Anamorphic encoded Blu-Rays on the Horizon ! - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 130 Old 01-18-2014, 08:06 AM
RLBURNSIDE's Avatar
Quoted: 2012 Post(s)
Liked: 1391
They've finalizing the Bluray UHD spec soon, I hope they will support anamorphic formats...any news?
http://www.twice.com/magazine-issue-type/current-issue/blu-ray-disc-association-4k-ultra-hd-blu-ray-way/109597
RLBURNSIDE is offline
post #122 of 130 Old 01-20-2014, 04:46 AM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
Lets hope so. Slightly excited. Not holding breath though.
Mark Techer
I love my Constant Image Height system!
CAVX is online now
post #123 of 130 Old 01-21-2014, 04:58 PM
John Schuermann's Avatar
Quoted: 1373 Post(s)
Liked: 1433
Yes, for sure anamorphic formats are supported smile.gif I sat in on the subcommittee meetings as a representative of Panamorph and pitched hard for anamorphic support. I can't take total credit, though, since there were two others on the committee that backed our proposal. There is support built in for anamorphic 1920 x 1080 HD and 3840 x 2160 *UHD. Getting the studios to release content this way, though, is still the challenge. However, there is good news.
As some of you may know, Panamorph (through Folded Space) has added Deep Color Encoding (DCE) capabilities to our suite of solutions that also includes MFE (MultiFormatEncoding) support for anamorphic Blu-ray. At CES this year we got the preliminary support of a major CE manufacturer for both DCE and MFE. Having a major CE player on our side should give us more influence at the studio level.
Sorry I've been away so long - I've been working on the sound mix and music score for the film "Creep!."
scarabaeus likes this.
John Schuermann is offline
post #124 of 130 Old 01-21-2014, 08:18 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 423 Post(s)
Liked: 447
Hi John. Thank you for the update and promising news. Glad to hear you're also working on a gig.
Cam Man is offline
post #125 of 130 Old 02-07-2014, 10:11 AM
Liked: 1433
For anyone following this, Shawn and I did a complete show on MFE anamorphic Blu-ray and Deep Color Encoding with Scott Wilkinson yesterday:
http://www.avsforum.com/t/1516457/who-wants-more-resolution-color-with-john-schuermann-shawn-kelly#post_24324946
In depth discussion of all of this.
post #126 of 130 Old 02-10-2014, 01:34 AM
230-SEAN's Avatar
Always nice to see progress and more light at the end of a long dark tunnel.
-Sean
230-SEAN is offline
post #127 of 130 Old 01-29-2015, 07:53 AM
BakeApples's Avatar
Quoted: 322 Post(s)
Liked: 172
Will the new UHD Blu-ray format use MFE from FoldedSpace?
BakeApples is offline
post #128 of 130 Old 01-29-2015, 01:05 PM
Liked: 1433
Sorry I've been away so long - I've been hard at work on my first full feature film
This will be extremely quick, as I'm getting ready for a shoot tonight. Folded Space will probably not be a part of the actual spec. However we are still working with interested parties to make it an a feature that can be incorporated into displays and used for mastering appropriate feature films. As I've discussed at length here on this Forum, many films won't actually benefit from higher resolution, whether we are talking about anamorphic or even 4K.
More later but I'm not sure when.
Thanks all!
post #129 of 130 Old 01-29-2015, 03:54 PM
RLBURNSIDE's Avatar
Liked: 1391
Thanks for the update.
At this point I'm wondering, due to the black bars being added by Java, why it would even matter whether it was part of the core specification, since it should be opaque to the user since Java is a mandatory requirement.
I'll do my part and support whatever UHD Blurays come out with Folded Space tech. I can hopefully decode it on my HTPC into full-frame anamorphic so I don't need to buy a new player.
Maybe Oppo would be a good company that could decode Folded Space MFE encoded Blurays. I'm not sure what the benefit of the enhanced color scheme is, since higher bit depths and dynamic range are part of the basic UHD Bluray spec now anyway. Including, I believe, a way to encode the basic disc as rec 709 color space plus metadata that can be used to reconstruct rec 2020 or dci p3.
post #130 of 130 Old 01-29-2015, 08:09 PM
Cam Man's Avatar
Quoted: 423 Post(s)
Liked: 447
Thanks all!
Hmm. Night shoot in Colorado in January. Sounds sporty. I'm sure you know that Tarantino and his gang are over in the Telluride area.
Cam Man is offline
Reply 2.35:1 Constant Image Height Chat
