A couple of questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-03-2012, 08:05 PM - Thread Starter
Floydster's Avatar
1. If BR discs were anamorphic, would it be simple to go to a 2:35 to 1 format?
2. Did HD-DVD offer an anamorphic content?
I'm new to front projectors. As soon as the Mits RP set wears out, I was thinking (in fact I have my theater room wired) for front projection. My choice would be a JVC DILA fp. I'm making an assumption that FP is still the best picture available.
Floyd
A lie can travel halfway around the world before the truth gets its shoes on. -- Mark Twain
Floydster is offline
post #2 of 9 Old 12-04-2012, 12:40 PM
Josh Z's Avatar
Quoted: 2146 Post(s)
Liked: 1442
Currently, Blu-rays are not anamorphic. They have 1920x1080 square pixels.
No. It worked the same as Blu-ray.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #3 of 9 Old 12-04-2012, 02:58 PM
rboster's Avatar
Quoted: 906 Post(s)
Liked: 758
Floyd
Five threads down from yours I found this thread that maybe of interest:
http://www.avsforum.com/t/1436729/anamorphic-encoded-blu-rays-on-the-horizon
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
post #4 of 9 Old 12-06-2012, 04:53 AM
CAVX's Avatar
Quoted: 124 Post(s)
Liked: 80
Yes because all the required scaling would be done at the encode of the disc. All you would need is to add an A-lens.
Have a read of the link rboster has added to his post above. I hope they have a win with that.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #5 of 9 Old 12-08-2012, 07:23 PM - Thread Starter
Floydster's Avatar
Why would the BR discs not anamorphic? It seems really stupid to me. I will read all the responses.
Floyd
post #6 of 9 Old 12-08-2012, 07:34 PM - Thread Starter
Floydster's Avatar
I would certainly hope so. I read the thread, and I was shocked to realize that BR discs were not anamorphic.
I had thought that the reason there was no 2:35 to 1 without bars was because when the whole HD standard started the only thing available were CRT TVs.
And no TV CRT could scan a beam that far left to right. Obviously, I was wrong.
Floyd
post #7 of 9 Old 12-09-2012, 05:10 AM
jchusky77's Avatar
Ok..so if the Blu Rays were to coming in 2.35:1 Aspect Ratio already..the A Lens will always be needed in the future, unless a PJ could project it natively. correct?
jchusky77 is offline
post #8 of 9 Old 12-10-2012, 04:21 PM - Thread Starter
Floydster's Avatar
I'm not sure, but I think one anamorphic lens could handle most of the viewing ratios. That's if BR was anamorphic.
post #9 of 9 Old 12-15-2012, 09:13 AM
CAVX's Avatar
Quoted: 124 Post(s)
Liked: 80
Floyd
DVD was essentially a bridging format from 4 x 3 to 16:9. To do this, it used non square pixels where each format (PAL and NTSC) had 720 horizontal pixels, but their height changed to keep the AR 1.33. PAL has 576 and NTSC has 480 (or is that 483?). BD is native 16:9 and uses square pixels. Because it was made for the HD standard of 1920 x 1080, it has a perfect 1:1 matrix of 1920 x 1080. There is simply no need for this format to use anamorphic encoding at the level it was originally designed for.
I would love to see anamorphic encoding used because it would allow wider formats to be integrated into the existing format as well as supporting all ARs down to 1.2:1.
Mark Techer
CAVX is offline
Reply 2.35:1 Constant Image Height Chat
