Shelf for Projector and A-Lens: Danger of reflections? Necessary for it to be black/low reflectivity? - AVS Forum | Home Theater Discussions And Reviews
Old 05-03-2013, 10:31 AM - Thread Starter
R Harkness's Avatar
Quoted: 1938 Post(s)
Liked: 1645
I'm just re-building a new shelf for my projector and with a Panamorph UH480 anamorphic lens and it's automated sled.
Previously my shelf was painted matte black and this new one will be as well.
However, I'm wondering if ensuring low reflectivity of the projector/lens shelf is actually important, and if so how important? In other words, are there reflections, light leaks from projector lenses, including possibly light bouncing between the A-lens and the Projector lens, that would affect image contrast and require absorption? And if that's the case, if I have the choice between painting the projector/A-lens shelf a flat matte black or going with an even darker surface coating for the shelf (e.g. Prostar material or even black velvet?) would this make any difference?
We have certainly seen that in terms of light reflections a dark black velvet-like material is better than any black paint, and I'm just wondering if this might also play out in the choice of finish on a projector/A-lens shelf.
R Harkness is online now
Old 05-03-2013, 06:12 PM - Thread Starter
R Harkness's Avatar
Liked: 1645
Old 05-04-2013, 12:55 AM
Gary Lightfoot's Avatar
Quoted: 593 Post(s)
Liked: 349
Kelvin has a white shelf for his JVC and lens set up, so you could ask him. He has pics etc over on the UK forum.
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is online now
Old 05-04-2013, 08:56 AM
John Schuermann's Avatar
Quoted: 814 Post(s)
Liked: 782
There is some back reflection from the various lenses. However, I think it might be easiest just to see what residual light your seeing and then make appropriate baffles out of black velvet. That would take care of the majority of concern. Unless your making the entire room black, my guess is that with good baffling you'’ll get more back scatter from the screen image light bouncing off the walls, furniture, clothes, etc. than what would come from the projector/lens back reflections.
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is online now
Old 05-04-2013, 11:56 AM - Thread Starter
R Harkness's Avatar
Liked: 1645
Thanks Gary and John.
My room is a black velvet "cave" so the room isn't an issue, which is why I care about any residual problematic reflections
near the projector. I've never really heard of any talk about this before, though I know some projectors leak some light around the front or lens area. I guess I'll just see what things look like once I'm finished.
Old 05-04-2013, 06:13 PM
Mike Garrett's Avatar
Quoted: 5577 Post(s)
Liked: 3560
Make the shelf depth so that you can place the lens at the front edge. That is what I did.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 05-07-2013, 01:15 PM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 153
As Gary says I have a shelf, but the upper face is just bare MDF (only the sides and underneath are painted light grey to match the wall). I can't really see any 'light peaks' or other issues that might be effected by the light coloured shelf, but my room currently isn't ideal anyway so I have more important issues. The only thing I would be concerned about is heat since this black material would be very close to the projector, but my black Isco II lens doesn't seem to get unduly hot so perhaps that's not an issue anyway.
I think you've probably seen my 'floating shelf' I built earlier this year, but here it is with the Isco in place as well: The Isco is right at the front edge of the shelf so any reflections coming out of the lens would hit the black stand rather than the shelf (nothing visible on the ceiling either as I have looked for this in the past).
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is online now
Old 05-07-2013, 04:30 PM - Thread Starter
R Harkness's Avatar
Liked: 1645
Thanks boys.
I did my new shelf in matte black as I intended anyway. Plus, the A-lens beam clears the front of the shelf anyway.
(I'm still having trouble dialing in this A-lens, though. There seem to be so may parameters to get right - get my projector perfectly flush/plumb to the screen, get the lens straight with the projector, but wait, the lens pattern is a bit off on the screen...so have I not got the projector aligned with the screen, or is it the A-lens that is not aligned with the projector, or with the screen, or both? It's hard to tell which parameter to change).
Old 05-08-2013, 05:48 AM
Quoted: 814 Post(s)
Liked: 782
http://www.panamorph.com/8-support/videos
Have you watched the 480 install video? It should answer your questions.
It is important that the projector be square with the screen and the horizontal lens shift centered. Use of vertical lens shift is fine, though.
John Schuermann
Old 05-08-2013, 08:17 AM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
Thanks boys.
Hi Rich,
Would love to hear your impressions and any setup/dialing-in tips about your A-Lens integration when you are finished! biggrin.gif
Some pics would be great also!
Glenn Baumann is offline
Old 05-08-2013, 05:53 PM - Thread Starter
R Harkness's Avatar
Liked: 1645
Yes thanks I've viewed it. I've squared the projector image, no horizontal lens shift, some vertical shift downward.
BTW, something curious about that instruction video: It recommends to use the projector's lens pattern to test the geometry when setting the lens, and a JVC projector is being used in the demo. I have a JVC RS55 projector. When I first tried to set up the lens using the projector lens pattern I was being driven nuts because it seemed that once the lens was in the path I could never get good geometry. After a while it hit me: even though I'd hit the anamorphic stretch button on my remote, the projector was not, in fact, applying any stretch to the lens pattern. It can't do this - it can only apply anamorphic stretch to picture material. So obviously each time the A-lens was in the path it was warping the non-stretched image.
I had to resort to using patterns from the Spears and Munsil calibration discs to get around this. It seems to me this would not be the case only with my particular model, so it's curious it was no issue in the video demo above.
