2:37.1 screen calculator - AVS Forum | Home Theater Discussions And Reviews
Old 09-14-2012, 05:12 PM - Thread Starter
RapalloAV's Avatar
Quoted: 1310 Post(s)
Liked: 292
BTW I used Kens 2:37.1 screen calculator to work out my screen sizes, I then had my screen made to "my true 2:37 size" http://tripp.com.au/avscrns.htm
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is online now
Old 09-22-2012, 12:16 PM
Gary Lightfoot's Avatar
Quoted: 621 Post(s)
Liked: 364
Ken seems to have fallen into the trap of thinking that THXs 36 degrees is their optimum seating distance, when in fact it's where they recommend the furthest seat (back row) should be. They actually recommend 2.4 x the screen height for max immersion/image quality with good 1080 material which is 40 degrees for full HD 16:9 which works out as around 52 degrees for 2.35 screens when viewed from the same seat in a CIH set up.
http://www.thx.com/consumer/home-entertainment/home-theater/hdtv-set-up/
The link I used to use for THX specs no longer seems to work, but this link to the THX Theatre Alignment Program has all the info you need in it. Section III part 5 contains the relevant info:
http://www.film-tech.com/warehouse/manuals/TAPGUIDELINES.pdf
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
