What screen for basic CIH setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-15-2012, 06:02 PM - Thread Starter
Chriscpm's Avatar
Quoted: 33 Post(s)
I have a 119 inch 16x9 screen that is getting pretty old. 13 years maybe. I was always interested in a CIH screen, but was always turned off by the lens cost and hassle. I updated my projector a couple times over the years and now have a JVC 1080p (an x30 or something from 2011).
I just ran a test of a BR where I zoomed it in and adjusted the height to play a 1.235 movie at the full height. It looks fine to me, so i doubt I'd want to spring for a lens.
With that in mind, what would a good screen be to project to a 60inch or so high screen?
I'm running a da-lite screen with a 1.3 gain. I was never really happy with how easily this thing got smudges and how hard it is to clean. I think its actually not recommended to clean it. I have a motorized masking system now, but would probably just just skip that and do an easy manual mask that I take off for movies. 80%+ of my watching is 16x9, so the scope would be for big occasion movies. I'd rather put the $$ towards a good screen material than fancy motors and lenses.
Any help would be appreciated.
Chris
Chriscpm is offline
post #2 of 12 Old 11-30-2012, 05:51 PM - Thread Starter
Chriscpm's Avatar
Quoted: 33 Post(s)
No comments, but no worries. The screen turned out sweet. It really fills the wall now. The resolution seems fine. I just finished up the good scenes in The Matrix.
Chris
Chriscpm is offline
post #3 of 12 Old 11-30-2012, 05:53 PM - Thread Starter
Chriscpm's Avatar
Quoted: 33 Post(s)
The screen size is 63" high x 148" wide (160.9" diagonal) . I had it made custom from Carada.
Chris
Chriscpm is offline
post #4 of 12 Old 11-30-2012, 06:50 PM
blastermaster's Avatar
Quoted: 430 Post(s)
Liked: 550
Looks good! I had a screen that was very close to a white ceiling. I painted it a dark grey and it really helped to minimize reflections. Not sure if that's a problem for you, but it may be something to consider. I'm guessing you like the aspect ratio now compared to 16:9? Personally I think It's awesome. Grats on your new purchase
Video: Optoma HD3300, Panamorph UH480, Darbee Darblet, Samsung BD D6700 Blu Ray player, DIY Seymour Centerstage XD 138" Curved Screen
LCR - Tannoy DC12i, Sides - Tannoy IW63, Rears - Tannoy Saturn DC6ti Bookshelf, Ceilings - Tannoy CMS 603DC (TF), Tannoy CMS 601DC (TR), 3 Micro Marty/1 Full Marty DIY subs
Amplification: Emotiva XPA-3, Emotiva XPA-2, Outlaw Audio 7700, 2x Inuke 6000DSP
Receiver: Anthem MRX 720
blastermaster is offline
post #5 of 12 Old 12-01-2012, 05:26 AM - Thread Starter
Chriscpm's Avatar
Quoted: 33 Post(s)
Now that you mention it, there is a lot of light on the ceiling. I might try some grey paint. I was originally going to paint the walls a really dark green. Once I did the stairway that color, it seemed too much like a cave, so I went with the lighter brown.
I watched a few more movies. Its pretty sweet. I'd say for a decent Blu-Ray, I don't see the need for a lens. Its pretty much spot on. I'd say every bit as good as a my old 720p projector for a 16x9 movie. There are no smudges that I can see on this one either.
I can't believe how much better wide screen movies look. I need to work up a mask now.
Chris
Chriscpm is offline
post #6 of 12 Old 12-24-2012, 07:15 AM - Thread Starter
Chriscpm's Avatar
Quoted: 33 Post(s)
I've been watching a bunch of movies is scope format. Its pretty sweet. I did some dialing in on a few things. Now its spot on, at least for what it is. Here is a shot in use. Its hard to get good pics, but this gives you the idea.
Like most things, I'm now wanting more. I've been reading up on lenses. I might spring for a cheap one. Either that or just wait for native scope projectors to come down in price.
Chris
Chriscpm is offline
post #7 of 12 Old 12-24-2012, 09:53 AM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 153
That looks good, but IMHO I wouldn't bother trying to find a 'cheap' lens as it will probably put you off lenses altogether. Instead keep your eyes on the classifieds for something like an Isco II ( I use one myself with my X35) or maybe the CAVX Mk4 lens. I'm not so familiar with the Panamorph models, but I'm sure they make some better models with focus correction but hopefully someone else can chime in with recommendations. I once bought a cheap VC lens and it was so bad I couldn't sell it on with a clear conscience so I still have it in a box in my loft.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #8 of 12 Old 12-25-2012, 06:42 AM - Thread Starter
Chriscpm's Avatar
Quoted: 33 Post(s)
Thanks for the tips. I was leaning towards a lens, but then I looked at the prices of the newer JVC projectors. The JVC DLA-X70 dropped from 8k to as low as $5,400. Wow! So would my now almost two year old 1080p projector with a lens looks better than a simulated 4k projector zoomed? Who knows.
I read up on lenses and screens. Even though my screen is flat, I have solid light distribution. I can not see any drop off at the sides. Even with the couch that is up close, it looks solid. I'm a bit on the dark side for movies, but its still pretty good, even with the "low" lamp setting. I did a bunch of tweaks and have it looking even better now.
I sort of stumbled into this. I had a great 720p projector for its day (a Seleco). The JVCs were so cheap in comparison (years later), that I didn't do a whole lot of research. The JVC is so much better. Then that made me think of the scope screen. I did some tests with the zoom, then got the new screen. Now I'm looking to optimize, then maybe even scrap the lower end JVC and get a better one. Its got me all confused. For all the stuff, the longer you push things off, the more you get.
Chris
Chriscpm is offline
post #9 of 12 Old 12-25-2012, 03:41 PM
yourtoys7's Avatar
Looks good, I've been using zoom for years now with my custom made 135" 2:35:1 AT screen and absolutely loving it with Panasonic 4000.
Now that I have JVC X35 it is even more fun, but I might have to redo the screen wit new XD material.
There might be or is benefits to lens, but I just can't justify the price, I would rather put that money into higher end jvc and still zoom., but that's just me.
EluneVision 106" Reference Studio 4K Tab-tensioned - 1.0 Gain, Benq 1070, psb T6, Rotel, OPPO, Velodine (Now),
135" AT screen, JVC-X35, 3x RF82, 3x Emotiva XPA100, Velodine, Rotel, OPPO (Sold with house).
yourtoys7 is offline
post #10 of 12 Old 12-26-2012, 05:09 PM
John Schuermann's Avatar
Quoted: 813 Post(s)
Liked: 781
Another recommendation to paint the ceiling and side walls a dark color. All of the light spill that lights up the ceiling and side walls bounces back to wash out the picture. Doing this single tweak will tremendously improve your contrast.
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is online now
post #11 of 12 Old 12-26-2012, 05:28 PM - Thread Starter
Chriscpm's Avatar
Quoted: 33 Post(s)
Thanks. I've been thinking about painting the walls and ceiling darker. I'm starting to get the bug for the JVC DLA-X70 too.
I watched a few movies today. Two Towers looked great. Then the new Star Trek is exceptional. I brought my good camera down to get some better pics. Here are some that show the rez I'm getting on the big screen. Its really crazy clear, especially for a 160 inch screen. With the detailed photos, you can see how I wedged the screen between the two top cuts. That leaves enough room for eh big Klipsch towers too. The whole screen sit on a shelving unit that came with the house. Then we covered it all in black cloth.
Chris
Chriscpm is offline
post #12 of 12 Old 12-26-2012, 05:50 PM
Quoted: 813 Post(s)
Liked: 781
Looks good! Since you already have the black cloth thing going, have you considered adding black cloth out a few feet to the side walls and out into the room on the ceiling? The improvement in PQ you will get from taming room reflections will probably be greater than upgrading to a higher end projector. Should be cheaper too smile.gif
Also, you are probably getting a pretty strong low mid - upper bass boost from having the speakers in the corners. If your receiver has Audyssey or some kind of room EQ you might run it to compensate for that.
John Schuermann
Reply 2.35:1 Constant Image Height Chat
