Chromatic Correction and Inexpensive A-Lenses - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-02-2013, 02:50 PM - Thread Starter
blastermaster's Avatar
Quoted: 430 Post(s)
Liked: 550
So, I've been reading up on the new Cinevista lens and the Chromatic Correction that comes with certain projectors. I've mentioned a few times in this forum that I have a HTB lens with the correction element. The element works to a degree, but I definitely still notice CA at the edges of my screen. Am I right that apart from noticing purple fringing on text that it also contributes to the loss of focus at the edges? I would love to get a new fancy lens, but it's just not in the cards right now (damn the home renos!). If this correction will work on the new Cinevista lens it should also work for any lens that has chromatic aberration, should it not? I'd eventually like to get the U480 or some similar variant but again I don't have the funds for that right now. I'm thinking that if a lot of the newer projectors come out with this CC feature it may eventually trickle down into more budget projectors. Here's hoping.
Video: Optoma HD3300, Panamorph UH480, Darbee Darblet, Samsung BD D6700 Blu Ray player, DIY Seymour Centerstage XD 138" Curved Screen
LCR - Tannoy DC12i, Sides - Tannoy IW63, Rears - Tannoy Saturn DC6ti Bookshelf, Ceilings - Tannoy CMS 603DC (TF), Tannoy CMS 601DC (TR), 3 Micro Marty/1 Full Marty DIY subs
Amplification: Emotiva XPA-3, Emotiva XPA-2, Outlaw Audio 7700, 2x Inuke 6000DSP
Receiver: Anthem MRX 720
blastermaster is offline
post #2 of 6 Old 04-02-2013, 08:14 PM
John Schuermann's Avatar
Quoted: 813 Post(s)
Liked: 781
Focus and chromatic aberration are two different things. With aberration, all three color images are sharp but misaligned. That shouldn’t be confused with focus error even though misalignment might be perceived as blurring.
Yes, the chromatic correction built into certain projectors will correct for aberration in other lenses as well. However, it is my understanding that the HTB lens does not have astigmatism correction, which is a focus issue. Chromatic correction will do nothing to correct for focus.
Keep in mind that I have never seen an HTB lens in action, so I could be wrong about whether or not is has astigmatism correction.
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is online now
post #3 of 6 Old 04-03-2013, 04:14 AM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
AFAIK, they started out as Home Theatre Brothers with trophy prisms and then moved onto a proper optical finish surface and when they changed their name. These new prisms were made from BK7 only, so not CA Corrected. They then made a prototype set of CA corrected prisms which they claimed were designed with Zemax by san optical designer. Photos of the prisms were posted on their blog, but there was no screen caps that I remember seeing. They never took them into production either. They did however produce something they called UACE (Universal Astigmatism Correction Element). Hope I got the name right and that seems to be as far as their "Anamorphic Research" took them rolleyes.gif
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #4 of 6 Old 04-03-2013, 07:59 AM - Thread Starter
Quoted: 430 Post(s)
Liked: 550
Thanks, CAVX. It's lookin' like I'm just going to have to ante up and get a good lens, although I'm not giving up hope on finding a good used one.
post #5 of 6 Old 04-03-2013, 01:18 PM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 153
If you're lucky and have a suitable throw then I'd recommend the Isco II if you find one for sale. Has all the corrections you need (Chromic and astigmatism) and no worries about having a projector with the pixel shifting feature, so you're more flexible in your projector choice. I use mine with a JVC X35 as per the pictures thread you saw.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #6 of 6 Old 04-06-2013, 12:03 PM - Thread Starter
Quoted: 430 Post(s)
Liked: 550
Thanks, Kelvin. Gonna keep my eyes out for that one and perhaps the UH380. I've seen B stock ones go for a price that I can live with (read: wife approval). wink.gif
Reply 2.35:1 Constant Image Height Chat
