Different Ratio Setups - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 04-15-2013, 12:42 AM
RapalloAV's Avatar
Quoted: 1314 Post(s)
Liked: 292
Originally Posted by Josh Z View Post
Here is a tutorial with pictures that should help answer some of your questions.
The link is broken Josh
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
Old 04-15-2013, 12:29 PM
Josh Z's Avatar
Quoted: 2153 Post(s)
Liked: 1443
Originally Posted by mijotter View Post
On another note. I will be having a 112" diagonal scope screen with a CIH of 43". Would anyone know or have an educated guess as to the height of the letter box bars when playing a scope movie. I'll be getting a Panny AE8000 so I can zoom so the picture fills the screen but the black bars will still be there just off screen.
Based on your numbers, I assume you're defining "scope" as 2.40:1 (not 2.35:1).
If your height is 43", that would make your width 103" to get a 2.40:1 screen.
103 / 43 = 2.4 (rounded)
Do you remember your Pythagorean Theorem? A squared + B squared = C squared. This would give you a diagonal of 112".
So, if you're projecting a 16:9 Blu-ray to fill the full width of the frame, the image will be 103" wide by 58" tall. (103 / 58 = 1.78)
The difference between 58 and 43 is 15, which means letterbox bars of 7.5 inches each above and below the screen.
Again, all of these numbers are rounded, so the exact amount may be slightly different, but that's approximately what you should expect.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
Old 04-15-2013, 12:30 PM
Josh Z's Avatar
Liked: 1443
Works when I click it.
http://www.highdefdigest.com/news/show/2798
Josh Z
Josh Z is offline
Old 04-15-2013, 07:45 PM - Thread Starter
mijotter's Avatar
Liked: 59
Josh, wow you nailed it. Thanks so much. Would it be advisable to have that 7.5 inches on the top and bottom in black velvet or would a 2 inch trim and black paint be sufficient?
Also I was planning on building a shelving unit to house the equipment and movies underneath the screen. Will the bottom black bar look weird on said shelving?
mijotter is offline
Old 04-15-2013, 08:51 PM
MikeyD360's Avatar
Liked: 26
You're equipment will likely be metal or plastic which will reflect the light back at you creating distraction. top or bottom should be light absorbing as much as possible. If you do put a rack in the path of the light beam, cover it with something like a black curtain or similar.
MikeyD360 is offline
Old 04-15-2013, 08:59 PM - Thread Starter
mijotter's Avatar
Liked: 59
Well I was going to have tinted glass for the cabinet/shelving doors to avoid that issue along with the power lights as well. The only problem is, I'll have enough space above the screen for the 7.5 velvet area. However the shelving below the screen is going to be fairly close to the bottom of the 2" trim for the screen and it is literally the sensible place to put my equipment and movies as my room is fairly small and no chance in the adjacent room either.
mijotter is offline
Old 04-16-2013, 09:58 PM - Thread Starter
mijotter's Avatar
Liked: 59
Would this present a problem at all?
mijotter is offline
Old 04-16-2013, 10:36 PM
MikeyD360's Avatar
Liked: 26
Putting the equipment underneath is not a problem, I would personally just put something over the front, like a black curtain, to stop light playing off the equipment and distracting you - that way its still accessible.
