New project need advice part 2. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-10-2012, 07:35 PM - Thread Starter
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Call me crazy but going scope with a Qumi Q5:p and have a few questions.
Since the Qumi has no zoom I will be mounting back 156" for a 16X9 image of 128"
and would like to fit it on my curved screen I made for the JVC/HE1500 setup.
I have decided to go with the Panamorph FVX200. For one what would be my TR
and can I pull off a curved screen at this distance?
greg1292 is offline
post #2 of 5 Old 10-11-2012, 09:03 PM - Thread Starter
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
what is the side effects of a curved screen with a VC lens?
greg1292 is offline
post #3 of 5 Old 11-03-2012, 11:55 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 438
I'm surprised no one has commented on this, but if you haven't figured it out yet; you can't use a curved screen with a VC lens.
HE lenses produce pincushion where VC lenses produce barrel distortion. A curved screen with a VC lens would enhance the amount of distortion. You would have to curve the screen backwards to match the barrel distortion, which obviously wouldn't work too well.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #4 of 5 Old 01-18-2013, 08:07 AM - Thread Starter
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
So I am working on a new stage for my scope screen and had a question about my UH480 lens.
My 16x9 image is 96" and with a DPX-1300 is 21ftl projected onto the screen and I know this might
sound dumb but with the lens does the lamberts stay the same on the larger 2:35 scope screen?
greg1292 is offline
post #5 of 5 Old 01-24-2013, 06:06 PM
kmannth's Avatar
How can it, the screen is larger right? You get a drop just much less that a zoom CIH setup.
Find the sq feet of the scope screen (sq inches / 12^2) and do a little math. Lumens / sqft. I there is a lumen loss for the lens as well, check into that for your glass.
Have Fun!
kmannth is offline
Reply 2.35:1 Constant Image Height Chat
