2:20 on 2:40 screen with Anamorphic Lens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-10-2012, 08:13 AM - Thread Starter
Cinema Gary's Avatar
Is there anything that needs to be done when projecting movies that were originally shot in 70mm through an anmorphic lens, like "Lawerence Of Arabia" and "Chitty,Chitty,Bang,Bang" to preserve the original aspect ratio of the theatrical presentation ?
I am using the Prismasonic HD5000M with the Themscene HD80 and a 90inch wide Screenresearch Acoustcally Transparent 2:40 screeen.
Cinema Gary is offline
post #2 of 2 Old 12-10-2012, 10:01 AM
Josh Z's Avatar
Quoted: 2421 Post(s)
Liked: 1589
If you apply the standard 2.35:1 scaling, you'll crop a little bit of picture off both the top and bottom of the 2.20:1 frame. Depending on the movie, this may or may not be notceable. (Some 70mm movies were composed with some leeway in this area, because the filmmakers knew that the 35mm theatrical prints would be cropped to 2.35:1.)
If you want the height of the image to fill the screen properly, with small pillarbox bars on the sides of the image, a video processor such as those from the Radiance series will allow you to zoom out a couple of steps.
The last I checked, DVDO video processors did not have sufficient aspect ratio controls to accomplish this.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
Reply 2.35:1 Constant Image Height Chat
