150" CinemaScope too big for my view - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 12-18-2012, 10:35 PM - Thread Starter
amb1s1's Avatar
I was planning to do 120 16:9, but lately I'm switching my dream to a CinemaScope screen. So I came with this conclusion that if I'm watching a 16:9 movie or show, the screen will still be 120. The question is, that I have to seating sofa that I'm planning to use. One is going to be at a 10 feet view and the last row is going to be at a 15 feet view. I can modify my first row to be at 12' feet. Is 150 CinemaScope too close for the first and second row?
amb1s1 is offline
post #2 of 16 Old 12-18-2012, 11:08 PM
tgrinch's Avatar
Quoted: 21 Post(s)
Not in my opinion biggrin.gif I have a 133" scope screen (with lens) with around the same seating distances - first row @ ~11' and second row ~15-16'. If I did it over again, I'd go bigger, probably close to 150". If you go that size, just consider if your PJ can get enough brightness for your tastes...
tgrinch is offline
post #3 of 16 Old 12-19-2012, 06:25 AM - Thread Starter
amb1s1's Avatar
I'm planning to buy the panasonic 8000u
amb1s1 is offline
post #4 of 16 Old 12-19-2012, 08:57 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
I also have similar seating distances (~10' and 15.5') and a 136" scope (108" 16x9) screen.
I would NOT go any bigger, as the front row is about as big as you can get without having to move your head around. I was very concerned about the size being too big during construction. Going smaller didn't really change the "feel" from the front row, but did make a negative impact from the 2nd (which is my primary row).
My recommendation is that if at all possible, test the screen size before deciding - use a sheet or photographer backdrop paper to see how it feels to you. After, of course, sizing the projector, etc. I did that, knowing the PJ would be able to handle the screen sizes I expected - and didn't order the screen until I had the room done with the PJ on-hand to validate the setup.
Jeff
jautor is online now
post #5 of 16 Old 12-19-2012, 10:11 AM - Thread Starter
amb1s1's Avatar
I think even if I want it, I wont be able. My room size is 11' 6" and thats without the drywall. I'm thinking going with a screen between 136 to 140.
amb1s1 is offline
post #6 of 16 Old 01-11-2013, 07:34 AM
Shepardos's Avatar
Quoted: 51 Post(s)
is there a formula about the maximum 21:9 screen size and the seat distance?
Shepardos
Shepardos is offline
post #7 of 16 Old 01-14-2013, 10:36 PM
jautor's Avatar
Liked: 777
Use the normal forumulas / guidelines based on your 16:9 screen size, since you'll be using that aspect as well - and, well, by definition here, the screen height remains the same for 2.35 content...
post #8 of 16 Old 01-15-2013, 06:56 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
I agree. Get the projector set up first.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #9 of 16 Old 01-15-2013, 12:51 PM
stanger89's Avatar
Quoted: 2634 Post(s)
Liked: 1354
except a lot of those specify sizes based on 16:9 screen widths, not screen heights so if you go with those you'll end up with a rather small screen.
stanger89 is online now
post #10 of 16 Old 01-16-2013, 07:29 AM
jautor's Avatar
Liked: 777
I'd contend that if you get the 16x9 screen size correct, you have your screen height, and therefore the correct 2.35 size... Now, whether that fits between your walls, well, another issue... biggrin.gif
post #11 of 16 Old 01-16-2013, 08:31 AM
stanger89's Avatar
Liked: 1354
post #12 of 16 Old 01-17-2013, 12:29 PM
coolrda's Avatar
Quoted: 852 Post(s)
Liked: 614
2X-3X screen height will take full advantage of a 1080+A lens projection system and 2.66X-4X SH will give you the comparable pixel density if using the Zoom method with its 800 lines.
coolrda is offline
post #13 of 16 Old 02-15-2013, 07:06 PM
Detees's Avatar
I found this
As I'm having the same problem regarding screen size and viewing distance in 2.35:1 and 16:9, my idea was to optimize the room for 2.35:1 material.
Since thats the main AR I watch and I prioritize. So I will sit in the second (middle) row.
For 16:9 I will sit in the front row, which should give me a more immersive feeling as I'm used to.
My screen is 120" 16:9 now, so I will size that a little up to 137", which give me around 170" in 2.35:1 with the lens.
Detees is offline
post #14 of 16 Old 02-15-2013, 08:40 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
Agreed. If zooming, you will need to work off the image height of the zoomed 16:9 image, not the screen height. Therefore you will have to sit back a bit further than you would if using an A-Lens. Still enjoyable though.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #15 of 16 Old 02-20-2013, 02:08 PM
jautor's Avatar
Liked: 777
That's a big screen, make sure your projector will work at the throw distance you have and be bright enough to be acceptable...
Also, what are you seating distances? Highly recommend you test the size out before committing. I'm about 10' at my front row to a 108" (in 1.85) screen, wouldn't go any bigger than that.
Jeff
post #16 of 16 Old 06-07-2013, 06:55 AM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 41
I'm 11 ft from a 148 in 2.35:1 high power (RS20 & UH480). I love it but theres pincushioning. My 16x9 image is 120 in. Id also suggest trying before buying.
My Theater Room JVC RS4910, Panamorph UH480, 148 in. 2.40:1 Dalite HD Pro 1.3, Klipsch THX Ultra II's x 7, Quad JTR Captivator S1 subs
My Previous Non-Dedicated space
RobZ is offline
Reply 2.35:1 Constant Image Height Chat
