Show us your 2.35 LENS setups - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 40 Old 10-31-2012, 06:14 PM - Thread Starter
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
A long time ago there was thread named the same thing. It had a great deal of outstanding theaters in it with Anamorphic lens setups. For some unknown reason back then the thread got removed. A shame.
Now all the A_lens users out there don't "play" here much anymore, they are content wit their setups. Obviously being from the A-lens is best camp, I thought I'd try to resurrect the content of that old thread and see how well we can reconstruct it.
Whether you have a Isco on a CineSlide, or a Home Theater Brother's lens on a drawer slide, lets catalog the installations out there for others to see. There was one guy with a Lego based lens transport that was pretty interesting.
Please keep the thread on topic. Start tangents in new threads, they are free and easy to start. Lets see how many photos we can get of current A-lens setups. It may be hard these days since so many of the regulars back then aren't here much anymore, they are watching movies smile.gif
So, please post photos of your A_lens setups. A photh of your Projector and lens installation is what this thread should have, not the whole theater, there's the 2.35 setup thread for that. Shel mounts, ceiling mounts, pole mounts, custom shelves, hush boxes, booths, custom PJ mounts, Panamorphs, CAVX, XEIT Schneider and of course Isco. Let's see them all.
Scott
GetGray is offline
post #2 of 40 Old 11-01-2012, 05:37 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
If I remember correctly, I went first last time [with a old trophy lens] so here is my current set up.
Video:
The Projector is a BenQ W6000 calibrated to 6500K with light output measured at 16 FL. Gamma measured at 2.6. I like it.
The Anamorphic Lens is my Aussiemorphic MK5 [cylindrical]
The Mount is a CAVX Projector Station. I am not using a sled at this time and scale everything for CIH.
The Screen is an 8' wide Curved 2.37 AT screen using SmX 2K material.
Audio:
The LCR speakers are my own design and are an active 2 way system. They have amazing dynamics for their size.
The Surrounds are again my own design and are tonally matched the to the LCRs. They are still passive. I would like to upgrade these to active some day.
The Sub-woofers are also my own design and use Peerless XLS driver technology. They move air!
Processing is THX Select 2
The room whilst small is free standing inside an existing room and has total light control. It does not touch any part of the house except the floor. Its internal floor floats as well. I have treated the first 1/3 with sound absorbing material and half treated the remaining 2/3rds of the room. What is interesting about the front is that is no slap echoes, so the only echoes heard here are recorded in the soundtrack. I have also used some diffusion on the back wall which you can see a part of between the two back surrounds.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #3 of 40 Old 11-01-2012, 06:40 AM - Thread Starter
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
You've moved up. Love to see the old setup, too.
GetGray is offline
post #4 of 40 Old 11-01-2012, 10:15 AM
holmern's Avatar
holmern is offline
post #5 of 40 Old 11-01-2012, 10:55 AM
flint350's Avatar
Liked: 36
Good timing on this for me, as I just recently moved my Prismasonic from it's inverted ceiling mount to an upright shelf mount directly in front of the projector.  Even though the Prismasonic is the motorized version that moves the lens from passthru to wide, I changed to a home made mount using a silky smooth sliding Opteka camera slider.  These sliders are normally used for time lapse and other photo-centric movement.  It has a nice base that is large enough for the A-lens and the movement is very soft and smooth, allowing for good positioning and locking in place.  The install is still rough, showing the mark points I determined for movement in and out.  I will be putting a stop on the rail for consistent placement in the near future.  Here are a couple of shots:
1000
1000
1000
Ray
"You cannot reason a person out of a position he did not reason himself into in the first place." -Jonathan Swift
flint350 is offline
post #6 of 40 Old 11-01-2012, 09:16 PM - Thread Starter
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Looks like an Igus linear Bearing. Great linear bearing for a manual slide.
GetGray is offline
post #7 of 40 Old 11-02-2012, 12:00 AM
edfowler's Avatar
Quoted: 152 Post(s)
Liked: 83
Just acquired a Panamorph UH480 and built a box around it to 'camouflage' my latest purchase. One nice benefit to the lens is that, with the added lens and foam insulation around it, it cuts off any sound coming from the projector booth. Now the theater is totally silent.
I built the boxes for the surrounds and just installed the def tech BP/As last weekend. They replaced some Cambridge Audio surrounds and match the def tech BP30s I have across the front. I haven't even fired them up yet to see how they sound.
edfowler is online now
post #8 of 40 Old 11-02-2012, 10:23 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
I'll play....................again, here is my 2.35:1 UH380 a-lens setup on DIY slide thread
Details are in there; aluminum plate slide mech, not too hard to do
http://www.avsforum.com/t/1101036/diy-alum-plate-anamorphic-lens-slide#post_15394629
Also, added end stop for lens in non-used position, 6.5" stroke. I can remove that and get full 12" stroke if I want to remove/service the PJ itself.
Compared to non-painted.
A few more painted.
You can see "hard stop" for the lens "off" position here, I can remove that to fully extend the lens 100% past the PJ if I want to remove the PJ.
130" DIY Curved screen + masking;
Build thread http://www.avsforum.com/t/1029683/diy-curved-screen-with-structural-extruded-aluminum-metal-framing/30#post_15186244
picts during build
final result
mtbdudex is offline
post #9 of 40 Old 11-03-2012, 01:07 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
The current set up [top] and the old set up [bottom].
These two anamorphic setups are complete opposite ends of the scale, so yes it has been a long road to video nirvana smile.gif
Mark Techer
CAVX is offline
post #10 of 40 Old 11-03-2012, 07:10 AM - Thread Starter
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Well, the old one was a clean, good looking install, too. Might as well ask you to post the one in the middle (MK1?). It was a milestone piece as you moved through the options and improvements toward round (IMO).
I've helped a lot of users go from nothing to cylindrical. Some via prisms, this would be a very busy thread if they didn't all reach nirvana and stop "playing" here on the forum smile.gif
GetGray is offline
post #11 of 40 Old 11-04-2012, 01:32 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
The MK1 pretty much looked the same as the MK2 [pictured]. The only real difference was there was a type of anti-reflecting coating on the prisms for MK2 and the stand was about 20mm thinner on the MK1. Same mount and and I made a short slide for MK2.
Then came the MK3 which was corrected for CA and housed in a laser cut plastic case. It was much smaller than the massive MK1 & 2.
I actually used one of these with a CAVX Corrector when I tested the Mits HC9000 3D projector. It worked better than expected, so was used for the time I had that projector.
After MK3 came MK4 and my first venture in true cylindrical optics followed by a case redesign to the MK5.
After MK4 came the CAVX Corrector to enhance the MK3. Not perfect, but a significant improvement.
Mark Techer
CAVX is offline
post #12 of 40 Old 11-04-2012, 08:37 AM - Thread Starter
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Sorry, I meant your square cylindrical. Whatever iteration that was.
GetGray is offline
post #13 of 40 Old 11-04-2012, 09:11 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
The MK4 is in the bottom image of my previous post. It is the heavy little guy I carried around CEDIA in 2010 smile.gif
Mark Techer
CAVX is offline
post #14 of 40 Old 11-06-2012, 03:35 PM
quack724's Avatar
Quoted: 92 Post(s)
Liked: 32
Scott, hopefully you recognize this one.
quack724 is offline
post #15 of 40 Old 11-06-2012, 03:44 PM - Thread Starter
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
You bet I do. Very clean install. You are missing the little gusset caps for the legs though? They dress it up a little.
For others benefit, the lens in the photo above is the new Isco 4/XL.
GetGray is offline
post #16 of 40 Old 11-06-2012, 11:31 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Panamorph U480 and sled, on a JVC RS50, Chief RPA mount.
So glad I bit the bullet on that,, really makes the theater experience special. Although I will admit to choosing films to show for friends that are in scope so I can use the whole setup!
Jeff
jautor is offline
post #17 of 40 Old 11-07-2012, 01:20 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
As these two images show.
When I took these images, the projector was a BenW5000 and I used both the MK4 cylindrical (same optics as MK5) for the top image and an old "trophy lens (MK2?) for the bottom one.
Mark Techer
CAVX is offline
post #18 of 40 Old 11-08-2012, 03:57 PM
Gunnar's Avatar
Quoted: 13 Post(s)
I have a DIY lens lift with an ISCO-II integrated into the back wall of my HT-room. The projector is a JVC X30. The picture shows the lift with the ISCO-II, seen from the room behind the HT-room. Above the lift there is a shelf that hold the projector. The lift is IR-controlled.
Gunnar is offline
post #19 of 40 Old 11-08-2012, 04:34 PM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 152
Cool lift. smile.gif Do you use the X30's lens memory to help with CIH when the lens is moved out of the way? I currently have a HD350 (RS10) and have to manually tweak the zoom (plus shift and focus) for non lens use. I'm getting an X35 soon, so plan to set up the lens memory to help with this.
In the spirit of this thread, I'll find some pictures of my existing setup and edit this post later. smile.gif
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #20 of 40 Old 11-09-2012, 03:22 AM
Gunnar's Avatar
Quoted: 13 Post(s)
Yes, I plan to use the lens memory to compensate for the slight zoom of the A-lens. I`m using Irule and a Global Cache gateway for remote control. Projector and onkyo preamp will be IP-controlled, Lighting and Lumagen Radiance controlled by RS-232, and BD, HD-DVD, lerns lift and screen masking controlled by IR.
Gunnar is offline
post #21 of 40 Old 11-25-2012, 02:48 AM
jabz's Avatar
Quoted: 103 Post(s)
Liked: 61
Here's mine, I had a HTB lens at first now got a Prismasonic HD-6000 cylindrical.
jabz is online now
post #22 of 40 Old 12-17-2012, 07:24 PM
Peter M's Avatar
Quoted: 162 Post(s)
Liked: 177
Hi,
Just put it in last weekend ... finally !!!
Thanks to Mark and Scott !
Cheers,
Peter M is offline
post #23 of 40 Old 12-17-2012, 09:10 PM - Thread Starter
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Looks good Peter. I think you get the record on time from purchase to installation smile.gif
GetGray is offline
post #24 of 40 Old 12-17-2012, 09:25 PM
Peter M's Avatar
Quoted: 162 Post(s)
Liked: 177
Cheers,
Peter M is offline
post #25 of 40 Old 12-17-2012, 09:26 PM
Peter M's Avatar
Quoted: 162 Post(s)
Liked: 177
Cheers,
Peter M is offline
post #26 of 40 Old 12-28-2012, 04:13 AM
MichaelCarey's Avatar
Here are some recent photos of my Aussiemorphic Mk IV / Sony VPL-VW60 projector setup. I recently lowered the projector/lens around 200mm to minimise some trapezoidal geometry issues with the projector. The screen is a 130" OZTS Majestic 2.37:1.
The frame you see hanging from the ceiling behind the projector is the frame from my old home made 16:9 screen. One day it will become an acoustic treatment!
Michael.
Port Lincoln
South Australia
I love watching movies!
HT Flickr Page
MichaelCarey is offline
post #27 of 40 Old 12-28-2012, 06:41 PM
TK Doom's Avatar
DC1 in da house!
Screen on the 15th.
Projector (X75) with screen!
TK Doom
Unreal Tournament Forever
Project Gotham Racing too!
TK Doom is offline
post #28 of 40 Old 01-06-2013, 06:01 PM
Steinmanngd's Avatar
Thanks to GetGray - everything went together well. (ISCO3 and JVC RS40)
Steinmanngd is offline
post #29 of 40 Old 01-16-2013, 12:43 AM
Christian Bergh's Avatar
Please advice your throw distance, scaler, and screen type.
Any problems with soft image or pincushion?
/Christian
Christian Bergh is offline
post #30 of 40 Old 02-25-2013, 08:45 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
/Christian
I can't speak for the owner of the system above. What I can tell you though is that when using a cylindrical anamorphic lens like the ISCO, XEIT or Aussiemorphic (MK4 or MK5) is that image softness is a non issue. These types of anamorphic lenses are not only corrected for CA (ie there is NONE!), they are also corrected for geometry issues like grid distortion. What sets them apart form any other type of anamorphic adapter is the continuously adjustable astigmatism correction which allow the user to focus the vertical and horizontal lines at the same time at any distance.
A prisms based anamorphic adapter may have additional correction elements (usually cylindrical) but the optics are fixed and non adjustable. Therefore what you get is really dependent on the installation and where both the throw ratio and the throw distance come into play.
Hope that helps.
Mark Techer
CAVX is offline
Reply 2.35:1 Constant Image Height Chat
