Somfy control question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-02-2012, 06:45 PM - Thread Starter
Gomdaf's Avatar
Hoping somebody could help me understand what I would need here. I'm just looking at using 2 somfy tube motors for automated side masking. Trying to stay as low cost as possible. 3 programmed stops would be fine. If I go with the IR version can I control both motors with one remote or do I need another controller? What's the advantage of the RTS versions?
Basically I just want remote control to operate both motors simultaneously with 2-3 programmed stops.
Would this work? http://www.avoutlet.com/index.php?dispatch=products.view&product_id=1444
Gomdaf is offline
post #2 of 2 Old 12-02-2012, 06:48 PM - Thread Starter
Gomdaf's Avatar
Reposted this in DIY section
Gomdaf is offline
Reply 2.35:1 Constant Image Height Chat
