ways to reduce pincushion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 12-22-2012, 08:58 AM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
I have a pretty drastic pincushion with the bottom of my screen but not the top using a Panamorph 480.
My throw is 17'6".
I notice in a lot of pictures that the lens is tilted down a lot. Way more tilted than mine. Is this the best way to reduce pincushion? Physically I would have to raise my projector a few inches to do this but I want to keep lens shift to a minimum.
I may do this if that is what is required, but I don't want to if that isn't the main cause for the pincushion.
I have the light beam entering the center of the back of the lens and exiting the center of the front of the lens.
thanks
ed
FS: Complete theater with two large AT screens - local pick up in Indiana only
edfowler is offline
post #2 of 31 Old 12-22-2012, 09:01 AM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
I am going to build a curved screen this weekend but the pincushion looks to be about 2" at the bottom. I do not know if this will compensate for that much or not. I thought pincushion at this distance wasn't supposed to be this dras
edfowler is offline
post #3 of 31 Old 12-22-2012, 09:01 AM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
I am going to build a curved screen this weekend but the pincushion looks to be about 2" at the bottom. I do not know if this will compensate for that much or not. I thought pincushion at this distance wasn't supposed to be this drasti
edfowler is offline
post #4 of 31 Old 12-22-2012, 09:34 AM
Kelvin1965S's Avatar
Quoted: 283 Post(s)
Liked: 184
I have adjusted my lens tilt so that the pincushion is averaged between top and bottom of the screen: If tilt it in one direction I can have straight lines at either extreme such as the top, but the pincushion is double on the opposite side such as the bottom. With tilt set correctly, then the centre of the screen has no pincushion and it gradually increases towards the top and bottom (not that much in my 2.7 throw set up, but still evened out.
I might be worth you trying to adjust the tilt to see if you can even out the pincushion then it might not be so much of an issue (though curved screens do look cool anyway cool.gif).
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is online now
post #5 of 31 Old 12-22-2012, 01:24 PM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
sounds like I need to raise the pj then and tilt the lens down to try to even out the pincushion top and bottom. thanks mate.
edfowler is offline
post #6 of 31 Old 12-22-2012, 01:56 PM
Quoted: 283 Post(s)
Liked: 184
You need to get the 16:9 image lined up and in focus without the lens, first. Then add the lens and adjust the tilt, roll, focus and angle of the lens to the optimum position. You shouldn't need to adjust the image height using the lens really: With my Isco II the image is lined up first then the lens just expands (and slightly by 5% or so increases the height), but it expands equally on both sides and by the same small amount top and bottom.
post #7 of 31 Old 12-22-2012, 02:12 PM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
the 16:9 image is good. My problem is that I cannot tilt the lens down since I am projecting thru a wall (unless I raise up the pj on the other side of the wall)
edfowler is offline
post #8 of 31 Old 12-23-2012, 12:24 AM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
if you can't tilt the lens without raisng the projector, are you able to drop the lens?
Tilting will allow you to even out the pincushion top to bottom.
A curved screen is the only way to eliminate it, however, if you watch a lot of 16:9 program and move the lens to do so, I would stay with the flat screen.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #9 of 31 Old 12-23-2012, 02:15 PM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
edfowler is offline
post #10 of 31 Old 12-23-2012, 07:26 PM
stanger89's Avatar
Quoted: 3575 Post(s)
Liked: 1999
But, unless I'm mistaken, if you can't tilt the lens to even out the pincushion, even with the curved screen you'll still have pincushion, or at least some sort of distortion.
stanger89 is offline
post #11 of 31 Old 12-23-2012, 10:16 PM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
ok. the curved screen was a kind of aside. Still going to do it cause I think it looks cool. Top and bottom are cut but project had to be put on hold to watch a movie with the wife and her friend.
I have always heard that you want the lens as close to the pj lens as possible so I did not try tilting the lens down due to architectural restrictions. I pulled the lens out in front of the wall and tilted it down and got a uniform picture. So... I am going to tear into the wall so that I can tilt the lens down and still have it right next to the pj lens. I think I will build a pocket so I can just drop the lens into the pocket at the same place every time for scope content and then pull it out for 16:9 content.
I tried zooming again one more time to see if I could just live without the hassle of the lens. I did after all just get a JVC 4810 with the e shift 4k wobulation. Believe me, the added resolution/brightness of the lens still adds a lot to the picture, even with the supposed 4k image of the JVC.
I am wondering how much of an improvement I am going to realize getting the tilt on the lens right? I guess we always are looking for that little something extra.
edfowler is offline
post #12 of 31 Old 12-25-2012, 07:47 AM
Mike Garrett's Avatar
Quoted: 6957 Post(s)
Liked: 4659
What is the size of your screen?
mjgarrett100@gmail.com
Mike Garrett is offline
post #13 of 31 Old 12-25-2012, 09:08 AM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
i just built a curved frame that is 126 wide with a 40' radius.
the old screen was 123 wide i used to watch it masked down to 117 " so the screen is going to be anywhere from 117 to 126 (with a little experimentation)
edfowler is offline
post #14 of 31 Old 12-25-2012, 09:59 PM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
kind of leaning toward 117. Liking the sharper, punchier image thing over the immersive experience thing. (also would not have to buy more screen material)
edfowler is offline
post #15 of 31 Old 12-26-2012, 04:18 PM
John Schuermann's Avatar
Quoted: 1381 Post(s)
Liked: 1435
As you have discovered, the solution here is simple. You just need to tilt the lens to follow the light beam from the projector. It's simply a matter of tilting the lens until the pincushion is even top and bottom.
There are no other real advantages to tilting the lens other than to get the distortion to even out.
John Schuermann is offline
post #16 of 31 Old 12-26-2012, 04:47 PM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
hey John,
really really like your 480. I have tried a couple other lesser lenses before and did not care for them. Looks like the 480 is a keeper.
I'm building a curved screen tonight. after it is done I'll start a build thread in the diy 2.35 section
edfowler is offline
post #17 of 31 Old 12-26-2012, 05:05 PM
Liked: 1435
post #18 of 31 Old 03-16-2013, 06:24 PM
musicalfox's Avatar
Quoted: 16 Post(s)
Not sure if anyone can help me with this? I thought this might be the first thread to try with regards to picture distortion, and a non-anamorphic pincushion effect is my issue. I am getting a very slight pincushion effect in both 16:9 and zoomed 2.35 aspect ratios on an Elite fixed frame 235 screen. I know this is nothing to do with the issue of anamorphic lenses, but using the test pattern during set-up I am finding it very difficult to get the bottom white line to sit perfecting on or slightly above the masking; there is a slight 2 or 3 pixel droop on both left and right sides of the image (but not on the top). I know the screen is not distorted in any way - it is vertical and tensioned flat - so I suspect it must be related to the way the PJ is sitting on its shelf perhaps? I am new to the projector game, so any suggestions would be gratefully received.
musicalfox is offline
post #19 of 31 Old 03-17-2013, 05:30 AM
CAVX's Avatar
Quoted: 223 Post(s)
Liked: 117
In his opening post, he describes his image as has a flat top edge and a curved bottom edge. If he projects onto a curved screen, the top edge will now barrel whilst correcting the bottom, so the image won't be perfect. He needs to get the pincushion even first, then correct that with the curved screen.
Mark Techer
CAVX is offline
post #20 of 31 Old 03-19-2013, 09:33 AM
Liked: 1435
It would help to know which projector you are using, screen size and throw distance. It could be that you are tilting the projector in some way, or that it is not square with the screen. There is also the fact that some projector lenses have some built in pincushion or barrel distortion (the old Screenplay 7200 had quite a bit of barrel distortion in its optics).
Good luck!
post #21 of 31 Old 03-19-2013, 01:25 PM
RapalloAV's Avatar
Quoted: 1627 Post(s)
Liked: 474
If your projector has a pincushion correction, don't use it, they add artefacts!
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #22 of 31 Old 03-19-2013, 09:14 PM
musicalfox's Avatar
Quoted: 16 Post(s)
Good luck!
Thanks, John. My projector is the Epson 6010 with a 9ft throw and a 77.5 x 33in screen. The projector is located on the opposite wall below the plain of the top masking, so I am using a small amount of downwards lens shift. (I use zoom to achieve all different aspect ratios including 2.2, 2.35 and 2.40:1 to maintain a constant height, but the slight pincushion is visible to me on all ratios.) None of my movie audiences notice this and of course it is neatly hidden with masking, but the only annoyance is to the perfectionist me!
post #23 of 31 Old 03-20-2013, 12:20 PM
Liked: 1435
I don't see anything here that should influence pincushion. It is possible that your particular projector has a defective lens, or that the 6010 has this particular issue. Any way you can get your hands on another 6010 or even a different projector altogether for comparison?
post #24 of 31 Old 03-20-2013, 12:41 PM
musicalfox's Avatar
Quoted: 16 Post(s)
I don't think it's a defective lens because I didn't have the problem before taking the projector off its shelf to run some cable tests. I suspect I may have to do a little more tweaking. And you may be right about the lens not being absolutely square on. Either way, it's not a complete deal breaker, as it doesn't even register with subtitles (but does slightly with Blu-ray bottom-screen progress bars). I will keep working on it and thanks again for your help.
post #25 of 31 Old 03-20-2013, 01:32 PM
Liked: 1435
I agree that making sure the lens is square to the screen is your best course of action. Let us know how things turn out.
post #26 of 31 Old 03-29-2013, 09:42 AM
musicalfox's Avatar
Quoted: 16 Post(s)
Still haven't been able to resolve the effect. It's very weird because, like I said, the slight left and right 'moustache' wasn't there before removing the projector from the shelf and all hardware is in the same place. I'm thinking of getting a calibrator guy over who can run some patterns and maybe help me diagnose.
post #27 of 31 Old 06-25-2014, 11:18 AM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
only adding a pic of my curved screen because I want to learn how to add pics to posts with this new format:
ok, too dumb to figure it out. Can one of you younger guys tell me how to assign a URL to an image I have so I can insert it? Or at least tell me how to use this confounded new contraption???
edfowler is offline
post #28 of 31 Old 06-25-2014, 12:17 PM
Josh Z's Avatar
Quoted: 2422 Post(s)
Liked: 1589
There may be better ways, but this is what I've managed to make work:
1) Click the Attachments button (paperclip icon).
2) Choose your file and Upload. Close the pop-up window.
3) Click the Attachments button again. Your file should be listed there. Click on it, and it should insert into your post.
4) Submit your post. This will show the image as a small thumbnail that someone can click to enlarge.
If you want your image to appear larger in the post:
5) Click the thumbnail, then right-click the image and Copy URL. Close that.
6) Edit your post. Click the Insert Image button (yellow box with mountains or something in it). This will ask you to paste your URL. Do that, and it will insert the larger image into your post above the thumbnail.
Kind of a pain in the butt, I agree.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #29 of 31 Old 06-25-2014, 12:49 PM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
thanks Josh, here goes:
edfowler is offline
post #30 of 31 Old 06-25-2014, 12:56 PM - Thread Starter
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
trying it larger:
edfowler is offline
Reply 2.35:1 Constant Image Height Chat
