2.35:1 with Sony HW50 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 02-21-2013, 03:28 PM - Thread Starter
lakeville's Avatar
Hi All,
I just purchased a Sony HW50 projector and an really torn on what screen to get. I really want the 2.35:1 as 99% of the viewing will be movies. I was told not to consider the 2.35:1 becuase the Sony does not have lens memory. If most of my watching is movies, and I get a masking system for the occasional 16x9 will I be safe?? Do you guys see any flaws in my plan???
-thanks much
lakeville is offline
post #2 of 23 Old 02-21-2013, 11:43 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
If you want Scope because that is the majority of you watch, then go Scope.
Sure start with zooming as you can always add an A-Lens later if required.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #3 of 23 Old 02-22-2013, 03:15 PM
John Schuermann's Avatar
Quoted: 813 Post(s)
Liked: 782
The Sony does not have lens MEMORY, but it does have lens zoom. You just need to manually adjust each time using your own skills smile.gif
An anamorphic lens would work great with an HW50, as it has the necessary scaling modes.
DrZaus likes this.
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is online now
post #4 of 23 Old 03-19-2013, 10:53 PM
DrZaus's Avatar
Hey guys/gals, I wanted to know will I run into any issues using the Da-Lite High Power 166" 235:1 with the Cinevista lens with the Sony HW50ES?
DrZaus is offline
post #5 of 23 Old 03-20-2013, 01:28 PM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 153
I know someone in the UK who has bought an Isco II lens to go with his VW50ES after borrowing mine to try it out. He seems very pleased with it and he has (I think) a 4 metre wide 2.35:1 screen which is painted drywall. Search on AVF for 'Jagdeepp' to see his setup.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #6 of 23 Old 03-20-2013, 02:30 PM
Quoted: 813 Post(s)
Liked: 782
No issues unless you fall outside the throw ratio and distance guidelines for the CineVista itself. As discussed above the HW50 has all the necessary processing to make the CineVista look its best.
John Schuermann
post #7 of 23 Old 03-25-2013, 06:08 PM
Smackrabbit's Avatar
Quoted: 30 Post(s)
Liked: 90
I actually recently reviewed that hardware setup, though with a 122" Screen Innovations screen instead of the Da-Lite. 166" is getting pretty large, but the Sony is very bright, and even in high power mode it is exceptionally quiet. Anyway you can read the whole thing here http://www.hometheaterhifi.com/video-accessories-misc/video-accessories-misc/affordable-anamorphic-system.html and see if that answers your questions.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
post #8 of 23 Old 04-02-2013, 07:08 PM
timhet's Avatar
If you watch 99% movies, then it may not be worth spending the extra on a lens just so you can swap between aspect ratios faster.
Obviously, some movies will be in other ratios like 1.85 and 1.78.
I would just buy the screen first and see how it goes manually going between the ratios. Take it from there.
You might not even need masking...see how you feel about the side black bars, which will be fairly black given no light will be projected on them, considering the projector is 16:9 natively.
timhet is offline
post #9 of 23 Old 06-14-2013, 02:08 AM
mnj1987's Avatar
This combination is great. Ill post photos of my setup next week when it gets installed.
The 50es has a v-stretch aspect mode for 2.35 movies and a squeeze aspect mode for viewing 1.78 or 1.85 content. No need to manually zoom everytime. Just press the aspect button.
my setup is a 50es with a prismasonic lens and a 2.35 110" black diamond screen.
mnj1987 is offline
post #10 of 23 Old 06-17-2013, 07:03 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Here's a nice little review of the Sony mentioned here and the DC-1.
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #11 of 23 Old 06-19-2013, 11:01 AM
Mike Garrett's Avatar
Quoted: 5567 Post(s)
Liked: 3544
The problem is going to be the pincushion. Mount far enough back so that you do not have excessive pincushion, you are out of the focus range for that lens. Mount in the focus range and then you have a lot of pincushion.
mjgarrett100@gmail.com
Mike Garrett is online now
post #12 of 23 Old 02-25-2014, 06:33 PM
Romans828's Avatar
Quoted: 140 Post(s)
Liked: 70
I apologize for my ignorance in this area. I'm trying to make the 16:9 vs 2.35 decision. I haven't bought a projector yet but will likely get a Sony. With the v-stretch and squeeze modes, do you still need the prismasonic lens? Since most movies are in 2.35, I'm trying to grasp why all the projectors are 16:9. Its hard to believe that they aren't providing an "easy" solution.
JVC RS600 | Dual PSA V3600i | Denon X6300H | Klipsch THX Ultra 2 | CDT-5800-C II Atmos | Oppo UDP-203
Romans828 is offline
post #13 of 23 Old 02-28-2014, 12:42 AM
Seegs108's Avatar
Quoted: 4197 Post(s)
Liked: 2088
Most of them are providing an "easy" solution. It's called lens memory, but unfortunately the only projectors that can take advantage of such a technology need motorized lens control. Unfortunately this Sony model doesn't offer a motorized lens. Take a look at JVC's base model and you'll get your "easy" solution.
The squeeze mode is for use when you don't have a motorized anamorphic lens setup and need to display 1.78:1 material through an anamorphic lens. It will scale the image to get the proper geometry. The v-stretch is to scale the image 1.33x vertically so that when the image is sent through the anamorphic lens it has the correct geometry on screen.
Romans828 likes this.
Seegs108 is online now
post #14 of 23 Old 02-28-2014, 05:02 AM
Romans828's Avatar
Quoted: 140 Post(s)
Liked: 70
Thanks Dylan. I appreciate you taking the time to answer my questions. I haven't been looking at JVC...but maybe should start.
post #15 of 23 Old 03-03-2014, 10:29 AM
bburstei's Avatar
I recently had a lot of these concerns when trying to decide what projector to buy. I knew I wanted to run a CIH setup so after reading a few threads I was convinced I needed to have lens memory as my budget didn't allow for an anamorphic lens. Long story short, I decided to give the Epson 5030 a shot (it does NOT have lens memory). In my price range my only options for lens memory would have been the Panasonic 8000 or one of the entry level JVC models. Horror stories about customer support scared me away from the Panny and I was concerned that the JVC may not have enough light output since there is ambient light in my space. It takes me ~30 sec. to manually zoom, lens shift and refocus for my setup - in other words, no big deal.
bburstei is offline
post #16 of 23 Old 03-15-2014, 03:19 AM
Ebase131's Avatar
Quoted: 37 Post(s)
Popped open my sony VPL-HW50ES for the first time tonight and experimented with manually zooming between aspect ratio to get proper screen sizes for movies. Gotta say a huge thanks to Craig here at avs for saving me $1500+! This projector is breathtaking, my goodness.
Ebase131 is offline
post #17 of 23 Old 03-17-2014, 03:36 PM
ndskurfer's Avatar
Quoted: 39 Post(s)
Liked: 52
I tried out my first 3D movie since installing my panamorph cinevista lens last night on my HW50ES. Anybody watching 3D with this projector and scope lens? I realized last night that you can not do "verticle stretch" or "squeeze" when displaying 3D with this projector (keep in mind that the cinevista is not designed to be slid out of the way when viewing 16:9, and is considered fixed). I'm at a loss on what I should be doing when watching 3D? The only solution I can think of, although I have not tried it yet, is to manually slide the lense over on the hinges and do a manual zoom w/o the lens, defeating the purpose of the scope lens in the first place. I don't believe I will be watching a lot of 3D, but really bummed out that it will be very manual after sinking in all the cash for a lens, etc.
Am I a candidate for a lumagen mini 3d? I would consider ditching the cinevista if I do this. If I did, any compromises that I would be making by doing so? Thoughts on other solutions?
ndskurfer is offline
post #18 of 23 Old 03-17-2014, 04:15 PM
Romans828's Avatar
Quoted: 140 Post(s)
Liked: 70
 I didn't think that 3D with a lens would be an issue. Are anamorphic lenses not compatible with 3D?
post #19 of 23 Old 03-17-2014, 05:34 PM
ndskurfer's Avatar
Quoted: 39 Post(s)
Liked: 52
They are but this projector is unable to apply "vertical a stretch" and "squeeze" when processing 3d. Those options are available for 2d, but skips over them when pressing the aspect button on the projector remote when a 3d video is displayed. I guess the Epson 6020 does not have this issue.
post #20 of 23 Old 03-18-2014, 11:00 AM
Quoted: 813 Post(s)
Liked: 782
Confirmed - the Sony 50ES does not vertically stretch 3D content. JVC and Epson do.
The Lumagen Mini will handle the vertical stretch. So will an Oppo 3D Blu-ray player (although I understand that the Oppo does not like certain titles).
John Schuermann
post #21 of 23 Old 03-18-2014, 12:48 PM
ndskurfer's Avatar
Quoted: 39 Post(s)
Liked: 52
Thanks John. I found another thread that I replied to regarding scaling through the Oppo player with a 3D movie ripped into a MKV container.
post #22 of 23 Old 03-18-2014, 01:54 PM
Romans828's Avatar
Quoted: 140 Post(s)
Liked: 70
Wow....great information to know before making a purchase! :) Maybe Sony will address this in the next mid-range 2014-15 model.
post #23 of 23 Old 03-18-2014, 02:26 PM
Quoted: 813 Post(s)
Liked: 782
BTW, the Sony 4K units will vertically stretch 3D 1080P. No one can vertically stretch 4K native material yet, though.
John Schuermann
Reply 2.35:1 Constant Image Height Chat
