want to go. I've found a nice anamorphic lens for about a grand to mate up with my JVS RS20. Part of me is thinking about going with the zoom method and upgrading the projector to say a new Epson 5010 or thereabouts.
In your opinion; which one do you think would offer the better presentation? I really like the idea of a lens, but would love a brighter pj as well. I don't care at all for 3d, so this has no bearing on my decision.
Travis
Achievement Unlocked
Psychotic Episode Averted
bass addict is online now
post #2 of 15 Old 08-30-2012, 11:04 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
What A-Lens is it? Optics pending, you may be better off zooming.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #3 of 15 Old 08-31-2012, 07:54 AM - Thread Starter
Quoted: 447 Post(s)
Liked: 510
PANAMORPH FVX200J
post #4 of 15 Old 08-31-2012, 08:01 AM
Josh Z's Avatar
Quoted: 2475 Post(s)
Liked: 1627
In principle, I would say that upgrading your projector would give you more bang-for-your-buck than adding a lens.
However, other than 3D, which you've said you're not interested in, I'm not really sure how an Epson LCD could be considered an upgrade from a JVC D-ILA.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
post #5 of 15 Old 08-31-2012, 08:44 AM - Thread Starter
Quoted: 447 Post(s)
Liked: 510
I was just throwing out one of many I've checked into. Truth be told, I'm sure I will stay in the JVC family for some time to come. I looked into an RS45, but didn't see enough improvement to justify upgrading.
The only thing I would like out of my RS20 would be a little more brightness. I'd love to have grabbed a 35 but wasn't in the cards at the time.
post #6 of 15 Old 08-31-2012, 12:27 PM
Josh Z's Avatar
Liked: 1627
Order a Darblet from AVS. It won't actually make your picture brighter, but it helps a little with perceived contrast and detail. For less than $300, it's a great tweak.
Josh Z
post #7 of 15 Old 08-31-2012, 03:17 PM
Mike Garrett's Avatar
Quoted: 7079 Post(s)
Liked: 4781
The PANAMORPH FVX200 lens is a fixed in place lens and will not work with the Epson 5010. The FVX200ED works with the Epson 6010. Though once used to the native contrast of the JVC, it might be hard to switch.
mjgarrett100@gmail.com
Mike Garrett is online now
post #8 of 15 Old 08-31-2012, 06:52 PM
mbw23air's Avatar
Quoted: 198 Post(s)
Liked: 169
What screen do you have now? A Da-lite high power might be an option to give you more brightness because you are right a RS45 wouldn't be enough of an upgrade from your RS20 if any to justify it. I have a 1.5 gain(although some have reported it measures closer to 1) 2.35 screen and I also have a 1.78 2.4 high power pull down screen. The gain difference between the 2 is very noticeable. I plan on upgrading my 2.35 screen to a bigger one and I will be getting the high power material for it for the added brightness.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, 2 Behringer B1200D Mid Bass Modules, Buttkicker transducer, Oppo BDP-93 blu-ray player
mbw23air is offline
post #9 of 15 Old 08-31-2012, 06:55 PM
mbw23air's Avatar
Quoted: 198 Post(s)
Liked: 169
Oh, and +1 on the Darblet. Call Mike at AV Science, it's an instant upgrade to your pq.
Mike
mbw23air is offline
post #10 of 15 Old 08-31-2012, 09:41 PM - Thread Starter
Quoted: 447 Post(s)
Liked: 510
Thanks guys, I'll look into the Darblet.
Screen is a 115" diag center stage XD. I'm really sold on having my speakers behind the screen with three towers for a front stage. Couldn't go back.
post #11 of 15 Old 09-01-2012, 08:30 PM - Thread Starter
Quoted: 447 Post(s)
Liked: 510
Well I decided to contribute some more to the economy and pick up the lens as well as the darblet. Also ordered another bulb for the 20. Better get the theater finished up quickly, lol.
post #12 of 15 Old 09-02-2012, 06:11 AM
Liked: 4781
What lens did you get? Also what is your throw distance?
post #13 of 15 Old 09-02-2012, 09:18 AM - Thread Starter
Quoted: 447 Post(s)
Liked: 510
I picked up the FVX200J. From the front of the A lens to the screen will be right at 18'. For a 105" wide screen that gives me a throw distance of 2.05 if I understand the math right. From what I read on Panamorphs website, this should put it in the sweet spot of the range. Yes?
post #14 of 15 Old 09-03-2012, 10:09 AM
Liked: 4781
Your lens throw ratio is 2.72 if using a 2.35 screen and 2.78 if using 2.40. 18' will work fine on a flat screen. Your pincushion will be a little over 1/4".
post #15 of 15 Old 09-04-2012, 02:59 PM - Thread Starter
Quoted: 447 Post(s)
Liked: 510
Thanks. Do you have the formula for calculating that? Apparently I'm using the wrong one. smile.gif
I'm glad that's all the amount of "barrel distortion" I'll get, as curved screens won't work with VC lenses.
Reply 2.35:1 Constant Image Height Chat
