2:40:1 screen or 2:35:1 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 37 Old 06-25-2013, 03:32 PM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
If you were starting all over again, would you still get 2:35:1 or go to a 2:40:1 screen.
If I am not mistaking, when you have a 2:40:1 screen and watch 2:35:1 material, you get tiny bars on top and bottom and on the side?
But when you watch 1:85:1 material on it, you get those tiny bars as well, so you need to zoom out the image a bit more to at least lose those bars while you have the bars on the side.
Now the flip side of the coin is having a 2:35:1 screen and watching 2:40:1 material, then the tiny bars on top and the bottom of the screen, am I correct?
Bardia is offline
post #2 of 37 Old 06-25-2013, 04:37 PM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
A 2.37:1 screen might be a nice middle ground! wink.gif
Glenn Baumann is offline
post #3 of 37 Old 06-25-2013, 05:59 PM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
Please explain why..
Bardia is offline
post #4 of 37 Old 06-25-2013, 06:45 PM
stanger89's Avatar
Quoted: 2624 Post(s)
Liked: 1347
Well for one, 1.78 (16:9) times 1.33 (anamorphic lens expansion) = 2.37.
It also minimizes any error which is good since the actual aspect ratio stored on a disc is basically a crapshoot, the difference between 2.35 and 2.39 is less than 2%.
stanger89 is online now
post #5 of 37 Old 06-25-2013, 07:05 PM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
I see so if the screen is 2:37:1
where would the black bars be for 2:35:1, 2:40:1 and 1:85:1 formats?
Bardia is offline
post #6 of 37 Old 06-26-2013, 12:02 AM
coolrda's Avatar
Quoted: 852 Post(s)
Liked: 614
2.35 no bars. 2.40 will have the smallest sliver if no over zooming is used. 1.85 with have side bars only with just a sliver of top/bottom bars if not slightly zoomed off screen.
coolrda is offline
post #7 of 37 Old 06-26-2013, 01:56 AM
biliam1982's Avatar
Quoted: 340 Post(s)
Liked: 164
Barida, what is your setup or planned setup? That would help us steer you in the right direction.
This was discussed pretty recently in another thread. See my comments in there.
http://www.avsforum.com/t/1474387/2-35-or-2-40
biliam1982 is online now
post #8 of 37 Old 06-26-2013, 05:36 AM
stanger89's Avatar
Liked: 1347
OK, this get's a little complicated as it depends on the electronics/method you use.
Starting with the simple setup of a lens and built in electronic scaling (1.33x vertical stretch), you would get (lets assume a 100" wide screen for example):
  • 2.35:1 - no bars but a bit cut off the top/bottom (about 3/16")
  • 2.37:1 - no bars
  • 2.40:1 - small bars top/bottom (just about 3/16" each side)
  • 1.85:1 - large bars (about 12.5") each side, small bars (about 1/8") top bottom
  • 1.78:1 - large bars (about 12.5") each side, no bars top/bottom
Now if you go the "mac daddy" route with a video processor that can scale/stretch any aspect ratio:
  • - small bars top/bottom (just about 3/16" each side)
  • 2.37:1 - no bars
  • 2.35:1 - small bars (about 0.5") each side
  • 1.85:1 - large bars (about 11") each side
If you were to zoom it could go either way, but my understanding of that method means that if you used lens memory it would be more like the first (since the memory only remembers 2 positions?), but if you do it manually you could achieve the second.
Of course the second method has the advantage of supporting "oddball" aspect ratios like 2.2:1 or 2.0:1 of some movies, and they could be displayed wider without bars top/bottom or cropping.
Eksohek likes this.
post #9 of 37 Old 06-26-2013, 10:39 AM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
  • 2.37:1 - no bars
  • 2.37:1 - no bars
Thank you. That was very informative. Well the 4810 has 5 lens memories, so I was thinking to set them to 1:78:1 - 1:85:1 - 2:20:1 - 2:35:1 - 2:40:1
Bardia is offline
post #10 of 37 Old 06-26-2013, 08:05 PM
TK Doom's Avatar
Just for the record, i love my 2.4. I would have been dissatisfied if I'd of gotten a 2.35.
Granted I spent a ton of money on the whole thing and that probably isn't the norm. but just saying!
TK Doom
Unreal Tournament Forever
Project Gotham Racing too!
TK Doom is offline
post #11 of 37 Old 06-26-2013, 08:45 PM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
So when you watch 1:85:1 do you get some bars on top and bottom?
Bardia is offline
post #12 of 37 Old 06-26-2013, 10:11 PM
tgrinch's Avatar
Quoted: 21 Post(s)
When I made the decision, I went with 2.35 and am happy with it. We occasionally watch TV in the room and going with 2.35 vs. 2.4 gave me about an inch or so taller image. With the lens in front the tiny black bars are hardly noticeable at all. I think you'll be happy with either choice.
tgrinch is offline
post #13 of 37 Old 06-26-2013, 11:02 PM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
That's what I was thinking and plus, I just noticed Star Wars is 2:35:1, case closed for me!biggrin.gif
Bardia is offline
post #14 of 37 Old 06-27-2013, 12:01 AM
TK Doom's Avatar
No, because I bought a projector that has lens memory. So it zooms it a tad and motorized masking takes care of the sides.
TK Doom
TK Doom is offline
post #15 of 37 Old 06-27-2013, 05:35 AM
stanger89's Avatar
Liked: 1347
But is it, or is that just the number they put on the case? There's really no telling from the labeling what the precise aspect ratio of the transfer is.
post #16 of 37 Old 06-27-2013, 10:56 AM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
Yes for Blu ray it's 2:35:1 but original aspcet ratio was 2:39:1
Bardia is offline
post #17 of 37 Old 06-27-2013, 10:57 AM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
But your screen height is 1 inche shorter than 2:35:1, correct? I thought about that, and I rather have a taller 1:85:1 image.
Bardia is offline
post #18 of 37 Old 06-27-2013, 12:07 PM
Josh Z's Avatar
Quoted: 2134 Post(s)
Liked: 1432
Did you measure this, or did you read it somewhere? In the film industry, the terms "2.35:1", "2.39:1" and "2.40:1" are used interchangably. The original theatrical ratio for "scope" movies was 2.35:1, but Panavision changed that to 2.39:1 in 1970. Technically, it's 2.39 and change, which many people round up to 2.40. Nevertheless, the term "2.35:1" continues to be used out of habit. Even though this doesn't make mathematical sense, it's the way things are.
How any particular movie will wind up transferred to home video is a crapshoot. Sometimes you'll get a precise 2.40:1, but other times the picture may be slightly cropped (or open matte) to 2.35:1, depending on how the telecine machine was calibrated. The disc packaging is no help in telling you what you'll actually get, because the marketing people who write that text don't understand the technical differences and just pick whatever number they like the sound of.
DVD and Blu-ray reviewers rarely measure this either, because the majority of them are watching on 16:9 screens and don't see the difference. Most will just recite whatever number is listed on the case (which, again, is frequently inaccurate). The only people you can trust to tell you the actual aspect ratio of a disc are CIH viewers who've played it on their scope screens.
The reality of the situation is that the difference between 2.35:1 and 2.40:1 is so miniscule that it's not worth frettting over. Whichever aspect ratio screen you choose, zoom your projector out a smidge and the black bars will spill off onto your masking material anyway.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
post #19 of 37 Old 06-27-2013, 12:17 PM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
No you're right, I just went with the 2:35:1 to have a 1 inch taller image than 2:40:1 But it's all pretty much the same at the ned of the day..
Bardia is offline
post #20 of 37 Old 06-27-2013, 03:24 PM
stanger89's Avatar
Liked: 1347
FWIW, the two episodes I checked (I and IV) were 2.344:1
post #21 of 37 Old 07-07-2013, 09:50 PM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
The reality of the situation is that the difference between 2.35:1 and 2.40:1 is so miniscule that it's not worth frettting over. Whichever aspect ratio screen you choose, zoom your projector out a smidge and the black bars will spill off onto your masking material anyway.[/quote]
But wouldn't the sides of the pic be lost when you do that?
Bardia is offline
post #22 of 37 Old 07-08-2013, 12:10 PM
John Schuermann's Avatar
Quoted: 812 Post(s)
Liked: 777
Yes, but only a tiny amount. As I posted in another thread here:
...the vast majority of UltraWide movies are going to be transferred to Blu-ray / DVD with a ratio somewhere between 2.35:1 or 2.40:1. Even though the standard has actually been 2.39:1 since 1970, directors and video transfer techs often mess with the picture framing when transferring to video. This explains why a film may have slightly different framing each time it gets transferred. Contrary to popular belief, the framing of an image is almost never calculated down to some kind of precise ratio when shooting. Both directors and DPs will take into account the fact that the film is eventually going to be projected or shown in something other than the original aspect ratio, so frame accordingly. 2001 is an excellent example. Kubrick shot 2001 in 70mm, which has an aspect ratio of 2.20:1. However, the only folks who ever saw 2001 in 2.20 where those who lived near a theater equipped to show 70mm (these theaters were usually only in the biggest cities). Everyone else got to see 2001 cropped down to 2.35:1, just like you experienced it with your system. When Kubrick composed the image, he knew full well that 80 - 90% of viewers would actually get to see it at the 2.35:1 ratio. For that reason, I can't imagine that he put any vital picture information at the very top and bottom of the picture.
Unlike panning and scanning - where it is obvious that a picture's original composition has been destroyed - what you are talking about here is pretty much SOP in the filmmaking world. I've been on numerous shoots, and its not like most filmmakers so precisely frame a shot that losing 8% of the top of bottom is going to make any difference at all. In fact, it's amazing how little you can tell about exact framing when you are looking through a tiny viewfinder or video assist monitor, which is that the DP or director are using for framing purposes when setting up a scene.
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is online now
post #23 of 37 Old 07-08-2013, 12:31 PM
Josh Z's Avatar
Liked: 1432
To add to what John just said, all cinematographers know enough to frame their shots with a little leeway around the edges. Most camera viewfinders actually have "safe action zone" markings, to account for projection variances in commercial movie theaters or the typical overscan on most TVs.
The next time you go to a movie theater, pay attention to the extreme edges of the screen. Odds are that you'll see a little bit of picture being projected off the screen onto the wall. This is extremely common. The cinematographer knows about this, and plans his shots to take it into consideration.
Besides which, we're literally talking about slivers of picture information here. Zooming out a tiny smidge won't affect the compositional intent of the photography.
Josh Z
post #24 of 37 Old 07-08-2013, 01:12 PM
stanger89's Avatar
Liked: 1347
To add a bit more, the difference we're talking about is less than 2%, on a 100" screen that's about 3/4" on the sides or about 3/8" top/bottom. I don't know about the rest of the folks here, but that's about within the error I get when trying to align everything. I'm not sure I've ever seen a screen and projector aligned well enough to where 3/8" top/bottom would matter.
post #25 of 37 Old 07-08-2013, 03:20 PM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
Yeah I thought about it and I think I will stick with 2:35:1, that would also give me a taller 1:85:1 pic by 1 inch.
Bardia is offline
post #26 of 37 Old 07-09-2013, 08:07 PM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
I see. So since the bluray covers are sometimes misleading and don't provide the correct ratio, do you have to wait until you play the movie and then zoom to the proper ratio?
Bardia is offline
post #27 of 37 Old 07-09-2013, 09:41 PM
TK Doom's Avatar
Yes, sometimes that is the case. I start with 2.4 and then go to 2.35 if needed.
The other aspect ratios are another button away.
TK Doom
TK Doom is offline
post #28 of 37 Old 07-09-2013, 10:48 PM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
I see. And what happens when Apple TV is showing a movie in 2:35:1 or 2:40:1? Does it fill the screen?
Bardia is offline
post #29 of 37 Old 07-10-2013, 07:45 PM
TK Doom's Avatar
I'm guessing it'd be like any Bluray...
Lens memory setting.
TK Doom
TK Doom is offline
post #30 of 37 Old 07-21-2013, 11:51 AM - Thread Starter
Bardia's Avatar
Quoted: 35 Post(s)
Liked: 31
After thinking about this a bit, I am now leaning towards 2:40:1 screen.
I figured after going through all the trouble of going widescreen, I would hate to see any damn black bars on top and bottom no matter how small.
So with 2:40:1, I will have no bars for 2:40:1, small bars to medium to large on the side of the screen depending to the aspect ratio.
Bardia is offline
Reply 2.35:1 Constant Image Height Chat
