Mounting projector and A lens in projection room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-16-2013, 03:31 PM - Thread Starter
Johnnymenudo's Avatar
Quoted: 66 Post(s)
I am building a dedicated room and the back wall is adjacent to the equipment room. One of the things I don't like about using a projector is the having a projector above your head concept. My room will be 24' deep and 16.5' wide and I am thinking a 2.35:1 screen that could be anywhere from 120-140" wide. Does anyone know of a projector that would be capable of throwing an image bright and long enough that I can mount the projector through an opening or window on the back wall? Is this a goofy idea? I think it would be cool if it is possible.
Johnnymenudo is offline
post #2 of 4 Old 01-16-2013, 04:39 PM
RapalloAV's Avatar
Quoted: 1627 Post(s)
Liked: 474
Lots of us dont like projectors above our heads, so yours is not a goofy idea! See mine here and the separate projection area.
http://www.rapalloav.co.nz/blog/rapallo-home-cinema-build
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #3 of 4 Old 01-17-2013, 01:05 PM
CRGINC's Avatar
I feel as you do. My projector is mounted on the ceiling but behind me. The real issue is most of the median priced projectors have throw ratios just over 2:1. My old Sony is 2.4.:1 but recent models are about 2.2:1. Only higher end units that have multiple lenses that have throw ratios greater than 2:1. JVC units are 2.8:1 but that is about the limit for single lens units. It sounds like you need a projector with multiple throw lenses. Runco makes them and other manufacturer's do as well but there is usually a price tag associated with this capability. Behind my theater is a bathroom that I would like to convert into a projection booth like you describe. Good luck.
CRGINC is offline
post #4 of 4 Old 01-27-2013, 12:22 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
As mentioned Runco and Digital Projection both make projectors capable of that throw ratio. PM me if you need details on either..
Scott
GetGray is offline
Reply 2.35:1 Constant Image Height Chat
