Mits HC9000d CIH zoom setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-09-2013, 02:54 PM - Thread Starter
mc man's Avatar
Okay I just purchased my hc9000d and I want to do a CIH zoom method "for now" I have a 110" 2:35 diagonal stewart firehawk g3 screen. The projector has a 1.8x zoom. Where is the optimum throw distance for this setup? I am new to CIH and I could use some advice!!
Dave
mc man is offline
post #2 of 2 Old 03-18-2013, 09:58 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Technically you could use it anywhere that still gives you 1.33x zoom in the range. You will have to still lens shift the image as well for each AR change. Personally I would still use it in a long throw as you get better CR this way.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
Reply 2.35:1 Constant Image Height Chat
