Help with selecting 2.35 screen size and other CIH questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-20-2013, 07:38 AM - Thread Starter
sonichart's Avatar
Quoted: 229 Post(s)
Liked: 172
Hoping the 2.35 CIH crew can perhaps help me out with selecting a screen size. I'm ultimately looking to go Seymour AV AT-screen. 2.35:1 ratio, but would consider a curved screen if its needed.
The current unfinished dimensions of my theater build are 172" wide by 244" long. From left to right ,I figure to eliminate 10" for framing+drywall leaving 162" of space to be used for screen-width.
My initial plan was to create an AT space of about 30" deep... minus ~5" from the back wall for framing+drywall and thats 208" from back wall to screen wall.
How big of a 2.35 screen can I go along with the use of an A-lens (likely the Prismasonic). My initial thought was 120" wide... but can I get away with 130"? or 140"?
Is the throw distance (or throw ratio) measured from the front of the projector or with the A-lens in place?
sonichart is online now
post #2 of 12 Old 02-20-2013, 09:12 AM
John Schuermann's Avatar
Quoted: 818 Post(s)
Liked: 782
Really how big you can go is going to be determined primarily by the brightness of the projector you are using, plus your seating distance and preferences.
At Panamorph we use screen height to determine throw ratio, rather than width. Using height eliminates the confusion around whether or not you use the 2.35:1, 2.40:1 or 16:9 width. Typically we recommend a throw ratio of at least 2.85X the screen height, which should also work if you end up with the Prismasonic. It is a bit safer to judge from the front of the anamorphic lens, since longer throw distances are almost always better for anamorphic setups.
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is offline
post #3 of 12 Old 02-20-2013, 09:45 AM - Thread Starter
sonichart's Avatar
Quoted: 229 Post(s)
Liked: 172
If I had to buy the projector today, it would be the JVC 4810... but what will likely happen is I will wait for the next generation of JVC projectors until I make the purchase.
post #4 of 12 Old 02-20-2013, 10:16 AM
Quoted: 818 Post(s)
Liked: 782
I am running a JVC HD750 with a Panamorph DC1 on an 11 foot wide 2.35:1 screen - it's *just* bright enough with a new bulb, set to standard (low) power. Stewart StudioTek 130, so a 1.3 gain.
John Schuermann
post #5 of 12 Old 02-20-2013, 10:37 AM - Thread Starter
sonichart's Avatar
Quoted: 229 Post(s)
Liked: 172
I don't have room in the budget for a Stewart screen (wish I did!), but I think the Centersatge XD has a 1.2 or 1.3 gain to it.
My main concern is whether I will experience pincushion effect given my distances that would prompt me to purchase a curved screen. I'm not too concerned about brightness (yet), as I don't like a super-bright image. I have a Panasonic GT50 and I think that the THX Cinema setting for movies is too bright in some scenes... Almost creates a blurry-halo effect to my vision (future wife's vision as well).
Would an 11-foot wide, 2.35:1 image require a curved screen using an A-lens from the distances I mention above?
post #6 of 12 Old 02-20-2013, 04:45 PM
Quoted: 818 Post(s)
Liked: 782
As long as you are at least 2.85X the screen height, you will probably not find the pincushion objectionable at all. For an 11 foot wide image, your screen height would be 56". 56" x 2.85 = 159.6", or about 13.5 feet. The further back you go the less pincushion there will be. Since your room is about 20 feet deep and you only plan on a 30" deep acoustic space behind the screen, that gives you about 17 feet to play with. I am not very familiar with the Prismasonic lenses, but these figures should apply to it as well. The Panamorph sweet spot is 14.5 - 17.5 feet and I would think that the Prismasonic should work about the same.
John Schuermann
post #7 of 12 Old 02-20-2013, 04:59 PM
Yzfbossman's Avatar
Quoted: 44 Post(s)
Liked: 75
Just so you don't get your expectations too high, XD's gain is well documented at .94 -1.0 ....very good for a weave.
http://www.accucalhd.com/documents/accucal_front_projection_screen_report.pdf
Here is my build thread:
---->Like a Boss Theater Build<----
Yzfbossman is offline
post #8 of 12 Old 02-20-2013, 07:33 PM - Thread Starter
sonichart's Avatar
Quoted: 229 Post(s)
Liked: 172
John,
Thank you very much for the replies. This definitely helps with consideration for screen size as I have little doubt in going the A-lens route. I still have to educate myself on the difference between Panamorph and Prismasonic .... cylindrical v. prism .... etc etc. before making a purchase, so I guess its back to searching through the dungeons of AVS for an answer. It seems like there is very little side by side comparisons of lens or reviews of anything.
Bossman,
Thanks for the headsup with regard to the screen gain of the Centerstage... I'm actually relieved that the real-life numbers are lower than advertised as I don't particularly care for a super bright image. As I stated earlier, I feel like my Panasonic GT50 plasma is too bright (blurry halo effect) when using the default THX Cinema mode. I'm not sure if its my vision, but I don't much care for the effect...
post #9 of 12 Old 02-22-2013, 03:07 PM
Quoted: 818 Post(s)
Liked: 782
John,
I appreciate your comments.
FYI, Panamorph lenses are not straight prismatic, but a cylindrical / prismatic hybrid.
John Schuermann
post #10 of 12 Old 02-28-2013, 07:57 AM
stanger89's Avatar
Quoted: 2652 Post(s)
Liked: 1355
Yup, AFAIK all the "good" "prism" lenses we talk about here have a cylindrical element(s?) to correct CA and Astigmatism.
stanger89 is offline
post #11 of 12 Old 02-28-2013, 03:32 PM
steve71's Avatar
Quoted: 72 Post(s)
Liked: 36
Soinc, I hope you don't mind if I ask a question in your thread. Hopefully you find it relevant too. smile.gif
I was wondering what do you give up on a cylindrical / Prism hybrid vs an all out cylindrical lens?
steve71 is offline
post #12 of 12 Old 03-01-2013, 03:40 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
CA correction is part of the prisms themselves (doublets made from two glass types cemented together), not the cylindrical astigmatism corrector. The cylindrical astigmatism corrector is typically a singlet made from BK7 glass.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
Reply 2.35:1 Constant Image Height Chat
