New Panamorph Lens Coming Soon - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #151 of 175 Old 07-03-2013, 07:20 AM
Gary Lightfoot's Avatar
Quoted: 593 Post(s)
Liked: 349
If as John says the Cinevista is astigmatism corrected, and the MKII isn't (and you can't get the corrector element any more - pm Mark/CAVX for info), then you should have a sharper image with the Cinevista, so an upgrade smile.gif
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #152 of 175 Old 07-03-2013, 10:56 AM
John Schuermann's Avatar
Quoted: 818 Post(s)
Liked: 782
Thanks, Gary. Yes, the CineVista is astigmatism corrected for its recommended throw range (approximately 6 - 18 feet, with optimal sharpness between 8 - 14 feet).
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is offline
post #153 of 175 Old 07-03-2013, 11:16 AM
snowkarver's Avatar
Liked: 47
Took out my new CineVista last night and fired up the 8350 for a rough test (aka balancing the lens on foam blocks and projecting on the unfinished screenwall). The picture looks huge - there's definitely a fun immersion factor with scope. smile.gif
No vignetting with the full zoom I need. At a 2.5x height throw ratio, the pincushion is pretty atrocious - no surprise there - although with video content and proper masking I can see how even this level of distortion effectively disappears in a real-world viewing context. There is noticeable CA fringing at the far edges (no electronic correction on the 8350), although the middle half is laudably sharp. Fine for movies and FPS games, not so much for web browsing and test patterns.
I'm glad I decided to go with a curved screen, which will hopefully go some way towards correcting the worst of the pincushion.
I don't think the CV will satisfy demanding users, but for what it is - an entry level product for folks like me just getting started with this level of imaging and either unable or unwilling to zoom, I think it's a very nice option to have.
Theater for Hobbits 1.0 - One of the smallest-ever (13' x 8' x 6'8") AVS builds!
Theater for Hobbits 2.0 - AVS HT of the Month - This time it's 2.35 CIH in a 10' x 10' alcove!
snowkarver is offline
post #154 of 175 Old 07-03-2013, 12:29 PM
kgveteran's Avatar
Quoted: 364 Post(s)
Liked: 130
Hmmm. I think i will be using the MKII at first.
Maybe CAVX will chime in....
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is online now
post #155 of 175 Old 07-21-2013, 06:22 PM
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
What about the FVX200?
Bardia is offline
post #156 of 175 Old 07-21-2013, 10:02 PM
Quoted: 818 Post(s)
Liked: 782
All Panamorph lenses are astigmatism corrected.
Throw distance specs for all Panamorph lenses are here:
http://www.panamorph.com/8-support/lens-comparison
John Schuermann
post #157 of 175 Old 07-23-2013, 07:08 AM
Keith AP's Avatar
Quoted: 21 Post(s)
Liked: 26
Any chance you could post an image or two illustrating the pincushion in your environment (and perhaps one showing real-world image)? I have similar setup parameters in my environment and am considering the Cinevista.
Marantz AV7702mkII - Emotiva XPA-5 Gen3
BenQ W1070 w/ Panamorph CineVista Lens - Oppo BDP-103
PSA MTM-210 (L/C/R) - Polk Monitor 35B (SR/SL) - HSU VTF-3MK5 (dual subs)
Keith AP is offline
post #158 of 175 Old 07-23-2013, 09:02 AM
Quoted: 818 Post(s)
Liked: 782
Similar in terms of throw ratio? I ask because the amount of pin cushion is strictly related to throw ratio, and is pretty consistent from lens to lens (in other words, the CineVista has no more or less pincushion than any other anamorphic lens at the same throw ratio). Shorter throw ratio = more pincushion, longer throw ratio = less pincushion. Ideally you would be at at least 3x the screen height or further back.
Good luck!
John Schuermann
post #159 of 175 Old 07-23-2013, 09:23 AM
snowkarver's Avatar
Liked: 47
Sorry, I guess I should have taken a couple of quick snaps when I had it set up - but I was too busy watching stuff! Everything is boxed up as I am deep into construction. Probably won't have it all out again for at least a month.
I will say this though - John is spot on. I played around and anything under 3.0 on a flat surface I don't think most people would be happy with. I am not a very critical viewer - I'm in it for fun not technical perfection - and am very glad that I decided to spring for a curved screen.
post #160 of 175 Old 07-23-2013, 10:52 PM
Keith AP's Avatar
Quoted: 21 Post(s)
Liked: 26
Good luck!
John, yes a similar throw ratio, 103" from a 41" height screen. Several years ago I had a large theater setup in Colorado using the UH480 and loved it. Since then I've moved and downsized - and am currently "room size challenged".
Another aspect that must be considered is that the lens of my current projector - the Benq W1070 - is recessed 1 1/8" from the front of the unit. What problems might this introduce if any?
What I was hoping to gather from snowkarver was a real-world image at his 2.5 TR to evaluate the effect of pincushion - and whether I might find it objectionable. From the sound of it, a projector's setup grid pattern might really look bad at 2.5 TR, but actual movie content might be passable for now.
Keith AP is offline
post #161 of 175 Old 07-24-2013, 01:36 PM
Quoted: 818 Post(s)
Liked: 782
The CineVista has a large enough aperture that the recessed lens should not make a difference, but your short throw complicates things a bit. You might call Dave or Russell at Panamorph and give them the specifics. The possible issue would be vignetting, where the sides of the image could be cut off. Not likely, but worth a call to tech support.
John Schuermann
post #162 of 175 Old 07-24-2013, 05:32 PM
RLBURNSIDE's Avatar
Quoted: 1554 Post(s)
Liked: 1231
FYI : You can correct Chromatic aberattion from a PC on your desktop as well as movies and games (using either DirectX 8 / 9 / 10 / 11 / or OpenGL). How do I know this? Because I've done it. It's rather trivial to realign the colours at the edges, the hard part was making it work for games. I have currently no incentive to share my work for free, as I don't even own an A-lens currently to test it out with, and there's a bunch more tuning to be done before it's ready for prime time. Each lens is different and you really need to be able to tune the curves to achieve what ECC does on higher end projectors. My BenQ w1070 projector only cost me 850$, I just can't justify spending double that to squeeze out a slightly bigger / brighter image. (as much as I love widescreen)
greg1292 likes this.
RLBURNSIDE is online now
post #163 of 175 Old 07-25-2013, 04:34 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Gary
There was never a corrector for the MK2, only the "CAVX Corrector" for MK3 (MK3+C). MK3 was also corrected for CA.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #164 of 175 Old 08-17-2015, 03:37 PM
crashball's Avatar
I wanted to reach out and get some clarity before locking down my final projector location and seating distance. I've attempted to use some of the online placement calculators but they often have me asking more questions.
I'm very new in the field of projection systems, and lenses especially.
My setup consists of the following:
119" Screen Innovations Black Diamond 0.8 Gain 2.35 aspect ratio screen
Epson 6030UB
CineVista lens with mounting bracket for Epson 6030UB.
I have the flexibility of mounting my projector anywhere between 12' to 18' in my current room.
The calculator on projection central suggests that I mount the projector 16.8', which puts me on the edge of recommended for low ambient light. It claims an fL of 13.
If I adjust the throw range/zoom I can get an fL of 18 at a distance of 13' 2"
What are the pros and cons here...? Please help me understand FL vs. throw/range zoom and how it relates to the Cinevista placement requirements.
I'm very confused - just looking for the most ideal placement option while still maintaining great image brightness and reducing the pin cushion effect caused by the lens.
Much appreciated.
crashball is offline
post #165 of 175 Old 08-17-2015, 07:26 PM
stanger89's Avatar
Quoted: 2644 Post(s)
Liked: 1354
Just ignore the brightness from the online calculator, they're bogus, or maybe more accurately there's really no way to tell if they're remotely close.
Also keep in mind that the calculators don't account for a lens, when you pick 2.35:1 there, it's assuming you're zooming. What you want to do is set the calculator to the height of your screen, and look at things like throw from there.
As far as the lens goes, you generally want to keep your throw as far as possible to minimize the distortions introduced.
Regarding brightness, it's fL = (Lumens/Screen Area)*Gain.
The 6030 should be good for about 600-700Lumens calibrated, you've got a 0.8 gain screen, 35.5 sqft, so... 700/35.5*0.8 ~= 16ftL
Of course that's at mid throw (brightness) so it would be less if you end up at long throw:
http://www.projectorreviews.com/epso...-1/#brightness
stanger89 is online now
post #166 of 175 Old 08-18-2015, 08:57 AM
crashball's Avatar
Thanks! Great guidance.
Ideally I'd like to keep the projector behind or directly above the last row of seating to keep it out of line of sight. that puts me at approximately 18ft.
Anything else I should consider?
post #167 of 175 Old 08-18-2015, 09:32 AM
crashball's Avatar
post #168 of 175 Old 11-12-2015, 08:25 PM
James A. McGahee's Avatar
Quoted: 42 Post(s)
Is there a anamorphic lens available in the under $1K?
Is either Home Theater Brothers or Anamorphic Research still in business. Got a contact?
How about any other lens manufacturer in the same price ranges?
Thanks- PM me here.
James A. McGahee is offline
post #169 of 175 Old 11-13-2015, 05:46 AM
stanger89's Avatar
Liked: 1354
You missed the $995 deal on the Phoenix, but you can still get it for $1195 ($1295 with the mount):
http://www.panamorph.com/phoenix/
And it will be in another league than any of the brands you mentioned.
post #170 of 175 Old 12-12-2015, 10:19 AM
drpete12's Avatar
Quoted: 105 Post(s)
Liked: 44
Hi guys
Need help making a decision and thought you guys could help me. I am currently running a lumagen processor (2144) and a seymourav 130 wide screen (1.1 gain) acoustically transparent 2.35 . Jvc 4910 projector.
I watch 99 percent 2.35 movies but those that are 16/9 I stretch with nls. I am almost completely zoomed out with approx 14-15 feet from lens to screen (Guestimating here).
If I went with an anamorphic lens would I see a significant increase in brightness (Lumen) or not really? I gotta admit I am more of an audio guy then video but still like a nice picture. Is the lens a game changer or one of those purchases that get you 2-3 percent closer to a better system?
I am open to all ideas and suggestions. Thanks for any help
Peter
drpete12 is offline
post #171 of 175 Old 01-20-2016, 04:04 AM
bpassman's Avatar
Quoted: 115 Post(s)
Liked: 46
The websites been updated and MSRP now says $2695! But there is a limited 50% off sale until Jan 29th. And now the UH480 is being discontinued. I suppose if you missed the intro of $995 you'd better grab one now at $1495 before the EOM. Arghhh......I hate sales and love them at the same time.
Brad
AVR Anthen AVM 60 Amp Emotiva XPA-7 & XPA-5 Sources Oppo 103D, FiOS
Speakers Atmos 7.2.4 - TruAudio B23-465s (LCRs), TruAudio B23-265s (SL/R & SB), Dual SVS PC-2000s (Subs), 4 In Ceilings
PJ JVC RS500 Screen 153" DIY 2.35:1 Spandex
My crazy long build Coffered Ceiling
bpassman is offline
post #172 of 175 Old 01-20-2016, 06:52 AM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
How would the new Phoenix lens compare to the the FVX200J for a JVC projector?
I had a UH480 and manual slide, but really did not like moving the lens in/out..and all of the hassles of the large mounting plate, etc. I changed to the FVX200J which I really like and is super easy to mount. Like being able to leave it in place. Would the Phoenix be a big upgrade?
barhoram is offline
post #173 of 175 Old 01-20-2016, 06:53 AM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
barhoram is offline
post #174 of 175 Old 01-20-2016, 07:19 AM
stanger89's Avatar
Liked: 1354
First, you could have just left the UH480 in place.
As for FVX vs Phoenix, they're totally different applications, FVX is a Vertical Compression, the Phoenix is a Horzontal expansion (like the UH480). You'd probably need to move/re-mount your projector.
post #175 of 175 Old 03-25-2016, 09:55 PM
Quoted: 42 Post(s)
I need help with finding an anamorphic lens for an EPSON PowerLite Pro Cinema 6020UB.
I replaced my IN76 with the 6020UB. The anamorphic lens I used with my IN76 is a many year old Home Theater Brothers lens and only cost a few hundred bucks.
Are there any lens available that are at least as good or maybe better in quality and how are they priced?
Suggestions?
I also would like to know what is ECC and does the 6020UB have ECC.
THANKS!!
Reply 2.35:1 Constant Image Height Chat
